    How to put a SketchUp model on a website?
    54 Posts 15 Posters 14.8k Views 15 Watching
    • soloS
      Nathan, they are the Och hydraulic watchbox and the Glenmorangie whiskey in mechanical case.
      I don't have an iPad so I never saw the finished product. 😞
      • B
        bjornkn
        Here's a Javascript viewer/player for objects and panoramas: http://jquery.vostrel.cz/reel
        Using js and JQuery, and it can do multi-row. Look at that Mini.
        • Al HartA
          Al Hart
          Here is a JavaScript only example: Playground
          The mouse doesn't work as well as I would like. But it will give you an idea of what is possible.
          {Edit: This example works great in IE, but it does not track the mouse smoothly in Firefox]
          Al Hart
          IRender nXt from Render Plus
          • L
            ledisnomad
            So far, the jQuery Reel Plugin is the winner, IMO. Al, your Javascript-only implementation is nice, too, but doesn't have the polish yet. I'm going to do some render tests soon and see how it works.
            • soloS
              How do youn install/use jquery?
              • Al HartA
                Al Hart
                You just download the basic JQuery, and store it on your web server, and ink to it in the HTML, and then download the special JQuery piece you want to use.
                It took me a while to get it working the first time. But the trick to speed things up is to view the page source of their working page to see just what they used and set.
                e.g.
                <script charset='utf-8' src='http://code.jquery.com/jquery-latest.min.js' type='text/javascript'></script>
                    <script charset='utf-8' src='http://code.vostrel.cz/jquery.reel-edge-bundle.js' type='text/javascript'></script>
                I'll try to make a JReel example if I get a chance.
                Al Hart
                • soloS
                  That sounds like this:
                  你刚才下载的基本jQuery和存储在您的Web服务器中,以及油墨的HTML,然后下载的特殊JQuery的一块你要使用的。
                  I guess I'm gonna keep looking for an easier solution.
                  • Al HartA
                    Al Hart
                    I know, it was a little scary the first time - (I used a datepicker JQuery script.
                    After I make a sample, you can just download the JQuery stuff, and copy things from the sample HTML.
                    Also, if we ever find a solution we like, we plan to add it to RpTools, RPS 3D PDF, and IRender nXt to generate the web pages automatically
                    Al Hart
                    • Al HartA
                      Al Hart
                      Actually it is raw "Web Exporter".
                      Perhaps if there is some interest, SketchUp can work on it some more.
                      Al Hart
                      • soloS
                        Thanks to Focpt (Nathan) who has an iPad and took this video of the rotation thingy-majiggy for Wired Magazine.
                        Liam would need to find a stopping point (busy bastard), log onto SCF and explain how he used my images to create this.
                        [flash=700,500:ncd100sp]http://www.youtube.com/v/tyxHSBd9bCg&feature=youtu.be[/flash:ncd100sp]
                        I modeled it with Sketchup and rendered it with Thea, 120 renders each model at 30 degree increments.
                          d12dozr
                          👍 That's cool!
                          http://goo.gl/f7ooYh
                            Jim
                            Google's Swivel Viewer is open-source here - it is the same (I think) as the 3D Warehouse viewer. This is now a built-in feature of Picasa WebAlbums, also.
                            Also, here is one made for Blender, although SU could create the images instead of Blender - all that matters is the image name. I believe there are some old and new plugins (TIG's nudge orbit?) that could be made to work easily.
                              driven
                              I've been using a 'hacked' version of web exporter on my mac,
                              I made a .skp template with a scene/layer a generator I'm working on, I swap out the component and export the animation back into a hacked version of SU Web Exporter.
                              this version is rotating the camera, but I'm wanting to rotate the object normally which is why I need the layers.
                              I'm producing 192 imgs from 36 scenes
                              on the mac the choice for export allows jpg's, png's, or tif's, the examples a 800 x 454 jpg, but 1200x681 png's with transparency look great.
                              Is it possible to put up a working example here? (in an iframe)
                              ...MODEL from 3D warehouse...
                              should I make this into a plugin?
                              • GaieusG
                                No, sorry, iFrame is not possible on the forums (mainly due to security reasons - technically it could be done)
                                • L
                                  lewislovedale
                                  Great suggestion Alan Fraser, the flash script is exactly the kind of thing that i'm looking for.
                                  It 'sounds' easy enough. I'm in the process of giving it a go.
                                  Edit: Also, thanks so much for everyone else's responses, i didn't realise this thread had gone past the first page until i posted this so hadn't seen all the other posts - what a numpty.
                                  • soloS
                                    Thanks Alan, I bought it and it's awesome, one question... anyone know of a good .swf editor?
                                    Here is my test so far.
                                    404 Not Found
                                    (www.solos-art.com)
                                      Rotation test works fine for me 😄
                                      In definitive what is the prog used?
                                      • soloS
                                        cool, I have not checked it with firefox, mozzilla or opera yet.
                                        Here is another test page: http://www.solos-art.com/petes-blog/
                                        CLICK on large image.
                                        Does this effect work?
                                          d12dozr
                                          Yes, just checked Firefox - the color image goes blurry when the mask is applied...is it supposed to do that?
                                          Neat effect!
                                          • L
                                            lewislovedale
                                            The wheel looks really good, I'm doing the renders now to test in the flash rotation script. Two questions though, firstly, how many images do people think is best for a good balance between quality loading time? Secondly, is there a way to automatically create a number scenes to render around the same axis, or does it have to be done manually, as in render, move, render, move etc? Could it be done in SketchUp as scenes to be exported as a batch? I'm using Kerkythea if that makes an difference. Thanks again for the help so far.
                                            • 2 / 3
