    [Plugin] Recurve
    68 Posts 24 Posters 49.0k Views 24 Watching
      Recurve Edge = Weld
      Select edges - Right click - Recurve edge
        Sorry that works not ๐Ÿ˜ฎ
        I select the 2 lines + the arc then apply Right click "Recurve Edges"
        That only explode my arc in segments!
        Nothing is welded! ๐Ÿ˜ฒ
        This plug don't work with the V6 ?
        Edit: That works for the V7 ๐Ÿ˜’
          And v8
          Is it time to upgrade? ๐Ÿ˜‰
            I have all versions but all my plugs (I am a Plug test pilot collector ๐Ÿ’š ) are on the V6! ๐Ÿ˜‰
            • simon le bonS Offline
              simon le bon
              Dear Pilou and Rich,
              You have certainly missed this discrete announcing from Freddo for his:
              Alternate directory for Plugins
              Till SU8, Sketchup relies on a 'hard-coded' location for the Plugins, which is typically in C:\Program Files\Google\Google SketchUp X\Plugins. This has tow main drawbacks:
              1. This Plugin folder being in the System area, it may be protected for write access. I have heard that schools and some companies usually have PCs where access to C:\ is disabled.
              2. The Plugin directory is attached to each version of Sketchup. So if you use several SU version, in particular for transition, you have to install and then update plugins in each application domain.
              Highlighted by me (simon)I have been using for a while now a small script to overcome this situation. My requirement was primarily to be able to have a single plugin directory where I could easily test SU6, SU7 and SU8 without updating files for each application..........
              (read next on his thread)......
              I think a lot of SketchUp users like us still use .. v6 v7 v8 (why do we keep them? that is an interesting question ๐Ÿ˜‰ ) . Maintain the plugins up to date in each SU plugin directory version is effectively confusing and tiring. So Freddo's Alternate Directory seems a good solution
              ๐Ÿ˜‰ simon.
                Not sure in this case that is this who makes fail the tool in the V6 ๐Ÿ˜„
                Waiting adivice of the author ๐Ÿ˜„
                  Diggsey
                  I'm afraid I can't find out why it doesn't work in v6 because I only have versions 7 and 8 and google only host older downloads for sketchup pro.
                  It could be that the method it uses simply doesn't work in v6. You can test this by making a curve and copying it. Explode the copy and then make it into a group and position it exactly over the original curve. Then explode the group. If you are left with a curve, the method should work.
                    Pro reverts into Free when the trial period of over.
                      I ran Recurve on SU6 - selected a set of connected edges.
                      Got the following error in the Ruby Console:
                      Error: #<NoMethodError: undefined methodbreak_edges=' for Sketchup:Module>
                      C:/Program Files (x86)/Google/Google SketchUp 6/Plugins/recurve.rb:213:in recurve' C:/Program Files (x86)/Google/Google SketchUp 6/Plugins/recurve.rb:247:in recurve_selection'
                      C:/Program Files (x86)/Google/Google SketchUp 6/Plugins/recurve.rb:361
                      C:/Program Files (x86)/Google/Google SketchUp 6/Plugins/recurve.rb:361:in call'
                      Sketchup.break_edges was added in SU7 - that's when SU started to automatically split edges. So you should be able to make a wrapper that only use these methods and still have the plugin functioning properly. Just test for Sketchup.respond_to?( :break_edges= ).
                        Free version of SU6 is here ๐Ÿ˜‰
                          I'm not even sure that using Sketchcup.break_edges=boolean has any affect inside a script...
                          It determines whether or not crossing edges formed manually will split automatically at their intersection... BUT crossing edges never split when made in code anyway ??
                            I've wondered that myself! I find it confusing when making edges via the API, some times they seems to split - some times not. ๐Ÿ˜•
                              Diggsey
                              I've updated the first post with a new version which will work with SketchUp 6.
                                Many thanks! You rocks ๐Ÿ‘
                                • jeff hammondJ Offline
                                  hey diggsey
                                  i'm curious about what angle you have the cut-off(?) set to when using 'select curve' (for instance, you can't use select curve on one side of a square and have the whole thing select)
                                  i like that it acts the way it does but would like to know the # just so i have an idea of it.
                                  i also use TT's select tool which will select everything regardless of angle until it hits a 3-way junction which comes in handy as well depending on the situation..
                                  like i said though -- i'm just curious
                                  not asking you to change anything etc. ๐Ÿ˜„
                                  thanks
                                    Diggsey
                                    It uses an angle of 1 radian (~57 degrees) as the cut-off.
                                      ok, back again ๐Ÿ˜„
                                      so i found some discrepancies with the plugin.. i'm not sure if this behavior is desired by you (or anyone else?) but to me, i feel like recurve should work in all 5 of these instances:
                                      i hope this file is understandable -- i'm pretty sure it's at least 5x more understandable than if i were to try to type an explanation ๐Ÿ™‚
                                      so would you agree that all cases shown there should recurve? (or, if it's desired behavior, can you fill me in on the type of situation where it would be wanted?)
                                      thanks for looking at it..
                                        Diggsey
                                        I see what you mean. It seems that if you have two softened edges on the same side that it won't recurve properly. There is some code which divides the curve up if it intersects a hard edge, so maybe that's what's causing the problem. I'll have to look into it.
                                          Diggsey
                                          I've fixed the bug. It happened when faces touched the curve at just a corner. The code needs to do something for each face touching the curve, and it used to find all the faces connected to all the edges in the curve. Now it finds all the faces connected to all the vertices in the curve instead.
                                            awesome. thank you!
                                            [and i hope i'm not coming across as a pest ๐Ÿ˜„.. it's just that i'm really into this plugin and will be using it very often]
                                            • 3 / 4
