    [Plugin] Recurve
    68 Posts 24 Posters 52.0k Views 24 Watching
    • utilerU
      utiler
      @dedmin said:
      I see - thanks for the explanation. Just noticed this and wanted to be sure it is not a bug.
      What is the difference? I thought an arc was a curve..... ๐Ÿ˜ฒ
      Just Curious...
        An 'Arc' IS a 'Curve'... BUT a 'Curve' is NOT necessarily an 'Arc'...
        Also remember that 'Circles' [a special 'Arc' that's 360 degrees] and 'Polygons' are also types of 'Curve' - as is any bound-set-of-edges that has been made as a 'Curve' [e.g. a Bezier Curve or a 'Welded' Curve made from edges]...........
        • jeff hammondJ
          probably my oldest plugin request has finally happened ๐Ÿ˜„
          weld with no dialog boxes.
          a few suggestions (if you're open to it, of course)
          say i have two lines with an arc fillet connecting them and i'd like to make them all a single polyline (ie- something i do a lot with weld.rb), the recurve function won't work (or it doesn't appear in the context menu).. in order to recurve that scenario, i have to first explode the arc (or any polyline segments) prior to being able to recurve.
          it'd be nice if i could weld a combination of edges/lines with curves (or arcs,polylines,etc.. what ever you want to call them ๐Ÿ˜„) using recurve.
          there's also a bit of weirdness in there as far as 'select curve' goes.. using the same scenario as above, if i right click on the arc fillet then the 'select curve' option doesn't show up.. but, if i right-click on either of the lines then 'select curve' does show up and if i choose it, all parts including the arc will be selected.
          and taking that a step further, it'd be nice to have an option for 'select curve then recurve' (or whatever) so i could select a bunch of broken segments and weld them together in one operation..
          ultimately, this will definitely replace weld for me as my W shortcut and the last request would be assigned to โ‡งW .
          thanks a bunch!
          • K
            kyyu
            I never liked the 2 dialog boxes, either. Always answered "no". So I commented they out, in my modified version. ๐Ÿ˜Ž
              mmscanlo
              Super helpful, thanks for sharing ๐Ÿ˜„
              • utilerU
                utiler
                Thanks TIG.... ๐Ÿ‘
                Just Curious...
                  Diggsey
                  Just updated the first post with update 1.3. It includes the changes suggested by Jeff.
                  • mitcorbM
                    mitcorb
                    Thanks, Diggsey:
                    I just downloaded it to give it a try.
                      Really like this plugin.
                      One suggestion is that the context-menu 'Select Only' is changed as it is already used by Thomthom's Selection Tools. So I've 2 'Select Only' options.
                      Maybe all menu items under 'Recurve'
                        Diggsey
                        I've uploaded a new version. It behaves the same as the last version, but if you open it in notepad you can change the line:
                        RECURVE_ALL_UNDER_RECURVE_MENU = false
                        to:
                        RECURVE_ALL_UNDER_RECURVE_MENU = true
                        That will put the Select Only menu under the Recurve menu.
                          Thank you ๐Ÿ‘
                          • jeff hammondJ
                            wow! that's great.
                            it's been added to my shortcuts and has replaced my most used ruby.. so long good friend (weld) ๐Ÿ˜„
                            [btw - the 'select curve and recurve' (โ‡งW) seems like magic ๐Ÿ˜„]
                            thanks so much!
                            • B
                              Ben Ritter
                              Thank you Diggsey.
                                does this perform the same function as weld?
                                yes and much more
                                Sorry but I miss something ๐Ÿ˜ณ ๐Ÿ˜ณ ๐Ÿ˜ณ
                                Where is the function "weld" or similar in this plug?
                                How weld this with it?
                                  Recurve Edge = Weld
                                  Select edges - Right click - Recurve edge
                                    Sorry that works not ๐Ÿ˜ฎ
                                    I select the 2 lines + the arc then apply Right click "Recurve Edges"
                                    That only explode my arc in segments!
                                    Nothing is welded! ๐Ÿ˜ฒ
                                    This plug don't work with the V6 ?
                                    Edit: That works for the V7 ๐Ÿ˜’
                                      And v8
                                      Is it time to upgrade? ๐Ÿ˜‰
                                        I have all versions but all my plugs (I am a Plug test pilot collector ๐Ÿ’š ) are on the V6! ๐Ÿ˜‰
                                        • simon le bonS
                                          simon le bon
                                          Dear Pilou and Rich,
                                          You have certainly missed this discrete announcing from Freddo for his:
                                          Alternate directory for Plugins
                                          Till SU8, Sketchup relies on a 'hard-coded' location for the Plugins, which is typically in C:\Program Files\Google\Google SketchUp X\Plugins. This has tow main drawbacks:
                                          1. This Plugin folder being in the System area, it may be protected for write access. I have heard that schools and some companies usually have PCs where access to C:\ is disabled.
                                          2. The Plugin directory is attached to each version of Sketchup. So if you use several SU version, in particular for transition, you have to install and then update plugins in each application domain.
                                          Highlighted by me (simon)I have been using for a while now a small script to overcome this situation. My requirement was primarily to be able to have a single plugin directory where I could easily test SU6, SU7 and SU8 without updating files for each application..........
                                          (read next on his thread)......
                                          I think a lot of SketchUp users like us still use .. v6 v7 v8 (why do we keep them? that is an interesting question ๐Ÿ˜‰ ) . Maintain the plugins up to date in each SU plugin directory version is effectively confusing and tiring. So Freddo's Alternate Directory seems a good solution
                                          ๐Ÿ˜‰ simon.
                                            Not sure in this case that is this who makes fail the tool in the V6 ๐Ÿ˜„
                                            Waiting adivice of the author ๐Ÿ˜„
                                            • 2 / 4
