    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 510.9k Views 172 Watching
    • P
      Pierreden
      Thanks for the replies everyone!
      @pixero/thomthom/pugz: This is a brilliant idea. This wont be first priority, but will look into it after bug fixes and the mac issues 👍
      @oxero/driven: Thank you! Will look at it and hope to release a fix later today (saturday)
      @didier/dbalex/gaonirico: Looks like the textures isnt applied to the material... Are you using SU8 (im actually not sure if this is an requirement)? Mac Windows? Any console messages when you start a new model and then starts the plugin?
      Thank you for your patience and coops everyone!
      Peace
      Pierre
      • Didier BurD
        Didier Bur
        Hi Pierreden,
        @didier/dbalex/gaonirico: Are you using SU8 (im actually not sure if this is an requirement)? Mac Windows? Any console messages when you start a new model and then starts the plugin?
        I'm using SU8 Pro on Windows XP and 7. No console message at startup.
        Maybe there's a problem within the Pdn Materials class/module ?
        Keep on the good work !
        Regards
        DB
        • G
          gaonirico
          Hi Pierreden. I am using SU8 on Windows 7. Not appears me messages of console when beginning.
            dbalex
            same as the others: sketchup 8 and windows 7, Thanks for your work on this one, it's getting better and better!
            http://www.bocostudio.com
            • F
              function
              I like how fast the plugin is already developing, thanks for the hard work.
              Any reason Ivy keeps growing on all my unresolved design spots? Maybe a bug
              • P
                pibuz
                What a wonderful plugin! I always wanted to grow some ivy directly into SketchUp!!! Thank you Pierre!
                I'm here to report strange behaviours too: when I call the Ivy menu, the SkIndigo material panel is opened too (sketchup to Indigo plugin). Also, as some others noted, I can't see any textures applied to the geometry.
                I'm running on WinXP and SketchUp7.
                WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
                • B
                  Ben Ritter
                  Thank you Pierre!
                  • soloS
                    Is it just me or does everyone have a problem with JPP now? When I delete the Ivy plugin then JPP works, with Ivy it hangs.
                    • 66searcher6
                      66searcher
                      @Pierreden: 👍
                      ...when i select it from plugins sub-menu nothings appear(no menu) & selection(mouse left button) stops working ,and it can't be deactivate from plugins sub-menu.until i select a tool from toolbar..and then it makes it deactivate!
                      it's a complicated situation that i can't explain in better way ! 😒
                      http://hamidtoliat.deviantart.com/
                      • G
                        gaonirico
                        It happens me the same thing that 66searcher. It can be a conflict with other plugins
                        • soloS
                          Actually it's a combination of three plugins, e-onlumenrt.rb seems to mess with ivy, ivy and lumenrt mess with JPP, however if I remove lumenrt then ivy and JPP work.... strange.
                          • P
                            Pierreden
                            @66searcher/gaonirico: Thats not good. Uploaded a new fix (0.5.1). test it out.
                            @solo: Thats very weird. The only thing i can think of is that LumenRT adds an observer to something. Checked out JPP's source and cant find any sheared namespaces or anything.... Any suggestions?
                            • soloS
                              It's lumenrt that's the culptrit. no problems now that I deleted it.
                              I reported this to them on the e-on software beta forum.
                              • G
                                gaonirico
                                I uninstalled the previous version and installed the update but follows without functioning
                                • P
                                  Pierreden
                                  Any messages in the ruby console?
                                  • G
                                    gaonirico
                                    Error: #<IOError: Invalid component file>
                                    C:/Program Files/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb:298:in load' C:/Program Files/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb:298:in load_definitions'
                                    C:/Program Files/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb:10:in initialize' C:/Program Files/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb:342:in new'
                                    C:/Program Files/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb:298:in `call'
                                    • P
                                      Pierreden
                                      Try the new file (0.5.2) 👍
                                      • G
                                        gaonirico
                                        Yeah, it working fine now... Thanks Pierreden, million thanks
                                        • G
                                          gaonirico
                                          The proof that works well:
                                          • G
                                            gaonirico
                                            Mnn, maybe two errors: the first
                                            quietly_force_sync_mats_cb just calledquietly_force_sync_mats_cb just calledquietly_force_sync_mats_cb just calledquietly_force_sync_mats_cb just calledquietly_force_sync_mats_cb just calledquietly_force_sync_mats_cb just calledquietly_force_sync_mats_cb just calledquietly_force_sync_mats_cb just calledquietly_force_sync_mats_cb just calledquietly_force_sync_mats_cb just calledERROR: skpHelperClasses.rb:updateSkpMaterial, unable to find a material called: Ivyleaf_21
                                            ... the second and but notable is that not takes me the changes of parameters in the menu
                                            • 36
                                            • 37
                                            • 5 / 37
