    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 294.1k Views 172 Watching
    • E Offline
      ergio3485
      yes. the same thing happens to me. i've done all you said but in the end it's always the same thing, there's only this pointer with a blue cirlce but when i left-click, shift-click, alt-click, etc... it doesnt' do anything.
      It seems to be a very useful plugin!!! if only i could use it 😞
      • V Offline
        vidy
        im having that issue also here, but you can try to use ver 0.54 at least that still could work at mine πŸ˜‰
        regards,
        still so much to learn..
          driven
          It's well worth pursuing,
          some things to check...
          do the .skp files in the LiveIvy/Textures folder open on there own?
          have you removed all the other versions with different names?
          what version of osx are you on?
          • PixeroP Offline
            Pixero
            Has anyone been able to get the 0.6.3 version to work?
            • rodrigonotorR Offline
              rodrigonotor
              Nop, I still use 0.5.4 versiΓ³n, work fine.
              Regards
              β€’ [Sketchando.net](http://foro.sketchando.net/portal.php) β€’ www.arqcad.net β€’
                driven
                I got it working on the mac by separate loading,
                If you do a dif on the two files you can swop things over one at a time and see when it breaks,
                one thing to play with is commenting out the mac bit line 71 if key == 73 #|| key == 105 # i
                • N Offline
                  nomeradona
                  yes working with sketchup 8
                  • sadyoS Offline
                    sadyo
                    😞 ... It's not working with my SketchUp 8, still using the 0.5.4
                      Those of you with problems: can you post more info to what isn't working. "Not working" is like going to the doctor saying "I'm ill, fix me."
                      Please be specific by what isn't working (lack of menus, errors, or unexpected behaviour). Also keep the Ruby Console open so you can see if any error messages appear.
                      System information such as OS version and exact SketchUp version also helps.
                      • V Offline
                        vidy
                        Current problem on ver 0.6.3 on SU 8 at mine:
                        1. When i press alt + click, sometime ivy doesn't follow the direction i clicked.
                        2. Some time it doesn't react as it is supposed to be when i press ctrl + click (to grow leaves)
                        3. And the most problem.. it just won't finished when i press shift + click, so it never generated the ivy. 😞
                        but when i used ver 0.5.4, it's all work perfectly.. πŸ˜„
                          In the script's line #20 [..branch] and line #244 [..tool] [and probably other lines too πŸ˜• ] there is some arithmetic where something that's 'nil' is subtracted from something else and so it returns an error...
                          Either put these parts into begin...rescue...end traps so the error won't trip up the script OR better test if the variable is NOT 'nil' and setting it to say 0 if +or- or 1 if *or/ - e.g. xxx=0 if not xxx
                          The tools could be trapped to return at least something 1-seed.params[:branch][:spread] will fail if NOT seed.params[:branch][:spread] (i.e. it's nil)...
                          LiveIvy.seed is defined as @@seed which in turn is defined as ' self' πŸ˜•
                          which in turn has params which have :branch and :spread... BUT somewhere some of these aren't getting set to 0 [or 1 ?] as a safety net ??
                          • PixeroP Offline
                            Pixero
                            I have the same problems as Vidy.
                            • It doesnt branch. Just one stem.
                            • Doesn't finish. 😞
                              Windows 7 64bit. SU 8.
                              rodrigonotor
                              You're rigth, here are the info:
                              Sketchup 8.0.3117
                              Sketchup Ivy 0.6.3
                              Win 7 Ult
                              Only create a little part of the Ivy and when I make Click+Shitft not work at all.
                              Ruby Console:
                              Error; #<TypeError; nil can't be coerced into Fixnum>
                              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_branch.rb;20;in `-'
                              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_branch.rb;20;in `initialize'
                              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_branch.rb;49;in `new'
                              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_branch.rb;49;in `grow_stem'
                              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_branch.rb;38;in `each'
                              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_branch.rb;38;in `grow_stem'
                              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;204;in `grow_stem'
                              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;203;in `each'
                              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;203;in `grow_stem'
                              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;202;in `times'
                              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;202;in `grow_stem'
                              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;90;in `onLButtonUp'
                              Click+Shift
                              Error; #<NoMethodError; undefined method `-' for nil;NilClass>
                              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;244;in `birth_stem'
                              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;237;in `each'
                              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;237;in `birth_stem'
                              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;226;in `birth'
                              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb;93;in `onLButtonUp'
                              quietly_force_sync_mats_cb just called
                              • sadyoS Offline
                                sadyo
                                • Doesn't finish. 😞
                                Yep, I have the same problems too, just like i/we already reported since v0.6.2
                                Windows 7 64bit, SU8.0.4811 pro
                                • urgenU Offline
                                  urgen
                                  ....O-O-O-goooooooood! πŸ‘ please,do not stop this work,! πŸŽ‰
                                  --pupil forever...------
                                    SketchUpNoobie
                                    O.K. This is embarrassing. πŸ˜’
                                    How do I open the .rar file? πŸ˜• Do I just drop it in my plugins folder or do I need to do anything else such as extracting it somehow. I downloaded it right to my plugins folder and it doesn't seem to be showing up.
                                    SketchUpNoobie: the complete noob in all things SketchUp.
                                      .rar is a different compression format. Use 7zip or PeaZip to uncompress and then place in plugins folder
                                        SketchUpNoobie
                                        So I have to download an extractor? Then I would extract it the same as I would a .zip? Alright. Thanks.
                                          Yes, Windows doesn't extract .rar and many other compression types. Anyway either of those i posted are great alternatives to have.
                                            SketchUpNoobie
                                            Yep. Thanks. I got PeaZip seems to work well and looks like a useful tool.
                                            • 11
                                            • 12
                                            • 13
                                            • 36
                                            • 37
                                            • 11 / 37
