    [Plugin] [$] Artisan (1.2.3) - Feb 28, 2014
    296 Posts 95 Posters 143.4k Views 95 Watching
    • W Offline
      Whaat
      @charly2008 said:
      I have not yet worked with Artisan. But I find the best free alternative to generate organic forms is Sculptris and Sketchup. As far as I can judge the demonstrations is all this possible also with Sculptris. Comments are welcome, maybe I'm wrong.
      Charly
      Sculptris is a great program but like any external app, you can quickly run into workflow problems if you need to make changes to the geometry after you have already imported it into SketchUp. It is always nice to keep everything in the same application.
      Also, I don't think Sculptris is tailored very well to landscape and terrain modeling (I could be wrong). Artisan really excels at this. How would you even do this with Sculptris? For example, when modeling a real-world scene you need to have all of your references (site plan, surrounding buildings, scenery) visible to provide context as you are modeling
      Artisan also has many other tools besides sculpting that are awesome to finally have inside SketchUp (Soft selection, vertex editing, make planar, subdivision surfaces, paint brush, selection brush)
      Why not give a try for free and see what you think?
      • Gus RG Offline
        Gus R
        @laucity0513 said:
        I know this is strange but I don't know why.
        I have installed this tool (15 days trial) and when I was trying to use the subdivide and smooth tool, it failed.
        There is no Iterations to be set and the geometry doesn't turn into mesh like what shown in video.
        Any idea? Thanks!
        My first question would be is it working though?
        In order to see the mesh you have to turn on hidden geometry (Top menu selection: View --> Hidden Geometry). Then:
        **1. Select the group containing your proxy geometry.
        1. Click on "Subdivide and Smooth" which will generate a default 1 iteration.
        2. Now, go back and double click on that same group and a small "Settings" window should pop up where you can set:
        a. Iterations from 1 to 4.
        b. Auto-update option checkbox.**
        Hope that helps.
        www.instagram.com/gusrobatto/
        www.facebook.com/gusrobatto
          laucity0513
          @whaat said:
          @laucity0513 said:
          Any idea? Thanks!
          Make sure you are either first selecting faces or are selecting a group or component that contains faces (not nested groups and components)
          Also, please check for error messages in the Ruby Console (Window->Ruby Console)
          Yes. I did select faces or a group. 😞 What is nested groups?
          I draw a square, pull it up and group it, that's all. It should at least turns the cube into a sphere I guess?
            "Nested object"s are when one group is inside another group or a component-definition etc...
              laucity0513
              @gus r said:
              @laucity0513 said:
              Any idea? Thanks!
              Hope that helps.
              Hi, thanks for replying. What is happening now is basically nothing. I follow exactly the instruction but just nothing happen. No change to the geometry, no iteration window etc. Haha.
              Erm it probably because I am using the school computer which I don't have the admin right to install anything onto the computer. The installation might not be done properly through the Installer. I copied and paste other plugin directly to the plugin folder... they are all working fine. Probably that's the reason. Otherwise I really can't think of any reason. 😞
              • Gus RG Offline
                Gus R
                That's likely what's causing the problem. If you don't have admin rights the installation won't include required changes in the registry -- i.e. "permissions". Copying and pasting won't work -- would have to check with Whaat. Why don't you ask the administrator to install it for you and go from there.
                  laucity0513
                  Ya. I think that's the problem. I am not sure if I can get the admin for help. :S It's all right. THANKS FOR ALL THE HELPS GUYS! you all are really helpful πŸ˜„
                    rv1974
                    @Whaat:
                    There must be some kind of 'shortcut override' mode- people use arrow keys extensevely for other tools shortcuts.The same with TAB by default it used to undo viewport operations. If I'm not mistaken Thomthom made it in vertex tools.
                    Another thing: After sculpting\finetuning on subsuface level I'd like my gizmo proxy to get updated but it doesn't happen.What I'm doing wrong?
                    • Rich O BrienR Online
                      Hey John πŸ‘
                      • JClementsJ Offline
                        JClements
                        Dale:
                        It would sure be nice if you could finish the videos on your site for the remaining tools.
                        πŸ˜„
                        John
                        • F Offline
                          fbartels
                          Dale,
                          Thanks so much for Artisan! A brilliant update to SDS and a wonderful addition to SketchUp. You've provided us with an amazing new set of tools. Now if Google SketchUp would only get moving and modernize the drawing engine...
                          You've single handedly reenergized my interest in SketchUp!
                          With much gratitude for your amazing work.
                          Fred
                          PS Thanks also for the upgrade pricing for those who purchased SDS.
                          • W Offline
                            Whaat
                            @rv1974 said:
                            @Whaat:
                            Sorry, I didn't realize that the arrow keys would be used as short-cut keys. I thought people 'reserved' them for modifier keys 'inside' other tools (constraining axis movement for example). I will consider allowing overrides in a future update.
                            About your other question, if you are sculpting a subsurface, the updates do not proprogate back up to the proxy. I'm afraid it doesn't work that way.
                            • W Offline
                              Whaat
                              @jclements said:
                              Dale:
                              πŸ˜„
                              John
                              Hi John,
                              My day job has been killing me lately and I haven't had time to finish the tutorials. I am now hoping to have them all done by mid-April. I might have a new one out this weekend if all goes well.
                              My apologies for the delay.
                                JClements
                                No problem Dale. I think a lot of us are getting killed by day jobs. πŸ˜„
                                  Phil Rader AIA
                                  Having "a day job" is a good thing considering this economy.
                                  http://www.philrader.com
                                    JClements
                                    27 March 11
                                    Hey Dale:
                                    I see you have a new video on the basic Subdivide processes. Thanks!
                                    • W Offline
                                      Whaat
                                      @jclements said:
                                      27 March 11
                                      Hey Dale:
                                      Yes, here it is:
                                      http://artisan4sketchup.com/category/documentation/
                                      Make sure you subscribe to the tutorials on Youtube! More are coming!
                                        JClements
                                        Hey Dale ... again:
                                        I see you have added a couple more videos.
                                        I found the creasing video particularly helpful.
                                        John
                                          samtsham
                                          Hello everyone,
                                          I already posted this on the Artisan Support Forum six days ago, but I figure I've got better chances to get a response over here:
                                          I really enjoy Artisan and bought it right away.
                                          I ran into trouble, however. All the functions that get activated by "using the arrow keys" don't work. Unless the "arrow keys" are not the cursor keys with the arrows on them at the bottom right of my MacBook Pro keyboard, in which case I'd like to ask you to direct me to the correct keys, this makes several of Artisan's functions hard or impossible to use. I cannot sculpt "in", I can only add to the geometry, and the only option to subtract from it, apart from the inaccessible cursor control, which as of this moment does nothing, is typing "negative values +s" (-17s) in the VCB, (which I also have to use to change the radius). The convenient polarity switch by pressing both up and down arrow keys is also not available to me, leading to a lot of protracted typing, which really takes the fun out of sculpting. I also can't confine axes in Artisan, which works just fine in regular SU-use.
                                          My specs:
                                          MacBook Pro, 8GB RAM, Snow Leopard.
                                          SketchUp 8.0.4810
                                          Quite a number of essential plugins, amongst them LightUp, most of Fredo's, 1001bit, Soapskin and Bubble, Workplane Tools, Projections, Sketchy Physics and a couple more.
                                          I use a German/Austrian keyboard layout, but I already tried switching it to English/American, to no avail.
                                          Please advise. Thank you!
                                          Regards, SAM from Vienna.
                                          • W Offline
                                            Whaat
                                            @samtsham said:
                                            Hello everyone,
                                            My specs:
                                            SketchUp 8.0.4810
                                            Hi Sam,
                                            This is indeed strange. You say you are using the same arrow keys for Artisan that you are using to confine the axes for regular SketchUp use?
                                            Can I ask a question? You say you have other 3rd party plugins installed? Do any of them employ the use of the arrow keys? If so, do they work for you?
                                            Thanks (sorry for the slow reply).
                                            The contact form on the Artisan website is the quickest way to get support for Artisan.
                                            • 14
                                            • 15
                                            • 8 / 15
