    [Plugin][$] Tools On Surface - v2.6a - 01 Apr 24
    638 Posts 203 Posters 1.9m Views 202 Watching
      davidheim1
      i'm not quite sure how you ended up with a folder called 'ToolsOnSurface 1.6c - 15 May 10(3)' but it's not correct..
      the simplest way for you to install would be to download the installer here:
      http://web.me.com/jeffhammond/su/TOS.zip
      (this was made for someone else a little while ago.. su8 osx only)
      you'll probably want to trash the ToolsOnSurface 1.6c - 15 May 10(3) folder
      I trashed the ToolsOnSurface folder and used your installer to reinstall the program. Still no luck. Can't find the plug-in even when I restart SU 8. Does it matter that I'm using SU Pro?
      Many thanks for your help.
      dh
      • jeff hammondJ
        you might have to enable the plugin
        go sketchup-> preferences-> extensions
        and check tools on surface
        pro doesn't matter
          davidheim1
          pro doesn't matter
          Tools on Surface is enabled. But the plug-in still doesn't appear. I really don't know what to do. These fredo6 plug-ins always give me fits.
          • mitcorbM
            mitcorb
            Do you have the current LibFredo file in place, or does that matter here?
              davidheim1
              Yes. Current LibFredo file is in place. I even downloaded LibFredo Dir_34, even though I have Dir_35 installed. Arrgh!
                davidheim1
                Finally got it! The ZLoader_Onsurface.rb file needed to be pulled from the TOS folder.
                Thanks for all your help.
                dh
                • fredo6F
                  David,
                  Your unzip operation does not work properly and that's why you have problems.
                  For Tools on Surface, you should have only 4 elements in the Plugins directory:
                  • folder LIBFREDO6_Dir_35
                  • file LibFredo6.rb
                  • folder TOS_Dir_16 (and not Tools on Surface....)
                  • File ZLoader__ToolsOnSurface.rb
                  I suggest you remove all other files.
                  • fredo6F
                    NEW RELEASE: Tools on Surface 1.8a- 12 Jan 11
                    This is mostly a new release in relation with the migration to LibFredo6 3.6 and to small SU8 issues.
                    There is no functional evolution, but it is advised to upgrade when you can in order to get a better support with up-to-date code. You will also get the two-phase loading in this version.
                    You will need to migrate to LibFredo6 3.6 or higher
                    Please see main post for download
                      DIEGO-RODRIGUEZ
                      Hi Fred.
                      These days I've been using your plugins for drawing and detect some problems.
                      be possible to fix these problems?
                      Greetings, and thank you very much for all his contributions
                      [flash=800,600:3ftgvrq6]http://www.youtube.com/v/sE-FrqpMwfc&hd=1&fs=1[/flash:3ftgvrq6]
                      • H
                        Hexmeister
                        Life saving stuFF!!! ☀
                          d12dozr
                          I'm having trouble with the arc tool, the arc has some kinks in it, please see attached picture and SU file. Am I doing something wrong?
                          TOS question.skp
                          http://goo.gl/f7ooYh
                            I don't think it is you. I get it, too. Yours is selected. The ones above it show the problem to varying degrees. The one below it doesn't seem to have a problem, though. strange.
                              d12dozr
                              Yeah, it seems the problem gets worse the farther around the surface you go...I just wonder if there is a setting that I am missing or a workaround
                                d12dozr
                                Ah, fredo explains the problem in the documentation...it happens when the arc is so shallow that the centerpoint is off the surface (see attachment)
                                If anyone knows a workaround, I'd love to hear it
                                From the documentation...
                                • L
                                  lytk
                                  such an useful script, thanks for your post
                                  • dereiD
                                    derei
                                    Possible bug? TOS acts strange when I try do traw over group. It works fine on raw geometry, but on group I have strange projections. See the attachments.
                                    Tools On Surface - drawn on group
                                    Tools On Surface - drawn iniside group (on face)
                                    DESIGNER AND ARTIST DEREI.UK
                                      I didn't think it was supposed to draw on groups or components.
                                      As a work around, though, you could open the group or component and draw your lines. Then select them and use Edit>Cut. Close the group and use Edit>Paste in Place.
                                        Quite!
                                        The clue is in its name - it's NOT called Tools_on_Group or Tools_on_Instance,
                                        So just draw ON a 'Surface' not ON other things........... 😒
                                          My version doesn't draw on Groups/Components?
                                          • dereiD
                                            derei
                                            Well, it looks I just used a plugin in an inappropriate way. Do I still benefit of warranty ? 😆
                                            I promise I won't do it again! 😄
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 31
                                            • 32
                                            • 18 / 32
