    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 510.9k Views 172 Watching
      @pixero said:
      Any chance of using existing components as leaves (preferable several different simultaneously) as a compliment to the "built in"?
      +1
      • pugz1983P
        pugz1983
        @thomthom said:
        +1
        yes, this would be a welcome adittion to the plugin. Like in the component spray plugin. The textures that come with the original Ivy Generator Script have a young and old leaf texture. These can be used to make components.
        Greetz Pugz
        • OxerO
          Oxer
          Thanks Pierreden for your efforts!! 👍
          Nothing in the Ruby Console. I'll try to uninstall others plugins perhaps there is an incompatible plugin.
          EDIT:
          I have probed to uninstall all the plugins but it happen the same, the SketchupIvy window appears and disappears immediately.
            driven
            hi Pierreden,
            I finally got the dialog to stay open on mac, which then allows for console errors to show.
            Error: #<NoMethodError: undefined method face' for nil:NilClass> /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SIvy/LiveIvy_tool.rb:45:in onLButtonDown'
            Error: #<NoMethodError: undefined method valid?' for nil:NilClass> /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SIvy/LiveIvy_tool.rb:73:in draw'
            hope this helps
            • Didier BurD
              Didier Bur
              Is it me or something went wrong: after finishing the ivy, I'm getting 2 black materials 'Ivy_stem' (no texture) and 'Ivy_leaf' (no texture too) and that is not used on leaves ?
              DB
                dbalex
                I have the same results.. black stem texture and default texture on the leaves.
                http://www.bocostudio.com
                • G
                  gaonirico
                  Me too. Without textures and black faces
                  Ruby console
                  • P
                    Pierreden
                    Thanks for the replies everyone!
                    @pixero/thomthom/pugz: This is a brilliant idea. This wont be first priority, but will look into it after bug fixes and the mac issues 👍
                    @oxero/driven: Thank you! Will look at it and hope to release a fix later today (saturday)
                    @didier/dbalex/gaonirico: Looks like the textures isnt applied to the material... Are you using SU8 (im actually not sure if this is an requirement)? Mac Windows? Any console messages when you start a new model and then starts the plugin?
                    Thank you for your patience and coops everyone!
                    Peace
                    Pierre
                    • Didier BurD
                      Didier Bur
                      Hi Pierreden,
                      @didier/dbalex/gaonirico: Are you using SU8 (im actually not sure if this is an requirement)? Mac Windows? Any console messages when you start a new model and then starts the plugin?
                      I'm using SU8 Pro on Windows XP and 7. No console message at startup.
                      Maybe there's a problem within the Pdn Materials class/module ?
                      Keep on the good work !
                      Regards
                      DB
                      • G
                        gaonirico
                        Hi Pierreden. I am using SU8 on Windows 7. Not appears me messages of console when beginning.
                          dbalex
                          same as the others: sketchup 8 and windows 7, Thanks for your work on this one, it's getting better and better!
                          • F
                            function
                            I like how fast the plugin is already developing, thanks for the hard work.
                            Any reason Ivy keeps growing on all my unresolved design spots? Maybe a bug
                            • P
                              pibuz
                              What a wonderful plugin! I always wanted to grow some ivy directly into SketchUp!!! Thank you Pierre!
                              I'm here to report strange behaviours too: when I call the Ivy menu, the SkIndigo material panel is opened too (sketchup to Indigo plugin). Also, as some others noted, I can't see any textures applied to the geometry.
                              I'm running on WinXP and SketchUp7.
                              WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
                              • B
                                Ben Ritter
                                Thank you Pierre!
                                • soloS
                                  Is it just me or does everyone have a problem with JPP now? When I delete the Ivy plugin then JPP works, with Ivy it hangs.
                                  • 66searcher6
                                    66searcher
                                    @Pierreden: 👍
                                    ...when i select it from plugins sub-menu nothings appear(no menu) & selection(mouse left button) stops working ,and it can't be deactivate from plugins sub-menu.until i select a tool from toolbar..and then it makes it deactivate!
                                    it's a complicated situation that i can't explain in better way ! 😒
                                    http://hamidtoliat.deviantart.com/
                                    • G
                                      gaonirico
                                      It happens me the same thing that 66searcher. It can be a conflict with other plugins
                                      • soloS
                                        Actually it's a combination of three plugins, e-onlumenrt.rb seems to mess with ivy, ivy and lumenrt mess with JPP, however if I remove lumenrt then ivy and JPP work.... strange.
                                        • P
                                          Pierreden
                                          @66searcher/gaonirico: Thats not good. Uploaded a new fix (0.5.1). test it out.
                                          @solo: Thats very weird. The only thing i can think of is that LumenRT adds an observer to something. Checked out JPP's source and cant find any sheared namespaces or anything.... Any suggestions?
                                          • soloS
                                            It's lumenrt that's the culptrit. no problems now that I deleted it.
                                            I reported this to them on the e-on software beta forum.
                                            • 36
                                            • 37
                                            • 5 / 37
