    [Plugin] Normal Map Maker
    43 Posts 21 Posters 57.7k Views 21 Watching
      @tig said:
      I've been thinking about using a jar to mimic 'make_unique' for skewed textured materials etc as exporting these with correct UV mapping to tri-faces is not possible [or at least I don't know how to do it] - the way the built-in OBJ exporter copes is to make special versions of the texture image files that have non-exportable distorted UV-maps [from skewing etc] and then use those as a non-distorted image in the OBJ code... It's relatively easy to distort the width/height of an image in java BUT skewing is more tricky - but possible... e.g. http://www.jhlabs.com/ip/distorting.html and http://www.jhlabs.com/ip/filters/index.html or http://java.sun.com/products/java-media/jai/forDevelopers/jai1_0_1guide-unc/Geom-image-manip.doc.html
      Sketchup::TextureWriter allows you to write out distorted images. If you load a face with distorted texture to the TW and write it out it'll save a modified version of it. Oddly enough, it doesn't seem to work the same way for skewed, scaled etc - then the texture is the original texture. πŸ˜•
        And it's the skewed one we want! πŸ˜’
          ah... 😳
          But a skewed texture only needs three co-ordinates - why are these troublesome for triangles?
            @thomthom said:
            ah... 😳
            But a skewed texture only needs tree co-ordinates - why are these troublesome for triangles?
            Maybe I use the wrong wording... it's textures that are somehow rotated/skewed/sheared that need four UVs ?
              Only distorted textures needs four points.
              Normal size (based on material width and height): 1 point
              Uniformly scaled: 2 points
              Non-uniformly scaled: 3 points
              Skewed - sheared: 3 points
              Distorted: 4 points
                It's distorted then - do you mean that we CAN export these already using a TW and the material's actual face front-material?
                If so, how do we 'know' a face has a 'distorted' texture as opposed to a 'skewed' or 'rotated' one ?
                Let's say I have a face with a material that has its texture distorted and some other faces use that material 'undistorted'.
                The material is exported 'undistorted' and used with most faces with the simple 3-point UV-mapping...
                I need to know how to find which face has which type of texture, then if it's distorted then export that texture as a 'variant' using the TW with the very face, and then use that image-file for that face in the exported data.
                Is this what the built-in OBJ-Exporter does when it makes distorted texture files for some faces...
                The main issue is how do I tell if a face's material's texture is 'distorted' and needs this extra step... πŸ˜•
                It would greatly improve my OBJexporter and some 3rd party tools I am involved with...
                  AcesHigh
                  sorry for the stupid question but...
                  1 - whats the advantage of normal map over bump and displacement maps (both of which can use the same grayscale bitmap)?
                  2 - VRAY doesnt use normal maps, does it?
                    http://www.spinquad.com/forums/showthread.php?4478-Normal-maps-vs.-Bump-maps&s=157424c55a8e268f44d84e57618a04cb&p=54371&viewfull=1#post54371
                    http://i192.photobucket.com/albums/z232/Z-trooper/Modelling/mappings.png
                    a) is a bump map
                    b) is a parallax/normal map
                    c) is a relief map (normal map with self shadowing)
                    Not sure what V-Ray 2 does - but the version V-Ray for SketchUp currently use doesn't.
                      tomasz
                      http://forums.sketchucation.com/viewtopic.php?f=180&t=23947&hilit=distorted&start=60#p204899
                      Author of [Thea Render for SketchUp](http://www.thearender.com/sketchup)
                      • PixeroP Offline
                        Pixero
                        A bumpmap is like: Hey, change your normal (surface direction) by this grayscale amount!
                        A normal map is more like: Yo, use this normal instead of your old one!
                          tspco
                          I just downloaded and installed this plugin, but it doesn't seem to work, I am sure I missed something, nothing shows up in the plugins menu. Anybody have a step by step?
                          SU make 2017, /Twilight Render Hobby
                          Windows 10,64 bit,16GB ram, quad core Athlon 3.6 gHz proc. Anything else you want to know, ask me.
                            RepulsiveBoy
                            It doesn't work for me either 😒
                              driven
                              hi, did you look in the right place?
                              UI.menu("File").add_item("Export normal map")
                                Didier's version says this quite clearly
                                You'll find the command under the **File** menu -> Export normal map
                                πŸ˜’
                                  Tuttlet
                                  Great to find this Normal Map script. Thanks.
                                  I found that slows down if you have the Materials Windows open to "In Model" textures. So remember to have that closed.
                                  Was there any way to get a bump map from this ruby? I found some threads relating to bump mapping in Sketchup, but nothing conclusive, unless I missed it
                                  http://forums.sketchucation.com/viewtopic.php?f=180&t=18024&start=15
                                  http://forums.sketchucation.com/viewtopic.php?f=180&t=16660&hilit=plugin
                                    You can quite easily create bump maps from (raw) geometry if you project a greyscale image from one side and then export an image from the other side.
                                    • Bob JamesB Offline
                                      Bob James
                                      Just browsing through, got interested, and don't understand your reply.
                                      project (from what onto to what?) a greyscale image from one side (of what?)
                                      export an image from the other side (of what?)
                                        Tuttlet
                                        I believe this is the procedure:
                                        1. Make a rectangle with a greyscale texture in the z direction, scale it to 1.001 to ensure the top face is white
                                        2. Make the texture a projection
                                        3. Select and apply the texture to the model
                                        4. Set the time to noon, date to 3/21, location to near the equator (in File, Geo-location). Set light & dark to 100
                                        5. With a parallel projection and no edges, the top view is your bump map
                                          You can do the same without a texture, use white Fog on black geometry.
                                            Tuttlet
                                            Hey, that's even easier. Thanks.
                                            But aren't white areas usually interpreted as higher than black. I seem to get the right result with black fog on white geometry.
                                            • 2 / 3
