    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 543.7k Views 172 Watching
    • PixeroP
      Pixero
      Has anyone been able to get the 0.6.3 version to work?
      • rodrigonotorR
        rodrigonotor
        Nop, I still use 0.5.4 versiΓ³n, work fine.
        Regards
        β€’ Sketchando.net β€’ www.arqcad.net β€’
          driven
          I got it working on the mac by separate loading,
          If you do a dif on the two files you can swop things over one at a time and see when it breaks,
          one thing to play with is commenting out the mac bit line 71 if key == 73 #|| key == 105 # i
          • N
            nomeradona
            yes working with sketchup 8
            • sadyoS
              sadyo
              😞 ... It's not working with my SketchUp 8, still using the 0.5.4
                Those of you with problems: can you post more info to what isn't working. "Not working" is like going to the doctor saying "I'm ill, fix me."
                Please be specific by what isn't working (lack of menus, errors, or unexpected behaviour). Also keep the Ruby Console open so you can see if any error messages appear.
                System information such as OS version and exact SketchUp version also helps.
                • V
                  vidy
                  Current problem on ver 0.6.3 on SU 8 at mine:
                  1. When i press alt + click, sometime ivy doesn't follow the direction i clicked.
                  2. Some time it doesn't react as it is supposed to be when i press ctrl + click (to grow leaves)
                  3. And the most problem.. it just won't finished when i press shift + click, so it never generated the ivy. 😞
                  but when i used ver 0.5.4, it's all work perfectly.. πŸ˜„
                  still so much to learn..
                    In the script's line #20 [..branch] and line #244 [..tool] [and probably other lines too πŸ˜• ] there is some arithmetic where something that's 'nil' is subtracted from something else and so it returns an error...
                    Either put these parts into begin...rescue...end traps so the error won't trip up the script OR better test if the variable is NOT 'nil' and setting it to say 0 if +or- or 1 if *or/ - e.g. xxx=0 if not xxx
                    The tools could be trapped to return at least something 1-seed.params[:branch][:spread] will fail if NOT seed.params[:branch][:spread] (i.e. it's nil)...
                    LiveIvy.seed is defined as @@seed which in turn is defined as ' self' πŸ˜•
                    which in turn has params which have :branch and :spread... BUT somewhere some of these aren't getting set to 0 [or 1 ?] as a safety net ??
                    • PixeroP
                      Pixero
                      I have the same problems as Vidy.
                      • It doesnt branch. Just one stem.
                      • Doesn't finish. 😞
                        Windows 7 64bit. SU 8.
                      • rodrigonotorR
                        rodrigonotor
                        You're rigth, here are the info:
                        Sketchup 8.0.3117
                        Sketchup Ivy 0.6.3
                        Win 7 Ult
                        Only create a little part of the Ivy and when I make Click+Shitft not work at all.
                        Ruby Console:
                        Error; #<TypeError; nil can't be coerced into Fixnum>
                        C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_branch.rb;20;in `-'
                        C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_branch.rb;20;in `initialize'
                        C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_branch.rb;49;in `new'
                        C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_branch.rb;49;in `grow_stem'
                        C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_branch.rb;38;in `each'
                        C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_branch.rb;38;in `grow_stem'
                        C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;204;in `grow_stem'
                        C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;203;in `each'
                        C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;203;in `grow_stem'
                        C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;202;in `times'
                        C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;202;in `grow_stem'
                        C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;90;in `onLButtonUp'
                        Click+Shift
                        Error; #<NoMethodError; undefined method `-' for nil;NilClass>
                        C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;244;in `birth_stem'
                        C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;237;in `each'
                        C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;237;in `birth_stem'
                        C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;226;in `birth'
                        C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;93;in `onLButtonUp'
                        quietly_force_sync_mats_cb just called
                        • sadyoS
                          sadyo
                          • Doesn't finish. 😞
                          Yep, I have the same problems too, just like i/we already reported since v0.6.2
                          Windows 7 64bit, SU8.0.4811 pro
                          • urgenU
                            urgen
                            ....O-O-O-goooooooood! πŸ‘ please,do not stop this work,! πŸŽ‰
                            --pupil forever...------
                              SketchUpNoobie
                              O.K. This is embarrassing. πŸ˜’
                              How do I open the .rar file? πŸ˜• Do I just drop it in my plugins folder or do I need to do anything else such as extracting it somehow. I downloaded it right to my plugins folder and it doesn't seem to be showing up.
                              SketchUpNoobie: the complete noob in all things SketchUp.
                                .rar is a different compression format. Use 7zip or PeaZip to uncompress and then place in plugins folder
                                  SketchUpNoobie
                                  So I have to download an extractor? Then I would extract it the same as I would a .zip? Alright. Thanks.
                                    Yes, Windows doesn't extract .rar and many other compression types. Anyway either of those i posted are great alternatives to have.
                                      SketchUpNoobie
                                      Yep. Thanks. I got PeaZip seems to work well and looks like a useful tool.
                                        SketchUpNoobie
                                        I haven't read through the whole thread so please forgive me if this has been asked and/or solved before.
                                        I play around with my ivy until I am satisfied but when I Shift+Click to create the actual geometry, nothing happens. πŸ˜• Am I doing something wrong? I am running SketchUp 7 on Windows XP and have SketchUp Ivy version 0.6.3. I know you said this isn't tested on SketchUp 7. Is this my problem?
                                          SketchUpNoobie
                                          Nevermind. Works fine in SU 8. Really is a bummer though. Will there ever be support for version 7?
                                          • V
                                            vidy
                                            @sadyo said:
                                            I am following what TIG says, about better test if the variable is NOT 'nil', then i try to fill a variable on the Branch Detail,...and voilaaa.... the Ivy appearing like it should and the SketchUpIvy0.6.3 can work very well now.
                                            hooorraaay.. yes its work.. basically we need to input the detail and spread on ivy tab..
                                            thanks tig,sadyo and pierreden for this plugins 😍
                                            regards,
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 36
                                            • 37
                                            • 13 / 37
