    [Plugin] Toggle Units
    159 Posts 47 Posters 158.3k Views 47 Watching
      I have updated the first post in the thread http://forums.sketchucation.com/viewtopic.php?p=81391#p81391
      Please use the new 'bold' version which is v6/7/8... friendly - I left the old one BUT I don't recommend that version at all...
      • V Offline
        vidy
        thanks bob and tig, now it works perfectly
        still so much to learn..
          TIG,
          I just installed the latest version but I am getting the blank toolbar. In looking through the script I see what looks like the path to the PNGs shown as below. The icon folder is called "toggle_units_icons" but I wonder if it or the script should be modified. Or maybe I'm looking in the wrong place and have a different problem.
          cmd = UI;;Command.new(Strings["Decimal"]) { toggle_units(5) }
          cmd.small_icon = "CD_ICONS/TWEAK/tudec16.png"
          cmd.large_icon = "CD_ICONS/TWEAK/tudec24.png"
            @dave r said:
            TIG,
            You are right πŸ˜’ - I copied the files over without looking at then [I didn't use this tool at all]
            I've now updated the zip http://forums.sketchucation.com/viewtopic.php?p=81391#p81391 so that it has the correct folder specified for the icons !
              Thank you, TIG. I'm amazed that I sorted out the problem correctly. I must be learning from watching you.
                Matt666
                Hi all.
                Sorry for my absence, for now I don't often use SU. Thank you TIG to be here... 😳
                Frenglish at its best !
                My scripts
                  mag1800
                  [floatr:2nr8pix2][/floatr:2nr8pix2]Great Plugin Matt. Works great for me. Thank You.
                    Matt666
                    Hi all.
                    Plugin updated with a new tool (Toolbar manager): You can now choose icons you want to display in the toolbar.
                    Thanks to Thomthom and TIG!
                    LINK: http://forums.sketchucation.com/viewtopic.php?p=81391#p81391
                    My scripts
                      Matt666
                      Do not hesitate to tell me if something goes wrong... I'm new with HTML and JAVASCRIPT...
                      My scripts
                        driven
                        Hi Mat,
                        on my mac if I instal this correctly and open SU
                        Unless, I use the manager, make a change and then quit
                        SU actually crashes when I close a window and I get a report dialog.
                        When I remove this ruby, everything works as it should, if put it back again problem returns.
                        it make no difference if I use or don't use the plugin, only if it's installed.
                        %(#BF0040)[28 com.google.sketchupfree8 0x004a9316 std::vector<CSketchUpToolbar::CToolBarItem, std::allocatorCSketchUpToolbar::CToolBarItem >::_M_insert_aux(__gnu_cxx::__normal_iterator<CSketchUpToolbar::CToolBarItem*, std::vector<CSketchUpToolbar::CToolBarItem, std::allocatorCSketchUpToolbar::CToolBarItem > >, CSketchUpToolbar::CToolBarItem const&) + 1968
                        29 com.google.sketchupfree8 0x004aa4ab std::vector<CSketchUpToolbar::CToolBarItem, std::allocatorCSketchUpToolbar::CToolBarItem >::_M_insert_aux(__gnu_cxx::__normal_iterator<CSketchUpToolbar::CToolBarItem*, std::vector<CSketchUpToolbar::CToolBarItem, std::allocatorCSketchUpToolbar::CToolBarItem > >, CSketchUpToolbar::CToolBarItem const&) + 6469
                        30 libCommonUtils.dylib 0x00a8538a CNotificationCenter::SendNotification(char const*, void*) + 202
                        31 com.google.sketchupfree8 0x004c1d48 non-virtual thunk to CTool::~CTool() + 3048
                        32 com.google.sketchupfree8 0x004c27c3 non-virtual thunk to CTool::~CTool() + 5731
                        33 com.google.sketchupfree8 0x00008335 0x1000 + 29493]
                          Matt666
                          Hum Thomthom told me I had to use 'show' with windows and 'show_modal' with mac... I think this is the problem (because i completely forgot this!). I'll take a look soon thank you!
                          My scripts
                            driven
                            Hi Mat,
                            It actually seems to be something to do with the preference settings, which SU sends to the .plist on Mac.
                            .show and .show_modal never cause crashes, it's just the dialog disappears under the main window.
                              Matt666
                              Hi!
                              See first post to download new version [v2.11].
                              • Mac bug fixed
                              • Add tool in extensions window.
                                Big thanks to driven for his help! πŸ‘
                              My scripts
                                ankitdarda
                                thanks a lot..
                                404 Not Found
                                (forums.sketchucation.com)
                                thank you !!!
                                feel free to click on my site http://www.ankitfolio.co.cc includes my blog page link within it
                                :sunglasses:
                                ankitdarda
                                  Matt666
                                  πŸ˜‰
                                  My scripts
                                  • U Offline
                                    ultimato andy
                                    where is the pluggin to download for sketchup 8? i cant find it!:(
                                      Attached to the first post of the topic (usually at the bottom)
                                        Matt666
                                        Thank you Gaieus!
                                        My scripts
                                          mirale999
                                          Great plugin~ I find it easy to switch from mm to M when just to measure the area of a plan now!
                                          paranoia is a higher form of awareness...
                                            driven
                                            Hi.
                                            I don't think it's a Lion issue... per say
                                            on the mac the MF_UNCHECKED MF_CHECKED just doesn't work to your advantage, and after a few wrong combinations, it stops switching the screen text, although console says it's working.
                                            if you run it with RC open you can see that your better off re-clicking the currently selected first, to turn the shadow off, then changing. it's a drag, but SU enabled the native buttons behavior to latch and when it also coded to latch....
                                            the mac native SU button code needs to be modified, then we can have buttons the toggles, like 'some' native SU ones that were set up correctly.
                                            as a stop gap I changed the MF_CHECKED to MF_UNCHECKED, which sightly reduces confusion.
                                            • 6 / 8
