    [Plugin] [$] Artisan (1.2.3) - Feb 28, 2014
    296 Posts 95 Posters 143.3k Views 95 Watching
      "Nested object"s are when one group is inside another group or a component-definition etc...
        laucity0513
        @gus r said:
        @laucity0513 said:
        I know this is strange but I don't know why.
        I have installed this tool (15 days trial) and when I was trying to use the subdivide and smooth tool, it failed.
        There is no Iterations to be set and the geometry doesn't turn into mesh like what shown in video.
        Any idea? Thanks!
        My first question would be is it working though?
        In order to see the mesh you have to turn on hidden geometry (Top menu selection: View --> Hidden Geometry). Then:
        **1. Select the group containing your proxy geometry.
        1. Click on "Subdivide and Smooth" which will generate a default 1 iteration.
        2. Now, go back and double click on that same group and a small "Settings" window should pop up where you can set:
        a. Iterations from 1 to 4.
        b. Auto-update option checkbox.**
        Hope that helps.
        Hi, thanks for replying. What is happening now is basically nothing. I follow exactly the instruction but just nothing happen. No change to the geometry, no iteration window etc. Haha.
        Erm it probably because I am using the school computer which I don't have the admin right to install anything onto the computer. The installation might not be done properly through the Installer. I copied and paste other plugin directly to the plugin folder... they are all working fine. Probably that's the reason. Otherwise I really can't think of any reason. 😞
        • Gus RG Offline
          Gus R
          That's likely what's causing the problem. If you don't have admin rights the installation won't include required changes in the registry -- i.e. "permissions". Copying and pasting won't work -- would have to check with Whaat. Why don't you ask the administrator to install it for you and go from there.
          www.instagram.com/gusrobatto/
          www.facebook.com/gusrobatto
            laucity0513
            Ya. I think that's the problem. I am not sure if I can get the admin for help. :S It's all right. THANKS FOR ALL THE HELPS GUYS! you all are really helpful πŸ˜„
              rv1974
              @Whaat:
              There must be some kind of 'shortcut override' mode- people use arrow keys extensevely for other tools shortcuts.The same with TAB by default it used to undo viewport operations. If I'm not mistaken Thomthom made it in vertex tools.
              Another thing: After sculpting\finetuning on subsuface level I'd like my gizmo proxy to get updated but it doesn't happen.What I'm doing wrong?
                Hey John πŸ‘
                • JClementsJ Offline
                  JClements
                  Dale:
                  It would sure be nice if you could finish the videos on your site for the remaining tools.
                  πŸ˜„
                  John
                  • F Offline
                    fbartels
                    Dale,
                    Thanks so much for Artisan! A brilliant update to SDS and a wonderful addition to SketchUp. You've provided us with an amazing new set of tools. Now if Google SketchUp would only get moving and modernize the drawing engine...
                    You've single handedly reenergized my interest in SketchUp!
                    With much gratitude for your amazing work.
                    Fred
                    PS Thanks also for the upgrade pricing for those who purchased SDS.
                    • W Offline
                      Whaat
                      @rv1974 said:
                      @Whaat:
                      Sorry, I didn't realize that the arrow keys would be used as short-cut keys. I thought people 'reserved' them for modifier keys 'inside' other tools (constraining axis movement for example). I will consider allowing overrides in a future update.
                      About your other question, if you are sculpting a subsurface, the updates do not proprogate back up to the proxy. I'm afraid it doesn't work that way.
                      • W Offline
                        Whaat
                        @jclements said:
                        Dale:
                        πŸ˜„
                        John
                        Hi John,
                        My day job has been killing me lately and I haven't had time to finish the tutorials. I am now hoping to have them all done by mid-April. I might have a new one out this weekend if all goes well.
                        My apologies for the delay.
                          JClements
                          No problem Dale. I think a lot of us are getting killed by day jobs. πŸ˜„
                            Phil Rader AIA
                            Having "a day job" is a good thing considering this economy.
                            http://www.philrader.com
                              JClements
                              27 March 11
                              Hey Dale:
                              I see you have a new video on the basic Subdivide processes. Thanks!
                              • W Offline
                                Whaat
                                @jclements said:
                                27 March 11
                                Hey Dale:
                                Yes, here it is:
                                http://artisan4sketchup.com/category/documentation/
                                Make sure you subscribe to the tutorials on Youtube! More are coming!
                                  JClements
                                  Hey Dale ... again:
                                  I see you have added a couple more videos.
                                  I found the creasing video particularly helpful.
                                  John
                                    samtsham
                                    Hello everyone,
                                    I already posted this on the Artisan Support Forum six days ago, but I figure I've got better chances to get a response over here:
                                    I really enjoy Artisan and bought it right away.
                                    I ran into trouble, however. All the functions that get activated by "using the arrow keys" don't work. Unless the "arrow keys" are not the cursor keys with the arrows on them at the bottom right of my MacBook Pro keyboard, in which case I'd like to ask you to direct me to the correct keys, this makes several of Artisan's functions hard or impossible to use. I cannot sculpt "in", I can only add to the geometry, and the only option to subtract from it, apart from the inaccessible cursor control, which as of this moment does nothing, is typing "negative values +s" (-17s) in the VCB, (which I also have to use to change the radius). The convenient polarity switch by pressing both up and down arrow keys is also not available to me, leading to a lot of protracted typing, which really takes the fun out of sculpting. I also can't confine axes in Artisan, which works just fine in regular SU-use.
                                    My specs:
                                    MacBook Pro, 8GB RAM, Snow Leopard.
                                    SketchUp 8.0.4810
                                    Quite a number of essential plugins, amongst them LightUp, most of Fredo's, 1001bit, Soapskin and Bubble, Workplane Tools, Projections, Sketchy Physics and a couple more.
                                    I use a German/Austrian keyboard layout, but I already tried switching it to English/American, to no avail.
                                    Please advise. Thank you!
                                    Regards, SAM from Vienna.
                                    • W Offline
                                      Whaat
                                      @samtsham said:
                                      Hello everyone,
                                      My specs:
                                      SketchUp 8.0.4810
                                      Hi Sam,
                                      This is indeed strange. You say you are using the same arrow keys for Artisan that you are using to confine the axes for regular SketchUp use?
                                      Can I ask a question? You say you have other 3rd party plugins installed? Do any of them employ the use of the arrow keys? If so, do they work for you?
                                      Thanks (sorry for the slow reply).
                                      The contact form on the Artisan website is the quickest way to get support for Artisan.
                                        deanlegg
                                        I've been trying the crease tool
                                        If you look at the pic I want to keep the circled corners square, so I creased just the lines in the circle but it didnt work
                                        Where have I gone wrong?
                                        • boofredlayB Offline
                                          boofredlay
                                          Crease the corner, where the lines meet.
                                            kwistenbiebel
                                            I bought it and love it. Thank you Whaat!
                                            • 11
                                            • 14
                                            • 15
                                            • 9 / 15
