    [Plugin] Toggle Units
    159 Posts 47 Posters 158.3k Views 47 Watching
      chrisjk
      What versions of Mac OSX are you running? I have Snow Leopard and the icons do show up for me. You might need to check View>Tool Palettes>Toggle Units to see them.
      • V Offline
        vidy
        im using xp sp2, and su 7.1, the tool actually already perfectly functional, just the icon not showed up..
        already try to change the address on the script, but it still not working. ๐Ÿ˜’
        still so much to learn..
        • W Offline
          watkins
          Just tried installing Toggle Units into my SU8 plugin folder, and found that the icons won't show up. Is this a known problem for SU8? If so, does anyone have a fix?
          Kind regards,
          Bob
            When you extracted the contents of the zip file you should have got a file called toggle_units.rb and a folder called toggle_units_icons which contains 24 png files to make the various buttons.
            The file and the folder both go into your Plugins folder.
            If you have copied the rb file from v7 into v8 you must also copy the whole folder and its files too... ๐Ÿ˜•
            • W Offline
              watkins
              Dear All,
              Okay, Toggle Units is now working in V8, but only after installing the version posted by 'blajnov' (page 6 of this thread, and near the top).
              Kind regards,
              Bob
                davidlouis
                Not wanting to discourage the development of great tools such as this, I can't help wonder why, so far down the line in sketchup development, you can't have one preference for modelling units and a different one for the value readout of say... areas, dimensions etc etc... CAD software has been doing this since day one...
                At the moment I model in millimeters and require dimensions and areas in meters... I've used this tool since it pretty much came but why don't the skp developers integrate this into the preferences / model info units interface...???
                Either way thanks for a great tool! ๐Ÿ‘
                Dave
                • V Offline
                  vidy
                  @watkins said:
                  Dear All,
                  Kind regards,
                  Bob
                  dear bob,
                  do you have the icon showed up on v.8?
                  • W Offline
                    watkins
                    Dear Vidy,
                    Yes I do, and I have checked all the functions and they work. It would be very useful if someone could update the first posting with the V8 compatible plugin.
                    Regards,
                    Bob
                      I have updated the first post in the thread http://forums.sketchucation.com/viewtopic.php?p=81391#p81391
                      Please use the new 'bold' version which is v6/7/8... friendly - I left the old one BUT I don't recommend that version at all...
                      • V Offline
                        vidy
                        thanks bob and tig, now it works perfectly
                          TIG,
                          I just installed the latest version but I am getting the blank toolbar. In looking through the script I see what looks like the path to the PNGs shown as below. The icon folder is called "toggle_units_icons" but I wonder if it or the script should be modified. Or maybe I'm looking in the wrong place and have a different problem.
                          cmd = UI;;Command.new(Strings["Decimal"]) { toggle_units(5) }
                          cmd.small_icon = "CD_ICONS/TWEAK/tudec16.png"
                          cmd.large_icon = "CD_ICONS/TWEAK/tudec24.png"
                            @dave r said:
                            TIG,
                            You are right ๐Ÿ˜’ - I copied the files over without looking at then [I didn't use this tool at all]
                            I've now updated the zip http://forums.sketchucation.com/viewtopic.php?p=81391#p81391 so that it has the correct folder specified for the icons !
                              Thank you, TIG. I'm amazed that I sorted out the problem correctly. I must be learning from watching you.
                                Matt666
                                Hi all.
                                Sorry for my absence, for now I don't often use SU. Thank you TIG to be here... ๐Ÿ˜ณ
                                Frenglish at its best !
                                My scripts
                                  mag1800
                                  [floatr:2nr8pix2][/floatr:2nr8pix2]Great Plugin Matt. Works great for me. Thank You.
                                    Matt666
                                    Hi all.
                                    Plugin updated with a new tool (Toolbar manager): You can now choose icons you want to display in the toolbar.
                                    Thanks to Thomthom and TIG!
                                    LINK: http://forums.sketchucation.com/viewtopic.php?p=81391#p81391
                                    My scripts
                                      Matt666
                                      Do not hesitate to tell me if something goes wrong... I'm new with HTML and JAVASCRIPT...
                                      My scripts
                                        driven
                                        Hi Mat,
                                        on my mac if I instal this correctly and open SU
                                        Unless, I use the manager, make a change and then quit
                                        SU actually crashes when I close a window and I get a report dialog.
                                        When I remove this ruby, everything works as it should, if put it back again problem returns.
                                        it make no difference if I use or don't use the plugin, only if it's installed.
                                        %(#BF0040)[28 com.google.sketchupfree8 0x004a9316 std::vector<CSketchUpToolbar::CToolBarItem, std::allocatorCSketchUpToolbar::CToolBarItem >::_M_insert_aux(__gnu_cxx::__normal_iterator<CSketchUpToolbar::CToolBarItem*, std::vector<CSketchUpToolbar::CToolBarItem, std::allocatorCSketchUpToolbar::CToolBarItem > >, CSketchUpToolbar::CToolBarItem const&) + 1968
                                        29 com.google.sketchupfree8 0x004aa4ab std::vector<CSketchUpToolbar::CToolBarItem, std::allocatorCSketchUpToolbar::CToolBarItem >::_M_insert_aux(__gnu_cxx::__normal_iterator<CSketchUpToolbar::CToolBarItem*, std::vector<CSketchUpToolbar::CToolBarItem, std::allocatorCSketchUpToolbar::CToolBarItem > >, CSketchUpToolbar::CToolBarItem const&) + 6469
                                        30 libCommonUtils.dylib 0x00a8538a CNotificationCenter::SendNotification(char const*, void*) + 202
                                        31 com.google.sketchupfree8 0x004c1d48 non-virtual thunk to CTool::~CTool() + 3048
                                        32 com.google.sketchupfree8 0x004c27c3 non-virtual thunk to CTool::~CTool() + 5731
                                        33 com.google.sketchupfree8 0x00008335 0x1000 + 29493]
                                          Matt666
                                          Hum Thomthom told me I had to use 'show' with windows and 'show_modal' with mac... I think this is the problem (because i completely forgot this!). I'll take a look soon thank you!
                                          My scripts
                                            driven
                                            Hi Mat,
                                            It actually seems to be something to do with the preference settings, which SU sends to the .plist on Mac.
                                            .show and .show_modal never cause crashes, it's just the dialog disappears under the main window.
                                            • 5 / 8
