    [Plugin] Toggle Units
    159 Posts 47 Posters 163.5k Views 47 Watching
      @dave r said:
      TIG,
      I just installed the latest version but I am getting the blank toolbar. In looking through the script I see what looks like the path to the PNGs shown as below. The icon folder is called "toggle_units_icons" but I wonder if it or the script should be modified. Or maybe I'm looking in the wrong place and have a different problem.
      cmd = UI;;Command.new(Strings["Decimal"]) { toggle_units(5) }
      > cmd.small_icon = "CD_ICONS/TWEAK/tudec16.png"
      > cmd.large_icon = "CD_ICONS/TWEAK/tudec24.png"
      You are right πŸ˜’ - I copied the files over without looking at then [I didn't use this tool at all]
      I've now updated the zip http://forums.sketchucation.com/viewtopic.php?p=81391#p81391 so that it has the correct folder specified for the icons !
        Thank you, TIG. I'm amazed that I sorted out the problem correctly. I must be learning from watching you.
          Matt666
          Hi all.
          Sorry for my absence, for now I don't often use SU. Thank you TIG to be here... 😳
          Frenglish at its best !
          My scripts
            mag1800
            [floatr:2nr8pix2][/floatr:2nr8pix2]Great Plugin Matt. Works great for me. Thank You.
              Matt666
              Hi all.
              Plugin updated with a new tool (Toolbar manager): You can now choose icons you want to display in the toolbar.
              Thanks to Thomthom and TIG!
              LINK: http://forums.sketchucation.com/viewtopic.php?p=81391#p81391
              My scripts
                Matt666
                Do not hesitate to tell me if something goes wrong... I'm new with HTML and JAVASCRIPT...
                My scripts
                  driven
                  Hi Mat,
                  on my mac if I instal this correctly and open SU
                  Unless, I use the manager, make a change and then quit
                  SU actually crashes when I close a window and I get a report dialog.
                  When I remove this ruby, everything works as it should, if put it back again problem returns.
                  it make no difference if I use or don't use the plugin, only if it's installed.
                  %(#BF0040)[28 com.google.sketchupfree8 0x004a9316 std::vector<CSketchUpToolbar::CToolBarItem, std::allocatorCSketchUpToolbar::CToolBarItem >::_M_insert_aux(__gnu_cxx::__normal_iterator<CSketchUpToolbar::CToolBarItem*, std::vector<CSketchUpToolbar::CToolBarItem, std::allocatorCSketchUpToolbar::CToolBarItem > >, CSketchUpToolbar::CToolBarItem const&) + 1968
                  29 com.google.sketchupfree8 0x004aa4ab std::vector<CSketchUpToolbar::CToolBarItem, std::allocatorCSketchUpToolbar::CToolBarItem >::_M_insert_aux(__gnu_cxx::__normal_iterator<CSketchUpToolbar::CToolBarItem*, std::vector<CSketchUpToolbar::CToolBarItem, std::allocatorCSketchUpToolbar::CToolBarItem > >, CSketchUpToolbar::CToolBarItem const&) + 6469
                  30 libCommonUtils.dylib 0x00a8538a CNotificationCenter::SendNotification(char const*, void*) + 202
                  31 com.google.sketchupfree8 0x004c1d48 non-virtual thunk to CTool::~CTool() + 3048
                  32 com.google.sketchupfree8 0x004c27c3 non-virtual thunk to CTool::~CTool() + 5731
                  33 com.google.sketchupfree8 0x00008335 0x1000 + 29493]
                    Matt666
                    Hum Thomthom told me I had to use 'show' with windows and 'show_modal' with mac... I think this is the problem (because i completely forgot this!). I'll take a look soon thank you!
                    My scripts
                      driven
                      Hi Mat,
                      It actually seems to be something to do with the preference settings, which SU sends to the .plist on Mac.
                      .show and .show_modal never cause crashes, it's just the dialog disappears under the main window.
                        Matt666
                        Hi!
                        See first post to download new version [v2.11].
                        • Mac bug fixed
                        • Add tool in extensions window.
                          Big thanks to driven for his help! πŸ‘
                        My scripts
                          ankitdarda
                          thanks a lot..
                          404 Not Found
                          (forums.sketchucation.com)
                          thank you !!!
                          feel free to click on my site http://www.ankitfolio.co.cc includes my blog page link within it
                          :sunglasses:
                          ankitdarda
                            Matt666
                            πŸ˜‰
                            My scripts
                            • U
                              ultimato andy
                              where is the pluggin to download for sketchup 8? i cant find it!:(
                              • GaieusG
                                Attached to the first post of the topic (usually at the bottom)
                                  Matt666
                                  Thank you Gaieus!
                                  My scripts
                                    mirale999
                                    Great plugin~ I find it easy to switch from mm to M when just to measure the area of a plan now!
                                    paranoia is a higher form of awareness...
                                      driven
                                      Hi.
                                      I don't think it's a Lion issue... per say
                                      on the mac the MF_UNCHECKED MF_CHECKED just doesn't work to your advantage, and after a few wrong combinations, it stops switching the screen text, although console says it's working.
                                      if you run it with RC open you can see that your better off re-clicking the currently selected first, to turn the shadow off, then changing. it's a drag, but SU enabled the native buttons behavior to latch and when it also coded to latch....
                                      the mac native SU button code needs to be modified, then we can have buttons the toggles, like 'some' native SU ones that were set up correctly.
                                      as a stop gap I changed the MF_CHECKED to MF_UNCHECKED, which sightly reduces confusion.
                                      • mariochaM
                                        mariocha
                                        Well, no luck here on OS X Lion, with v 2.11
                                        Only the first 4 icons and the 2 setting the precision work; And the greyed out icons stays on when it should go out.
                                        %(#008000)[Mario C.
                                          driven
                                          no the native setting will still shadow the buttons as if selected, the light greying seems to work, until it/you gets confused,
                                          it only works on unavailable options, so maybe the fractions/decimal triggering could be modified to make it more intuitive...
                                          I just turned off Fractions and Arch and Use ENG in either metric or imperial, but with decimals only.
                                          I understand fractions, but not the use of them.... although they should run faster with binary conversions....
                                          • mariochaM
                                            mariocha
                                            Oh ! you mean the shadowing of the buttons is within SU. πŸ˜•
                                            Oh well, then I can just re-click it to make the shadow go.
                                            Here in Quebec, we are caught between 2 worlds so I have to use both Arch. and Met.
                                            %(#008000)[Mario C.
                                            • 6 / 8
