    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 511.0k Views 172 Watching
      driven
      hi Pierreden,
      I finally got the dialog to stay open on mac, which then allows for console errors to show.
      Error: #<NoMethodError: undefined method face' for nil:NilClass> /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SIvy/LiveIvy_tool.rb:45:in onLButtonDown'
      Error: #<NoMethodError: undefined method valid?' for nil:NilClass> /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SIvy/LiveIvy_tool.rb:73:in draw'
      hope this helps
      • Didier BurD
        Didier Bur
        Is it me or something went wrong: after finishing the ivy, I'm getting 2 black materials 'Ivy_stem' (no texture) and 'Ivy_leaf' (no texture too) and that is not used on leaves ?
        DB
          dbalex
          I have the same results.. black stem texture and default texture on the leaves.
          http://www.bocostudio.com
          • G
            gaonirico
            Me too. Without textures and black faces
            Ruby console
            • P
              Pierreden
              Thanks for the replies everyone!
              @pixero/thomthom/pugz: This is a brilliant idea. This wont be first priority, but will look into it after bug fixes and the mac issues šŸ‘
              @oxero/driven: Thank you! Will look at it and hope to release a fix later today (saturday)
              @didier/dbalex/gaonirico: Looks like the textures isnt applied to the material... Are you using SU8 (im actually not sure if this is an requirement)? Mac Windows? Any console messages when you start a new model and then starts the plugin?
              Thank you for your patience and coops everyone!
              Peace
              Pierre
              • Didier BurD
                Didier Bur
                Hi Pierreden,
                @didier/dbalex/gaonirico: Are you using SU8 (im actually not sure if this is an requirement)? Mac Windows? Any console messages when you start a new model and then starts the plugin?
                I'm using SU8 Pro on Windows XP and 7. No console message at startup.
                Maybe there's a problem within the Pdn Materials class/module ?
                Keep on the good work !
                Regards
                DB
                • G
                  gaonirico
                  Hi Pierreden. I am using SU8 on Windows 7. Not appears me messages of console when beginning.
                    dbalex
                    same as the others: sketchup 8 and windows 7, Thanks for your work on this one, it's getting better and better!
                    • F
                      function
                      I like how fast the plugin is already developing, thanks for the hard work.
                      Any reason Ivy keeps growing on all my unresolved design spots? Maybe a bug
                      • P
                        pibuz
                        What a wonderful plugin! I always wanted to grow some ivy directly into SketchUp!!! Thank you Pierre!
                        I'm here to report strange behaviours too: when I call the Ivy menu, the SkIndigo material panel is opened too (sketchup to Indigo plugin). Also, as some others noted, I can't see any textures applied to the geometry.
                        I'm running on WinXP and SketchUp7.
                        WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
                        • B
                          Ben Ritter
                          Thank you Pierre!
                          • soloS
                            Is it just me or does everyone have a problem with JPP now? When I delete the Ivy plugin then JPP works, with Ivy it hangs.
                            • 66searcher6
                              66searcher
                              @Pierreden: šŸ‘
                              ...when i select it from plugins sub-menu nothings appear(no menu) & selection(mouse left button) stops working ,and it can't be deactivate from plugins sub-menu.until i select a tool from toolbar..and then it makes it deactivate!
                              it's a complicated situation that i can't explain in better way ! šŸ˜’
                              http://hamidtoliat.deviantart.com/
                              • G
                                gaonirico
                                It happens me the same thing that 66searcher. It can be a conflict with other plugins
                                • soloS
                                  Actually it's a combination of three plugins, e-onlumenrt.rb seems to mess with ivy, ivy and lumenrt mess with JPP, however if I remove lumenrt then ivy and JPP work.... strange.
                                  • P
                                    Pierreden
                                    @66searcher/gaonirico: Thats not good. Uploaded a new fix (0.5.1). test it out.
                                    @solo: Thats very weird. The only thing i can think of is that LumenRT adds an observer to something. Checked out JPP's source and cant find any sheared namespaces or anything.... Any suggestions?
                                    • soloS
                                      It's lumenrt that's the culptrit. no problems now that I deleted it.
                                      I reported this to them on the e-on software beta forum.
                                      • G
                                        gaonirico
                                        I uninstalled the previous version and installed the update but follows without functioning
                                        • P
                                          Pierreden
                                          Any messages in the ruby console?
                                          • G
                                            gaonirico
                                            Error: #<IOError: Invalid component file>
                                            C:/Program Files/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb:298:in load' C:/Program Files/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb:298:in load_definitions'
                                            C:/Program Files/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb:10:in initialize' C:/Program Files/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb:342:in new'
                                            C:/Program Files/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb:298:in `call'
                                            With your input, this post could be even better šŸ’—
                                            • 36
                                            • 37
                                            • 5 / 37
