    Large Terrain Mesh
    105 Posts 11 Posters 26.4k Views 11 Watching
    • charly2008C
      charly2008
      Problem solved! I forgot to change the projection to UTM Datum WGS84.
      Charly
      • GaieusG
        Cool. And now let's see some nice eruption!
          dbwv69
          Through some experimentation and the help of someone who has a newer version of DE, I was able to determine that the problem I was having is related to the way the DE reduces files of different types.
          Solo was importing the DXF file into Sketchup and saving it as Sketchup version 6 prior to reducing the mesh in DE. I was unable to import the DXF file into Sketchup due to it's size so I was opening the DXF file directly with DE.
          After sending a sample DXF file to a friend with a newer version of DE and hearing that he was seeing the same problem, I began to suspect that it must have something to do with the file type so I tried converting the DXF file to another type, OBJ I think, then opened that with DE and reduced the terrain mesh. After doing this, I was finally able to obtain acceptable results at 90% reduction.
          • charly2008C
            charly2008
            I have a additional question to the downloaded SRTM. For what purpose is served by the tagged files. Thanks in advance.
            Charly
            • nokluN
              noklu
              I have used Global Mapper quite a bit to generate contours for import to SU. The largest I have done was about 2000 acres. You may want to play with the contour interval to speed up SU. I generated a terrain model with 2' contours on 2000 ac. SU ran all night. When It was complete, I had to zoom WAY back (really far). Good Luck, sounds like a cool project.
              • 6 / 6
