    [Plugin] Recurve
    68 Posts 24 Posters 51.2k Views 24 Watching
      Diggsey
      I've updated the first post with a new version which will work with SketchUp 6.
        Many thanks! You rocks πŸ‘
        • jeff hammondJ Offline
          hey diggsey
          i'm curious about what angle you have the cut-off(?) set to when using 'select curve' (for instance, you can't use select curve on one side of a square and have the whole thing select)
          i like that it acts the way it does but would like to know the # just so i have an idea of it.
          i also use TT's select tool which will select everything regardless of angle until it hits a 3-way junction which comes in handy as well depending on the situation..
          like i said though -- i'm just curious
          not asking you to change anything etc. πŸ˜„
          thanks
            Diggsey
            It uses an angle of 1 radian (~57 degrees) as the cut-off.
              ok, back again πŸ˜„
              so i found some discrepancies with the plugin.. i'm not sure if this behavior is desired by you (or anyone else?) but to me, i feel like recurve should work in all 5 of these instances:
              i hope this file is understandable -- i'm pretty sure it's at least 5x more understandable than if i were to try to type an explanation πŸ™‚
              so would you agree that all cases shown there should recurve? (or, if it's desired behavior, can you fill me in on the type of situation where it would be wanted?)
              thanks for looking at it..
                Diggsey
                I see what you mean. It seems that if you have two softened edges on the same side that it won't recurve properly. There is some code which divides the curve up if it intersects a hard edge, so maybe that's what's causing the problem. I'll have to look into it.
                  Diggsey
                  I've fixed the bug. It happened when faces touched the curve at just a corner. The code needs to do something for each face touching the curve, and it used to find all the faces connected to all the edges in the curve. Now it finds all the faces connected to all the vertices in the curve instead.
                    awesome. thank you!
                    [and i hope i'm not coming across as a pest πŸ˜„.. it's just that i'm really into this plugin and will be using it very often]
                      a necessary pest πŸ˜‰
                        davidheim1
                        Does the plug-in work with Mac OS? When I download the file, I get the code, not the usual files or folders.
                          that's something to do with your browser maybe ?.. (though this does happen to me when i get rubies from crai but not when getting them from scf (using safari btw)
                          right-click the download link and choose 'download linked file' (or something worded similarly) then the .rb should come in normal..
                            mcpcorey
                            Diggsey,
                            I just wanted to say: THANK YOU, THANK YOU, for this plug in. In the relatively short time since I have started using it, it has saved me countless hours of frustration !.. I would have to say, (at least for the way I model) that this is probably the most useful, and time/frustration, saving plugin, that I have used to date.
                            And a general shout out to all of you here that take the time to write, and share, such useful scripts!... You are way smarter than me, and you all deserve many accolades.. I don't know how I would get by without you all !
                            Thanks Again !
                            • W Offline
                              Whaat
                              Hey Diggsey,
                              This looks like a great plugin. However, it doesn't seem to have the feature that I am most interested in.
                              What would be very useful to me is if you could select two edges anywhere in a mesh and the plugin would try to find the shortest edge path in between them. A tool interface would be nice. You first select a single edge. Then, hold down 'shift' and click on another edge and all of the edges in between would be selected.
                              This is actually the next plugin I was planning on writing but I haven't had the time to work on it yet. Is there any chance you could add this feature to your plugin?
                                see this thread for ideas πŸ’š
                                404 Not Found
                                (forums.sketchucation.com)
                                (there's a video in the first post showing some sweet selecting)
                                  Tgi3D Amorph has a funky selection tool
                                  [flash=800,600:32tsmsqq]http://www.youtube.com/v/-0lmatxjuJM[/flash:32tsmsqq]
                                    doesn't that plugin cost like 5 million dollars or something?
                                      $150 for 2 licences.
                                      Ramps for XGames cost 5 million bucks πŸ˜‰
                                        bogmusic
                                        Yo Diggsey
                                        Superb tool - thanks
                                        I will give more feedback when the work pressure drops a bit 😞
                                          MartinK
                                          Great plugin. Thanks. πŸ‘
                                            leminilab
                                            I should have thanked you sooner for this great plugin... β˜€
                                            Now I'm being punished... πŸ‘Ώ
                                            I use it quite often but it seems not to work anymore... I can't see the plugin upon right clicking or in the System Preferences/Extensions...
                                            At least not with the 8.0.15158 (nice name for a version by the way... πŸ˜’ )
                                            I think I could live without Recurving but I really got used to it now... I'm kind of hooked... πŸ˜•
                                            Thanks a lot wor your plugin anyway! πŸ‘
                                            • "Live every day as if it were your last and then some day you'll be right."
                                            • "ThomThom rules!!!"
                                            • 3 / 4
