    [Plugin] Voxelize - Updated 2011-04-04
    48 Posts 21 Posters 64.7k Views 21 Watching
    • Dan RathbunD Offline
      Dan Rathbun
      @thedro said:
      I'll probably release a new version tonight that calculates the position of the cubes MUCH faster.
      It is customary (here at SCF,) to replace the file in the first post of the topic, with the new version, and then edit the topic title (which only you can do because you "own" the topic,) to reflect the revision date.
      Example revised topic title:
      "[Plugin] Voxelize - Updated 2011-03-24"
      *** standard date format for Ruby is YYYY-MM-DD**
      Then you can slide all the way down to the bottom of the webpage, and click the "Bump" link to bring the topic to the top of the forum list (without needing to post a new message.)
      After you do that, I'll remove my version 1a and put a link back to the first post.
      I'm not here much anymore.
      • 2 Offline
        22curious
        spread out the cubes...double click on one...use scaling tool to shrink it.
        This is where that Homer [doh] audio plugin button comes in handy. Of course!
        'Wearing too many hats, my SKU skills are SKrUsty...
        As for the plane slicing
        My need may be met using asteronimo's SliceModeler.rb "plugin that slices a solid 3d model along 2 axes, f.i. an X- and a Z-axis." SliceModeler.rb is based on Tig's Slicer.rb (that isn't on the plugins list? but found at http://forums.sketchucation.com/viewtopic.php?f=180&t=10413&p=68825&hilit=slicer.rb#p688). I'm checking SliceModeler and Voxelize out now!
        ...another path may be combining a lattice>>cutting component>>Tig's Hole punching Tool.
          Dan Rathbun
          Made a few changes for you Andrew:
          • properly module wrapped the plugin.
          • cube size is remembered during session in var @@cube_size
          • made it easier to control menu with constants defined at top of file
          • added validation for the menu item
          I think the "group test" should fire before the inputbox is displayed.
          But otherwise it looks good.
          Latest version now in the first post
            Gillman
            Very intesting plug-in, and practical too. I was looking for a quick way to place a repeating element on a sphere (in this case Clint Howard's ship from Star Trek TOS "The Corbomite Manuver"). I edited the cube and replaced it with a pyramid with geodesic spheres at each angle.Fesperus.jpg
            It turned what would have been a mind-numbing task into something trivial. Now all I have to do is upload it to the warehouse.
              TheDro
              @Gillman: I'm glad to hear that it was of use to you.
              @Khai: I've been looking at the structure of the .schematic file which is used to import structures into Minecraft using MCEdit. I think I've got it figured out but I still need to write the code and I'm reading the book of ruby to try and figure out the best way to do it.
              @Everyone: I've added a new "spiral" algorithm to prevent interpreting sharp edges of solids as "entrances" to the solids. Basically, I improved the algorithm to work with more solids which is good. I'll upload the new version once I'm not too busy with work/school.
              • 2 Offline
                22curious
                @TheDro, the spiral refinement will be useful - looking forward to it - thanks!
                  Khai
                  thanks Dro 😄
                  • mitcorbM Offline
                    mitcorb
                    You will discover, while scaling an instance of a component, that the others do not scale accordingly, at least while using the native scale tool.
                      Scaling one Component Instance from the 'outside' won't affect other Component Instances of the same Component BUT scaling a Component Instance's 'contents' will change all Component Instances of that Component - that's because when you edit the contents of a Component Instance you change the Component Definition itself and this is repeated across all of its Instances]...
                      • mitcorbM Offline
                        mitcorb
                        Aaah yes. Thank you. 😄
                          Lobster
                          Thanks for this,
                          Interesting plug in.
                            Is there any chance of making this work to allow selection of a component as well as a group?
                              TheDro
                              I might eventually get to adding that feature but it's hard to say when. I've been pretty busy this summer and plan to be until September so I might not get to programming any time soon. I just checked out some of the methods of components (instance and definition) and there is a "bounds" method (not found in the api documentation...) which I could use to run my script. This means it should be possible to make it work for components but I might not get to it any time soon.
                              Have a great summer 😄 .
                                Of course you could always explode the component-instance and immediately group the highlighted geometry that results... now you have a group to process...
                                  That's true, TIG. I guess for no more often than I would use the plugin, that wouldn't be too much trouble.
                                    leminilab
                                    This screams out for Sketchy Physics to drop all those cubes.
                                    👍 That's what I thought too!
                                    Can't wait to see that! 🎉
                                    • "Live every day as if it were your last and then some day you'll be right."
                                    • "ThomThom rules!!!"
                                    • O Offline
                                      octopus2
                                      Is there a way of knowing how many cubes were generated?
                                        Since the plugin creates the cubes as instances of a component, select one of them and look at the Entity Info box. It'll tell you how many there are.
                                          TheDro
                                          If you open up Window>>Ruby Console, before running the plugin, the debug information will tell you how many cubes were created, among other things. The other things are the amount of time each step takes to run. This is probably more helpful to me than to you but remember, this is still in beta 😄.
                                          • F Offline
                                            Flashhawk
                                            You are kidding me right? I mean you must kid me!! I did this by hand last week!!! I was totally not aware of your script and i made a voxelized soldier for a 3d Print project (3mm or 1/600 scale infantry) by overlaying a 3d-warehouse model with a matrix of 30x30x30 voxel and then deleting everything that was not used... (like in Michelangelos "I chipped off everything that did not look like a lion") Man i will so much use this next time!!!! Thanks alot!
                                            Flashhawk
                                            • 2 / 3
