    [Plugin] Toggle Units
    159 Posts 47 Posters 158.3k Views 47 Watching
    • W Offline
      watkins
      Just tried installing Toggle Units into my SU8 plugin folder, and found that the icons won't show up. Is this a known problem for SU8? If so, does anyone have a fix?
      Kind regards,
      Bob
        When you extracted the contents of the zip file you should have got a file called toggle_units.rb and a folder called toggle_units_icons which contains 24 png files to make the various buttons.
        The file and the folder both go into your Plugins folder.
        If you have copied the rb file from v7 into v8 you must also copy the whole folder and its files too... πŸ˜•
        • W Offline
          watkins
          Dear All,
          Okay, Toggle Units is now working in V8, but only after installing the version posted by 'blajnov' (page 6 of this thread, and near the top).
          Kind regards,
          Bob
            davidlouis
            Not wanting to discourage the development of great tools such as this, I can't help wonder why, so far down the line in sketchup development, you can't have one preference for modelling units and a different one for the value readout of say... areas, dimensions etc etc... CAD software has been doing this since day one...
            At the moment I model in millimeters and require dimensions and areas in meters... I've used this tool since it pretty much came but why don't the skp developers integrate this into the preferences / model info units interface...???
            Either way thanks for a great tool! πŸ‘
            Dave
            • V Offline
              vidy
              @watkins said:
              Dear All,
              Kind regards,
              Bob
              dear bob,
              do you have the icon showed up on v.8?
              still so much to learn..
              • W Offline
                watkins
                Dear Vidy,
                Yes I do, and I have checked all the functions and they work. It would be very useful if someone could update the first posting with the V8 compatible plugin.
                Regards,
                Bob
                  I have updated the first post in the thread http://forums.sketchucation.com/viewtopic.php?p=81391#p81391
                  Please use the new 'bold' version which is v6/7/8... friendly - I left the old one BUT I don't recommend that version at all...
                  • V Offline
                    vidy
                    thanks bob and tig, now it works perfectly
                      TIG,
                      I just installed the latest version but I am getting the blank toolbar. In looking through the script I see what looks like the path to the PNGs shown as below. The icon folder is called "toggle_units_icons" but I wonder if it or the script should be modified. Or maybe I'm looking in the wrong place and have a different problem.
                      cmd = UI;;Command.new(Strings["Decimal"]) { toggle_units(5) }
                      cmd.small_icon = "CD_ICONS/TWEAK/tudec16.png"
                      cmd.large_icon = "CD_ICONS/TWEAK/tudec24.png"
                        @dave r said:
                        TIG,
                        You are right πŸ˜’ - I copied the files over without looking at then [I didn't use this tool at all]
                        I've now updated the zip http://forums.sketchucation.com/viewtopic.php?p=81391#p81391 so that it has the correct folder specified for the icons !
                          Thank you, TIG. I'm amazed that I sorted out the problem correctly. I must be learning from watching you.
                            Matt666
                            Hi all.
                            Sorry for my absence, for now I don't often use SU. Thank you TIG to be here... 😳
                            Frenglish at its best !
                            My scripts
                              mag1800
                              [floatr:2nr8pix2][/floatr:2nr8pix2]Great Plugin Matt. Works great for me. Thank You.
                                Matt666
                                Hi all.
                                Plugin updated with a new tool (Toolbar manager): You can now choose icons you want to display in the toolbar.
                                Thanks to Thomthom and TIG!
                                LINK: http://forums.sketchucation.com/viewtopic.php?p=81391#p81391
                                My scripts
                                  Matt666
                                  Do not hesitate to tell me if something goes wrong... I'm new with HTML and JAVASCRIPT...
                                  My scripts
                                    driven
                                    Hi Mat,
                                    on my mac if I instal this correctly and open SU
                                    Unless, I use the manager, make a change and then quit
                                    SU actually crashes when I close a window and I get a report dialog.
                                    When I remove this ruby, everything works as it should, if put it back again problem returns.
                                    it make no difference if I use or don't use the plugin, only if it's installed.
                                    %(#BF0040)[28 com.google.sketchupfree8 0x004a9316 std::vector<CSketchUpToolbar::CToolBarItem, std::allocatorCSketchUpToolbar::CToolBarItem >::_M_insert_aux(__gnu_cxx::__normal_iterator<CSketchUpToolbar::CToolBarItem*, std::vector<CSketchUpToolbar::CToolBarItem, std::allocatorCSketchUpToolbar::CToolBarItem > >, CSketchUpToolbar::CToolBarItem const&) + 1968
                                    29 com.google.sketchupfree8 0x004aa4ab std::vector<CSketchUpToolbar::CToolBarItem, std::allocatorCSketchUpToolbar::CToolBarItem >::_M_insert_aux(__gnu_cxx::__normal_iterator<CSketchUpToolbar::CToolBarItem*, std::vector<CSketchUpToolbar::CToolBarItem, std::allocatorCSketchUpToolbar::CToolBarItem > >, CSketchUpToolbar::CToolBarItem const&) + 6469
                                    30 libCommonUtils.dylib 0x00a8538a CNotificationCenter::SendNotification(char const*, void*) + 202
                                    31 com.google.sketchupfree8 0x004c1d48 non-virtual thunk to CTool::~CTool() + 3048
                                    32 com.google.sketchupfree8 0x004c27c3 non-virtual thunk to CTool::~CTool() + 5731
                                    33 com.google.sketchupfree8 0x00008335 0x1000 + 29493]
                                      Matt666
                                      Hum Thomthom told me I had to use 'show' with windows and 'show_modal' with mac... I think this is the problem (because i completely forgot this!). I'll take a look soon thank you!
                                      My scripts
                                        driven
                                        Hi Mat,
                                        It actually seems to be something to do with the preference settings, which SU sends to the .plist on Mac.
                                        .show and .show_modal never cause crashes, it's just the dialog disappears under the main window.
                                          Matt666
                                          Hi!
                                          See first post to download new version [v2.11].
                                          • Mac bug fixed
                                          • Add tool in extensions window.
                                            Big thanks to driven for his help! πŸ‘
                                          My scripts
                                            ankitdarda
                                            thanks a lot..
                                            404 Not Found
                                            (forums.sketchucation.com)
                                            thank you !!!
                                            feel free to click on my site http://www.ankitfolio.co.cc includes my blog page link within it
                                            :sunglasses:
                                            ankitdarda
                                            • 5 / 8
