    How to put a SketchUp model on a website?
    54 Posts 15 Posters 14.3k Views 15 Watching
    • soloS Offline
      How do youn install/use jquery?
      • Al HartA Offline
        Al Hart
        You just download the basic JQuery, and store it on your web server, and ink to it in the HTML, and then download the special JQuery piece you want to use.
        It took me a while to get it working the first time. But the trick to speed things up is to view the page source of their working page to see just what they used and set.
        e.g.
        <script charset='utf-8' src='http://code.jquery.com/jquery-latest.min.js' type='text/javascript'></script>
            <script charset='utf-8' src='http://code.vostrel.cz/jquery.reel-edge-bundle.js' type='text/javascript'></script>
        I'll try to make a JReel example if I get a chance.
        Al Hart
        IRender nXt from Render Plus
        • soloS Offline
          That sounds like this:
          你刚才下载的基本jQuery和存储在您的Web服务器中,以及油墨的HTML,然后下载的特殊JQuery的一块你要使用的。
          I guess I'm gonna keep looking for an easier solution.
          • Al HartA Offline
            Al Hart
            I know, it was a little scary the first time - (I used a datepicker JQuery script.
            After I make a sample, you can just download the JQuery stuff, and copy things from the sample HTML.
            Also, if we ever find a solution we like, we plan to add it to RpTools, RPS 3D PDF, and IRender nXt to generate the web pages automatically
            Al Hart
            • Al HartA Offline
              Al Hart
              @ledisnomad said:
              Al, your Javascript-only implementation is nice, too, but doesn't have the polish yet.
              Actually it is raw "Web Exporter".
              Perhaps if there is some interest, SketchUp can work on it some more.
              Al Hart
              • soloS Offline
                Thanks to Focpt (Nathan) who has an iPad and took this video of the rotation thingy-majiggy for Wired Magazine.
                Liam would need to find a stopping point (busy bastard), log onto SCF and explain how he used my images to create this.
                [flash=700,500:ncd100sp]http://www.youtube.com/v/tyxHSBd9bCg&feature=youtu.be[/flash:ncd100sp]
                I modeled it with Sketchup and rendered it with Thea, 120 renders each model at 30 degree increments.
                  d12dozr
                  👍 That's cool!
                  http://goo.gl/f7ooYh
                    Jim
                    Google's Swivel Viewer is open-source here - it is the same (I think) as the 3D Warehouse viewer. This is now a built-in feature of Picasa WebAlbums, also.
                    Also, here is one made for Blender, although SU could create the images instead of Blender - all that matters is the image name. I believe there are some old and new plugins (TIG's nudge orbit?) that could be made to work easily.
                      driven
                      I've been using a 'hacked' version of web exporter on my mac,
                      I made a .skp template with a scene/layer a generator I'm working on, I swap out the component and export the animation back into a hacked version of SU Web Exporter.
                      this version is rotating the camera, but I'm wanting to rotate the object normally which is why I need the layers.
                      I'm producing 192 imgs from 36 scenes
                      on the mac the choice for export allows jpg's, png's, or tif's, the examples a 800 x 454 jpg, but 1200x681 png's with transparency look great.
                      Is it possible to put up a working example here? (in an iframe)
                      ...MODEL from 3D warehouse...
                      should I make this into a plugin?
                        No, sorry, iFrame is not possible on the forums (mainly due to security reasons - technically it could be done)
                          lewislovedale
                          Great suggestion Alan Fraser, the flash script is exactly the kind of thing that i'm looking for.
                          It 'sounds' easy enough. I'm in the process of giving it a go.
                          Edit: Also, thanks so much for everyone else's responses, i didn't realise this thread had gone past the first page until i posted this so hadn't seen all the other posts - what a numpty.
                          • soloS Offline
                            Thanks Alan, I bought it and it's awesome, one question... anyone know of a good .swf editor?
                            Here is my test so far.
                            404 Not Found
                            (www.solos-art.com)
                              Rotation test works fine for me 😄
                              In definitive what is the prog used?
                              • soloS Offline
                                cool, I have not checked it with firefox, mozzilla or opera yet.
                                Here is another test page: http://www.solos-art.com/petes-blog/
                                CLICK on large image.
                                Does this effect work?
                                  d12dozr
                                  Yes, just checked Firefox - the color image goes blurry when the mask is applied...is it supposed to do that?
                                  Neat effect!
                                    lewislovedale
                                    The wheel looks really good, I'm doing the renders now to test in the flash rotation script. Two questions though, firstly, how many images do people think is best for a good balance between quality loading time? Secondly, is there a way to automatically create a number scenes to render around the same axis, or does it have to be done manually, as in render, move, render, move etc? Could it be done in SketchUp as scenes to be exported as a batch? I'm using Kerkythea if that makes an difference. Thanks again for the help so far.
                                    • soloS Offline
                                      Okay, another test. I had to reduce the frames as it got too heavy, this is 30 image rotation.
                                      404 Not Found
                                      (www.solos-art.com)
                                        driven
                                        hi solo,
                                        it's not working here, but you had something that rotated fine the other day...
                                        seems to be a couple of errors in the html?
                                        I'm seeing the actual code under the scooter for example
                                        • soloS Offline
                                          oh! 😕
                                          Does this one show correct?
                                          That's the problem I get something to work with IE, then mozilla is crap,I fix mozilla and Firefox is crap....I dunno what to do.
                                            driven
                                            I don't expect you mean to show the links...
                                            this is what looks like an error to me... links are normally more discrete. the rest of yours are...
                                            and the player shows a syntax error with simplestats.js but that may be caused by the other user modified bit...
                                            • 2 / 3
