    [Plugin] follow me rotate
    211 Posts 79 Posters 258.0k Views 79 Watching
    • E Offline
      emanuelson87
      @solo said:
      I have tried that without anything happening.
      Hello I have the same problem I can not run this plugin you could tell me how you solved it? thanks
      • charly2008C Offline
        charly2008
        It works normally only with a face and a curve. If you want to use it with a straight line than have look at page 5 of this topic. ThereEcuadorian shows a tutorial video.
        Charly
        • brookefoxB Offline
          brookefox
          I have a 3d helix as a curve and a circular face, but the results ain't right. Any tips?
          ~ Brooke
            brookefox
            Results with a 2d spiral:
            ~ Brooke
              Better if surface is drawn on the ground (Flat) as a top view as the helix is vertical
              but not obliged in theory any orientations can be made
              Seems your examples fail because of the Construction Point is out of the surface!
              You can add a Construction Point on the surface By the Didier Bur Projection
              http://www.pushpullbar.com/forums/attachment.php?attachmentid=45446&stc=1&d=1223643779
              Images following by Takesh
              http://www.pushpullbar.com/forums/attachment.php?attachmentid=45450&stc=1&d=1223648103
              http://www.pushpullbar.com/forums/attachment.php?attachmentid=45506&stc=1&d=1223954760
                brookefox
                Thank you for your very helpful help. I will try to implement it.
                ~ Brooke
                  brookefox
                  It's a start!
                  ~ Brooke
                    Looks like a drogue to drag behind a boat. 😄
                    • mitcorbM Offline
                      mitcorb
                      Do you have to group the polygon first? No?
                        Your result is normal 😉
                        Scale 0.2 signify 1/5 at each segment generation!
                        so
                        1, 0.2, 0.04, 0.008...so toward very tiny very speedy 😉
                        Take 0.95 if you want a more smooth reduction 😄
                        PS Put a Construction Point at the center of the surface make nothing more! 😉
                        This one must be excentered for make something funny!
                          brookefox
                          You pick the face and the path, face and curve, no group.
                          Getting somewhere, at least.
                          I'm sparing you the mis-starts, by which means I absolve myself of error.
                          ~ Brooke
                            brookefox
                            I think that degrees of rotation and scaling over the entire path would be useful settings, saving much perhaps tedious calculation for the machine, which does it so much faster.
                            ~ Brooke
                              http://farm8.staticflickr.com/7085/6965349742_2e0f0c498b_z.jpg
                              I had to play a little. 😉
                                The curious is that works for the v6 but not for the V7 for me 😒
                                  brookefox
                                  I will get a boat and try it. Thank you, Dave.
                                  Thanks, Pilou. I figured my interpretation of the scale setting was the problem. I assumed it was over the entire path and that the number would be the result, i.e. 20% of the original at the end. A few extra words in the setting dialog might save a lot of dead drouge drag. Did you miss my construction point? I managed that.
                                  I think another problem is the helix has too many segments to be workable and I am trying now to work that but so far the routine reverses the helix, etc.
                                  ~ Brooke
                                    brookefox
                                    My main problem at the time of my first post, apart from understanding that the settings were per segment rather than per curve, was that I had picked the edges of the face as well as the face. You must not pick the face edges.
                                    The movement of the path from its original location seems inconsistent, though I don't doubt it is obeying some rule. My faces lie on the path and my control points are at the end of the path and on the face, but sometimes the routine moves the path to have its other end meet the face and point. Once with the same entities but a simplified curve it did not do this.; at the moment it is so instead of decreasing from the big end I contrive to increase from the small end.
                                    Use Simplify curves to reduce the segment numbers in a curve if it suits your purposes as it does here for me as I want the faceted look.
                                    Pilou's pics by Takesh, with Pilou's notes, at the wonderful site pushpullbar.com: http://www.pushpullbar.com/forums/showthread.php?9467-Visual-Index-of-Ruby-Scripts
                                    What happens for you now, Pilou?
                                    This is close to the kind of thing I was looking for.
                                    ~ Brooke
                                      brookefox
                                      Suggestion for settings dialog, with a tweak.
                                      ~ Brooke
                                      • mitcorbM Offline
                                        mitcorb
                                        I downloaded the zip version on page 4 or 5, extracted to V7 Plugins. No sign of any part of the script in the menu. No info in preferences>extensions. No toolbar selection. Nothing in the tools menu. Is it a right click context thing? Did I miss something?
                                          brookefox
                                          Did you try page 1: far.rar?
                                          C:\Program Files (x86)\Google\Google SketchUp 7 or 8\Plugins\FollowAndRotate_en.rbs
                                          Called by name in plugin drop down menu...
                                          ~ Brooke
                                          • mitcorbM Offline
                                            mitcorb
                                            The files are in the correct Plugins folder, they just don't "install(?)" to be seen in the drop downs.
                                            • 11
                                            • 7 / 11
