    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 543.5k Views 172 Watching
    • G
      gaonirico
      Hi Pierreden. I am using SU8 on Windows 7. Not appears me messages of console when beginning.
        dbalex
        same as the others: sketchup 8 and windows 7, Thanks for your work on this one, it's getting better and better!
        http://www.bocostudio.com
        • F
          function
          I like how fast the plugin is already developing, thanks for the hard work.
          Any reason Ivy keeps growing on all my unresolved design spots? Maybe a bug
          • P
            pibuz
            What a wonderful plugin! I always wanted to grow some ivy directly into SketchUp!!! Thank you Pierre!
            I'm here to report strange behaviours too: when I call the Ivy menu, the SkIndigo material panel is opened too (sketchup to Indigo plugin). Also, as some others noted, I can't see any textures applied to the geometry.
            I'm running on WinXP and SketchUp7.
            WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
            • B
              Ben Ritter
              Thank you Pierre!
              • soloS
                Is it just me or does everyone have a problem with JPP now? When I delete the Ivy plugin then JPP works, with Ivy it hangs.
                • 66searcher6
                  66searcher
                  @Pierreden: 👍
                  ...when i select it from plugins sub-menu nothings appear(no menu) & selection(mouse left button) stops working ,and it can't be deactivate from plugins sub-menu.until i select a tool from toolbar..and then it makes it deactivate!
                  it's a complicated situation that i can't explain in better way ! 😒
                  http://hamidtoliat.deviantart.com/
                  • G
                    gaonirico
                    It happens me the same thing that 66searcher. It can be a conflict with other plugins
                    • soloS
                      Actually it's a combination of three plugins, e-onlumenrt.rb seems to mess with ivy, ivy and lumenrt mess with JPP, however if I remove lumenrt then ivy and JPP work.... strange.
                      • P
                        Pierreden
                        @66searcher/gaonirico: Thats not good. Uploaded a new fix (0.5.1). test it out.
                        @solo: Thats very weird. The only thing i can think of is that LumenRT adds an observer to something. Checked out JPP's source and cant find any sheared namespaces or anything.... Any suggestions?
                        • soloS
                          It's lumenrt that's the culptrit. no problems now that I deleted it.
                          I reported this to them on the e-on software beta forum.
                          • G
                            gaonirico
                            I uninstalled the previous version and installed the update but follows without functioning
                            • P
                              Pierreden
                              Any messages in the ruby console?
                              • G
                                gaonirico
                                Error: #<IOError: Invalid component file>
                                C:/Program Files/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb:298:in load' C:/Program Files/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb:298:in load_definitions'
                                C:/Program Files/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb:10:in initialize' C:/Program Files/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb:342:in new'
                                C:/Program Files/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb:298:in `call'
                                • P
                                  Pierreden
                                  Try the new file (0.5.2) 👍
                                  • G
                                    gaonirico
                                    Yeah, it working fine now... Thanks Pierreden, million thanks
                                    • G
                                      gaonirico
                                      The proof that works well:
                                      • G
                                        gaonirico
                                        Mnn, maybe two errors: the first
                                        quietly_force_sync_mats_cb just calledquietly_force_sync_mats_cb just calledquietly_force_sync_mats_cb just calledquietly_force_sync_mats_cb just calledquietly_force_sync_mats_cb just calledquietly_force_sync_mats_cb just calledquietly_force_sync_mats_cb just calledquietly_force_sync_mats_cb just calledquietly_force_sync_mats_cb just calledquietly_force_sync_mats_cb just calledERROR: skpHelperClasses.rb:updateSkpMaterial, unable to find a material called: Ivyleaf_21
                                        ... the second and but notable is that not takes me the changes of parameters in the menu
                                        • P
                                          Pierreden
                                          It seems like Sketchup cant find the correct material, which is "Ivyleaf_2" (it looks for "Ivyleaf_21"), or that vray looks for the wrong one. Does this happen every time you make an ivy, or does it happen on special actions? Cant recreate this myself. After completely uninstaling and reinstaling the plugin, i dont get any errors with sketchup nor with vray
                                          http://i.imgur.com/eSwjM.jpg
                                          (I appreciate your debugging very much gaonirico!!)
                                          • G
                                            gaonirico
                                            It uninstalled and installed and did not give errors with the material. In the image of the left all parameters are in 1 , in the image of the right all parameters are in 50. There is not significant changes in both cases... I am sorry if do not speak well the english language ^_^
                                            • 36
                                            • 37
                                            • 5 / 37
