    [Plugin] Recurve
    68 Posts 24 Posters 51.2k Views 24 Watching
      @diggsey said:
      Yes, currently it only makes curves not arcs. The reverse curve command basically explodes the curve and then calls recurve on it in the opposite direction, so the arc information is lost in the process. I could try changing recurve so that it detects if the sequence of edges makes a perfect arc.
      why not just detect if you are exploding an arc?
        Diggsey
        That doesn't help solve the problem I mentioned though. The only way I know of to create an arc in sketchup is with Entities.add_arc, which is functionally equivalent to the arc tool. Arcs created by dividing another arc in two cannot be made this way. I would have to know the exact sequence of events which happened to create the arc in the first place to recreate it in the opposite direction.
        • utilerU Offline
          utiler
          @dedmin said:
          I see - thanks for the explanation. Just noticed this and wanted to be sure it is not a bug.
          What is the difference? I thought an arc was a curve..... ๐Ÿ˜ฒ
          Just Curious...
            An 'Arc' IS a 'Curve'... BUT a 'Curve' is NOT necessarily an 'Arc'...
            Also remember that 'Circles' [a special 'Arc' that's 360 degrees] and 'Polygons' are also types of 'Curve' - as is any bound-set-of-edges that has been made as a 'Curve' [e.g. a Bezier Curve or a 'Welded' Curve made from edges]...........
            • jeff hammondJ Offline
              probably my oldest plugin request has finally happened ๐Ÿ˜„
              weld with no dialog boxes.
              a few suggestions (if you're open to it, of course)
              say i have two lines with an arc fillet connecting them and i'd like to make them all a single polyline (ie- something i do a lot with weld.rb), the recurve function won't work (or it doesn't appear in the context menu).. in order to recurve that scenario, i have to first explode the arc (or any polyline segments) prior to being able to recurve.
              it'd be nice if i could weld a combination of edges/lines with curves (or arcs,polylines,etc.. what ever you want to call them ๐Ÿ˜„) using recurve.
              there's also a bit of weirdness in there as far as 'select curve' goes.. using the same scenario as above, if i right click on the arc fillet then the 'select curve' option doesn't show up.. but, if i right-click on either of the lines then 'select curve' does show up and if i choose it, all parts including the arc will be selected.
              and taking that a step further, it'd be nice to have an option for 'select curve then recurve' (or whatever) so i could select a bunch of broken segments and weld them together in one operation..
              ultimately, this will definitely replace weld for me as my W shortcut and the last request would be assigned to โ‡งW .
              thanks a bunch!
                kyyu
                I never liked the 2 dialog boxes, either. Always answered "no". So I commented they out, in my modified version. ๐Ÿ˜Ž
                  mmscanlo
                  Super helpful, thanks for sharing ๐Ÿ˜„
                  • utilerU Offline
                    utiler
                    Thanks TIG.... ๐Ÿ‘
                    Just Curious...
                      Diggsey
                      Just updated the first post with update 1.3. It includes the changes suggested by Jeff.
                      • mitcorbM Offline
                        mitcorb
                        Thanks, Diggsey:
                        I just downloaded it to give it a try.
                          Really like this plugin.
                          One suggestion is that the context-menu 'Select Only' is changed as it is already used by Thomthom's Selection Tools. So I've 2 'Select Only' options.
                          Maybe all menu items under 'Recurve'
                            Diggsey
                            I've uploaded a new version. It behaves the same as the last version, but if you open it in notepad you can change the line:
                            RECURVE_ALL_UNDER_RECURVE_MENU = false
                            to:
                            RECURVE_ALL_UNDER_RECURVE_MENU = true
                            That will put the Select Only menu under the Recurve menu.
                              Thank you ๐Ÿ‘
                                wow! that's great.
                                it's been added to my shortcuts and has replaced my most used ruby.. so long good friend (weld) ๐Ÿ˜„
                                [btw - the 'select curve and recurve' (โ‡งW) seems like magic ๐Ÿ˜„]
                                thanks so much!
                                  Ben Ritter
                                  Thank you Diggsey.
                                    does this perform the same function as weld?
                                    yes and much more
                                    Sorry but I miss something ๐Ÿ˜ณ ๐Ÿ˜ณ ๐Ÿ˜ณ
                                    Where is the function "weld" or similar in this plug?
                                    How weld this with it?
                                      Recurve Edge = Weld
                                      Select edges - Right click - Recurve edge
                                        Sorry that works not ๐Ÿ˜ฎ
                                        I select the 2 lines + the arc then apply Right click "Recurve Edges"
                                        That only explode my arc in segments!
                                        Nothing is welded! ๐Ÿ˜ฒ
                                        This plug don't work with the V6 ?
                                        Edit: That works for the V7 ๐Ÿ˜’
                                          And v8
                                          Is it time to upgrade? ๐Ÿ˜‰
                                            I have all versions but all my plugs (I am a Plug test pilot collector ๐Ÿ’š ) are on the V6! ๐Ÿ˜‰
                                            • 2 / 4
