    [Plugin][$] Tools On Surface - v2.6a - 01 Apr 24
    638 Posts 203 Posters 1.8m Views 202 Watching
      Ruturaj
      Thank you ,..... 😄
      Thanks,
      RuturaJ
        You can assume that most plugins work in SU8 if they worked in earlier versions. Just install and try.
          davidheim1
          Does Tools on Surface run on SU 8? I've tried to download and install it just as you described, but I can't seem to get it to appear in either the Tools menu or the Plug Ins menu, even after I restart my computer. I have the Dir 35 running on my computer. Any suggestions?
          As always, many thanks
            It works on SU8, yes.
            Exactly what location did you install it to? can you post a print screen of where you files are?
              davidheim1
              It's in the Macintosh HD/Library/Application Support/SU8/Plug-Ins. Here's a screen shot:
              • jeff hammondJ
                i'm not quite sure how you ended up with a folder called 'ToolsOnSurface 1.6c - 15 May 10(3)' but it's not correct..
                the simplest way for you to install would be to download the installer here:
                http://web.me.com/jeffhammond/su/TOS.zip
                (this was made for someone else a little while ago.. su8 osx only)
                you'll probably want to trash the ToolsOnSurface 1.6c - 15 May 10(3) folder
                  It's it the content of 'ToolsOnSurface 1.6c - 15 May 10(3)' that should be in the plugins folder?
                  • jeff hammondJ
                    that's what i was thinking as well.
                    though when i unzip the download, i'm left with a folder called ToolsOnSurface%201 which then needs to be opened to find the goodies.
                      davidheim1
                      I trashed the ToolsOnSurface folder and used your installer to reinstall the program. Still no luck. Can't find the plug-in even when I restart SU 8. Does it matter that I'm using SU Pro?
                      Many thanks for your help.
                      dh
                      • jeff hammondJ
                        you might have to enable the plugin
                        go sketchup-> preferences-> extensions
                        and check tools on surface
                        pro doesn't matter
                          davidheim1
                          pro doesn't matter
                          Tools on Surface is enabled. But the plug-in still doesn't appear. I really don't know what to do. These fredo6 plug-ins always give me fits.
                          • mitcorbM
                            mitcorb
                            Do you have the current LibFredo file in place, or does that matter here?
                              davidheim1
                              Yes. Current LibFredo file is in place. I even downloaded LibFredo Dir_34, even though I have Dir_35 installed. Arrgh!
                                davidheim1
                                Finally got it! The ZLoader_Onsurface.rb file needed to be pulled from the TOS folder.
                                Thanks for all your help.
                                dh
                                • fredo6F
                                  David,
                                  Your unzip operation does not work properly and that's why you have problems.
                                  For Tools on Surface, you should have only 4 elements in the Plugins directory:
                                  • folder LIBFREDO6_Dir_35
                                  • file LibFredo6.rb
                                  • folder TOS_Dir_16 (and not Tools on Surface....)
                                  • File ZLoader__ToolsOnSurface.rb
                                  I suggest you remove all other files.
                                  • fredo6F
                                    NEW RELEASE: Tools on Surface 1.8a- 12 Jan 11
                                    This is mostly a new release in relation with the migration to LibFredo6 3.6 and to small SU8 issues.
                                    There is no functional evolution, but it is advised to upgrade when you can in order to get a better support with up-to-date code. You will also get the two-phase loading in this version.
                                    You will need to migrate to LibFredo6 3.6 or higher
                                    Please see main post for download
                                      DIEGO-RODRIGUEZ
                                      Hi Fred.
                                      These days I've been using your plugins for drawing and detect some problems.
                                      be possible to fix these problems?
                                      Greetings, and thank you very much for all his contributions
                                      [flash=800,600:3ftgvrq6]http://www.youtube.com/v/sE-FrqpMwfc&hd=1&fs=1[/flash:3ftgvrq6]
                                      • H
                                        Hexmeister
                                        Life saving stuFF!!! ☀
                                          d12dozr
                                          I'm having trouble with the arc tool, the arc has some kinks in it, please see attached picture and SU file. Am I doing something wrong?
                                          TOS question.skp
                                          http://goo.gl/f7ooYh
                                            I don't think it is you. I get it, too. Yours is selected. The ones above it show the problem to varying degrees. The one below it doesn't seem to have a problem, though. strange.
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 31
                                            • 32
                                            • 17 / 32
