    [Plugin] Toggle Units
    159 Posts 47 Posters 163.5k Views 47 Watching
      RootlessAgrarian
      @cadfather said:
      the lines make sense if you have the corresponding folder (toggle_units_icons) in the plugins menu..
      plugins menu? or plugins directory (folder)?
      that subdir does exist in the plugins directory (as do other subdirs of small images used successfully by other Ruby extensions). can't figure out why the images are not getting associated with the buttons. but hey, the unit switching function works and that's what I needed. I can fool around with the icons later.
      Nothing is 'mere'. -- Richard Feynman
      • CadFatherC
        CadFather
        sorry.. 😳 i meant plugins folder of course..
        if the path is right the icons should show up
          RootlessAgrarian
          as I say I do not speak Ruby, but I used to be extremely literate in Tcl/Tk and the syntax is not completely alien. I have tried various things, even using the full pathname. other .rb scripts are correctly finding their icons w/rel pathname starting at 'plugins', but this one for some reason is not. mysterious! I've looked for some initialisation that might set the default path, etc -- no luck so far. must be a very silly coding error that I can't see because I'm so unfamiliar with Ruby apps.
          checked the obvious like protection bits on subdir and images, checked that they really are .pngs, checked that they are not empty files, etc. baffled.
          oh well. something to fool with when I've nothing more urgent to do πŸ˜„
          • V
            vidy
            Have the same problem here also, the function was working perfectly, but the icon are invisible.. need some advice, please...
            thanks,
            still so much to learn..
            • C
              chrisjk
              What versions of Mac OSX are you running? I have Snow Leopard and the icons do show up for me. You might need to check View>Tool Palettes>Toggle Units to see them.
              • V
                vidy
                im using xp sp2, and su 7.1, the tool actually already perfectly functional, just the icon not showed up..
                already try to change the address on the script, but it still not working. πŸ˜’
                • W
                  watkins
                  Just tried installing Toggle Units into my SU8 plugin folder, and found that the icons won't show up. Is this a known problem for SU8? If so, does anyone have a fix?
                  Kind regards,
                  Bob
                    When you extracted the contents of the zip file you should have got a file called toggle_units.rb and a folder called toggle_units_icons which contains 24 png files to make the various buttons.
                    The file and the folder both go into your Plugins folder.
                    If you have copied the rb file from v7 into v8 you must also copy the whole folder and its files too... πŸ˜•
                    • W
                      watkins
                      Dear All,
                      Okay, Toggle Units is now working in V8, but only after installing the version posted by 'blajnov' (page 6 of this thread, and near the top).
                      Kind regards,
                      Bob
                        davidlouis
                        Not wanting to discourage the development of great tools such as this, I can't help wonder why, so far down the line in sketchup development, you can't have one preference for modelling units and a different one for the value readout of say... areas, dimensions etc etc... CAD software has been doing this since day one...
                        At the moment I model in millimeters and require dimensions and areas in meters... I've used this tool since it pretty much came but why don't the skp developers integrate this into the preferences / model info units interface...???
                        Either way thanks for a great tool! πŸ‘
                        Dave
                        • V
                          vidy
                          @watkins said:
                          Dear All,
                          Kind regards,
                          Bob
                          dear bob,
                          do you have the icon showed up on v.8?
                          • W
                            watkins
                            Dear Vidy,
                            Yes I do, and I have checked all the functions and they work. It would be very useful if someone could update the first posting with the V8 compatible plugin.
                            Regards,
                            Bob
                              I have updated the first post in the thread http://forums.sketchucation.com/viewtopic.php?p=81391#p81391
                              Please use the new 'bold' version which is v6/7/8... friendly - I left the old one BUT I don't recommend that version at all...
                              • V
                                vidy
                                thanks bob and tig, now it works perfectly
                                  TIG,
                                  I just installed the latest version but I am getting the blank toolbar. In looking through the script I see what looks like the path to the PNGs shown as below. The icon folder is called "toggle_units_icons" but I wonder if it or the script should be modified. Or maybe I'm looking in the wrong place and have a different problem.
                                  cmd = UI;;Command.new(Strings["Decimal"]) { toggle_units(5) }
                                  cmd.small_icon = "CD_ICONS/TWEAK/tudec16.png"
                                  cmd.large_icon = "CD_ICONS/TWEAK/tudec24.png"
                                    @dave r said:
                                    TIG,
                                    You are right πŸ˜’ - I copied the files over without looking at then [I didn't use this tool at all]
                                    I've now updated the zip http://forums.sketchucation.com/viewtopic.php?p=81391#p81391 so that it has the correct folder specified for the icons !
                                      Thank you, TIG. I'm amazed that I sorted out the problem correctly. I must be learning from watching you.
                                        Matt666
                                        Hi all.
                                        Sorry for my absence, for now I don't often use SU. Thank you TIG to be here... 😳
                                        Frenglish at its best !
                                        My scripts
                                          mag1800
                                          [floatr:2nr8pix2][/floatr:2nr8pix2]Great Plugin Matt. Works great for me. Thank You.
                                            Matt666
                                            Hi all.
                                            Plugin updated with a new tool (Toolbar manager): You can now choose icons you want to display in the toolbar.
                                            Thanks to Thomthom and TIG!
                                            LINK: http://forums.sketchucation.com/viewtopic.php?p=81391#p81391
                                            My scripts
                                            • 5 / 8
