    1st or 3rd angle projection- what's your preference?
    24 Posts 10 Posters 33.7k Views 10 Watching
      tfdesign
      But would you have laid out a 2D drawing with a front, side and plan view?
      I've seen many an architects drawing where at the bottom is the front view, above that is a top view and on the right side a side view. Do draughtsmen (people) not do that anymore? Have we been spoilt by SketchUp or do draughtsmen still use AutoCAD?
      • marvins_dadM Offline
        marvins_dad
        Okay - so this is what you are talking about.
        http://www6.district125.k12.il.us/teched/Courses/TDresources/3rd%20%26%201st%20Angle%20Proj.html
        I started off my Architectural career with a degree in drafting - we had to do those type of drawings for machine and tool making, but don't do much isometric drawings for architectural work anymore....if at all.
        I thought you were talking about building a perspective like the following.
        http://www.tpub.com/content/draftsman/14276/css/14276_277.htm
        I think some folks, for small projects, might still have a plan with a front and side elevation similar to what you are speaking of. I try not to use elevations with clients, they aren't always trained to know how to read them - that is what I use sketchup models for now.
        I still use cad...to do some work prior to bringing into sketchup - but over the years it has become easier for me to start in sketchup as well.
        My Gallery
        • W Offline
          watkins
          There is this Wiki article:
          Engineering drawing - Wikipedia
          (en.wikipedia.org)
          which is inaccurate regarding UK standards, which is third angle (also see the discussion http://en.wikipedia.org/wiki/Talk:Engineering_drawing).
          There is also this article:
          Architectural drawing - Wikipedia
          (en.wikipedia.org)
          Regards,
          Bob
            ... extract...
            First-angle projection [FR/EU] is as if the object were sitting on the paper and, from the "face" (front) view, it is rolled to the right to show the left side or rolled up to show its bottom. It is standard throughout Europe (excluding the UK) and Asia.
            First-angle projection used to be common in the UK, and may still be seen on historical design drawings, but has now fallen into disuse in favor of third-angle projection [US].
            Third-angle projection [US] is as if the object were a box to be unfolded. If we unfold the box so that the front view is in the center of the two arms, then the top view is above it, the bottom view is below it, the left view is to the left, and the right view is to the right.
            It is standard in the United Kingdom (BS 8888:2006 specifies it as the default projection system), USA (ASME Y14.3-2003 specifies it as the default projection system), and also in Canada, and Australia etc.
            In 'first-angle projection' [FR/EU], the "top" view is pushed down to the floor, and the "front" view is pushed back to the rear wall; the intersection line between these two planes is therefore closest to the large end of the cone, hence the first-angle symbol shows the cone with its large end open toward the donut.
            In 'third-angle projection' [US - and all sensible nations], the "top" view is pulled up to the ceiling, and the "front" view is pulled forward to the front wall; the intersection line between the two planes is thus closest to the small end of the cone, hence the third-angle symbol shows the cone with its large end away from the donut.
            • mitcorbM Offline
              mitcorb
              Hi, tfdesign:
              I hope this doesn't come off too abrupt or rude, because I surely do not mean it:
              I have been a licensed architect since 1989. I have not encountered the terminology in the subsequent years. In my years of education, technical drafting was never presented as a requirement. We were expected to just pick it up and learn it by doing. When I was in middle school, approximately 13 years old, I took an elective class dealing with intro to woodworking and drafting. Even then, the 3rd angle projection was never mentioned. That early exposure made it a little easier for me in college. I use Autocad every day since Version 12, which I also have never been formally trained in. As far as that goes, I have never been formally trained in Sketchup, Photoshop, the GIMP, Inkscape, Word, Excel, OpenOffice.
              In practice, we use the terms Floor Plan, Elevations, Building Sections, Wall Sections, Details. Other plans include, but are not limited to, Roof Plan, Foundation Plan, Framing Plan.
              The orientation of the Plans is in relation to the 4 points on the compass. When a site or building is skewed from due North, we provide indication of "True" North and impose a Plan North for ease of use among the disciplines who will be referring to the Construction Documents. I don't believe the Contractor/Builder knows that terminology, either.
              So that term appears to be an Engineer's treatment, and in my opinion, just serves as another layer of complication in everyday effort. Much like sheet size debacle e.g. A1, A2, B1, B2. Since I work with real measurements and space, these designations are meaningless to me. However, I know what 30x42 means, or 8 1/2 x 11 means. But I digress.
              • BoxB Offline
                @tig said:
                ... extract...
                • KrisidiousK Offline
                  Krisidious
                  I was taught Third Angle in College.
                  By: Kristoff Rand
                    mac1
                    For what it is worth. Engineering Drawing by Thomas E. French and Charles J Vierck( My old Engineering Drawing Book , 1953) states third angle is the US standard. Difference is top view is above front and right side is right while first angle is top below and left is right πŸ’š
                      tfdesign
                      @box said:
                      @tig said:
                      ... extract...
                      These are my paper cups....
                        tfdesign
                        The problem with a doughnut (torus), is that you can't differentiate between 1st and 3rd, due to the symmetry πŸ˜• πŸ˜‰
                          Note the donut 'symbol' for first and third angle projections. projection_systems.GIF This is important information for the person interpreting the drawing because in third angle projection:
                          the view from the front is in the middle
                          the view from the left is on the left
                          the view from the right is on the right
                          the view from the top is on the top
                          the view from the bottom is on the bottom
                          the view from the rear is on the far right
                          BUT with first angle projection, the view you are looking at is projected through to the other side of the object.
                          So if we are drawing the three visible sides of the object illustrated in a first angle projection, we draw the views projected on the other side of the object and not the three nearest views.first_angle3d.jpg πŸ˜’
                            Of course just writing what each view is beneath it is the idiot-proof method in case someone reads the plan as the front elevation, or the back as the front etc...
                              tfdesign
                              Did you not find me paper cup idea novel enough? 😞
                              πŸ˜‰
                                I did get the cup analogy but I wasn't sure the others would ! πŸ˜‰
                                  tfdesign
                                  πŸ˜†
                                  It's aimed at children really. But that explanation you posted is spot on.
                                  However I'm still at a slight loss how architects use projection. I'll have a look at my genius little Charlotte Baden-Powell book. See what she says. πŸ˜„
                                    "Fraser Reekie" was our draughting 'bible' - Typically for a one sheet set you drew the plan[s] in the middle of the page, with north up the sheet [as near as, keeping main walls parallel to the sheet sides], then you arranged the elevations around the plan, drawn in 3rd.ap 'drawn' onto the 'face' of the building nearest to you, rotating them so the ground was horizontal etc and they looked right... The corners of the South elevation would align with the equivalent corners of the plan. Sections were made a similar way.
                                    The elevations were named after the compass directions they faced - 'North Elevation' etc, the sections were either named after the compass direction they face e.g. 'Cross-Section Looking North', or less prone to misinterpretation by a code on the section-cut symbol itself e.g. 'Section A-A'... Larger building had plans, sections and elevations on separate sheets...
                                      tfdesign
                                      Ah- yes. I've got the Fraser Reekie one as well, although I can't seem to put my hands on it right now πŸ˜•
                                      thanks for this πŸ˜„
                                        Seraphinx
                                        @tig said:
                                        ... extract...
                                        Just wanted to say, this is... yes, I know this post is 6 years old... still though, this is the best textual description of the difference between 1st & 3rd angle projection I've ever seen. Well done! Last I knew, UK was 1st angle... sounds like my info was out of date! Great to know, thank you! Reason I came to this post, was a Canadian drawing (I'm in US)... so this was helpful in adding weight to my suspicion.
                                        It surprises me to see people w/ formal drafting training have no experience w/ these terms. That said, I admit they don't mean a lot for most people. However, the second you have international customers, these terms become amazingly important. Maybe this is less the case in architectural fields... probably less houses shipped overseas than "parts". Still, it is absolutely not an "over-complication", any more than it would be an "over-complication" to discriminate between inches and millimeters. If you assume a drawing is 3rd angle, and it's actually 1st angle, odds are, your part will be completely wrong. Vitally important. Possibly this will be less important when we stop all trade with the rest of the world. 😞
                                          Seraphinx
                                          Really, the cup analogy has pitfalls. First or Third, the right hand view will look identical, be it the hollow inside of the cup, or the bottom of the cup, both would result in a "donut" end view on either side. TRUNCATED CONE! Accept no substitutes.
