    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 543.5k Views 172 Watching
    • soloS
      This is heading towards being an epic plugin...similar to what 'Fur' achieved IMo.
      • P
        Pierreden
        Thanks for the thumbs up and critics everyone!
        I have fixed solo's bug, will upload i fix later today 👍
        @oxer: This is not good. I'm really struggling with mac support. Will fix as soon as i can! Any error messages in the console?
        Thank you! Really hope its of use. When i get time i will release additional plugins based on the same principles as this one. Have working proof of concepts for Cloth, fur and a simple particle flow system, all which i hope to develop further in the long run.
        Peace
        Pierre
        • PixeroP
          Pixero
          Any chance of using existing components as leaves (preferable several different simultaneously) as a compliment to the "built in"?
            +1
            • pugz1983P
              pugz1983
              @thomthom said:
              +1
              yes, this would be a welcome adittion to the plugin. Like in the component spray plugin. The textures that come with the original Ivy Generator Script have a young and old leaf texture. These can be used to make components.
              Greetz Pugz
              • OxerO
                Oxer
                Thanks Pierreden for your efforts!! 👍
                Nothing in the Ruby Console. I'll try to uninstall others plugins perhaps there is an incompatible plugin.
                EDIT:
                I have probed to uninstall all the plugins but it happen the same, the SketchupIvy window appears and disappears immediately.
                  driven
                  hi Pierreden,
                  I finally got the dialog to stay open on mac, which then allows for console errors to show.
                  Error: #<NoMethodError: undefined method face' for nil:NilClass> /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SIvy/LiveIvy_tool.rb:45:in onLButtonDown'
                  Error: #<NoMethodError: undefined method valid?' for nil:NilClass> /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SIvy/LiveIvy_tool.rb:73:in draw'
                  hope this helps
                  • Didier BurD
                    Didier Bur
                    Is it me or something went wrong: after finishing the ivy, I'm getting 2 black materials 'Ivy_stem' (no texture) and 'Ivy_leaf' (no texture too) and that is not used on leaves ?
                    DB
                      dbalex
                      I have the same results.. black stem texture and default texture on the leaves.
                      http://www.bocostudio.com
                      • G
                        gaonirico
                        Me too. Without textures and black faces
                        Ruby console
                        • P
                          Pierreden
                          Thanks for the replies everyone!
                          @pixero/thomthom/pugz: This is a brilliant idea. This wont be first priority, but will look into it after bug fixes and the mac issues 👍
                          @oxero/driven: Thank you! Will look at it and hope to release a fix later today (saturday)
                          @didier/dbalex/gaonirico: Looks like the textures isnt applied to the material... Are you using SU8 (im actually not sure if this is an requirement)? Mac Windows? Any console messages when you start a new model and then starts the plugin?
                          Thank you for your patience and coops everyone!
                          Peace
                          Pierre
                          • Didier BurD
                            Didier Bur
                            Hi Pierreden,
                            @didier/dbalex/gaonirico: Are you using SU8 (im actually not sure if this is an requirement)? Mac Windows? Any console messages when you start a new model and then starts the plugin?
                            I'm using SU8 Pro on Windows XP and 7. No console message at startup.
                            Maybe there's a problem within the Pdn Materials class/module ?
                            Keep on the good work !
                            Regards
                            DB
                            • G
                              gaonirico
                              Hi Pierreden. I am using SU8 on Windows 7. Not appears me messages of console when beginning.
                                dbalex
                                same as the others: sketchup 8 and windows 7, Thanks for your work on this one, it's getting better and better!
                                • F
                                  function
                                  I like how fast the plugin is already developing, thanks for the hard work.
                                  Any reason Ivy keeps growing on all my unresolved design spots? Maybe a bug
                                  • P
                                    pibuz
                                    What a wonderful plugin! I always wanted to grow some ivy directly into SketchUp!!! Thank you Pierre!
                                    I'm here to report strange behaviours too: when I call the Ivy menu, the SkIndigo material panel is opened too (sketchup to Indigo plugin). Also, as some others noted, I can't see any textures applied to the geometry.
                                    I'm running on WinXP and SketchUp7.
                                    WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
                                    • B
                                      Ben Ritter
                                      Thank you Pierre!
                                      • soloS
                                        Is it just me or does everyone have a problem with JPP now? When I delete the Ivy plugin then JPP works, with Ivy it hangs.
                                        • 66searcher6
                                          66searcher
                                          @Pierreden: 👍
                                          ...when i select it from plugins sub-menu nothings appear(no menu) & selection(mouse left button) stops working ,and it can't be deactivate from plugins sub-menu.until i select a tool from toolbar..and then it makes it deactivate!
                                          it's a complicated situation that i can't explain in better way ! 😒
                                          http://hamidtoliat.deviantart.com/
                                          • G
                                            gaonirico
                                            It happens me the same thing that 66searcher. It can be a conflict with other plugins
                                            • 36
                                            • 37
                                            • 5 / 37
