    [Plugin] UV Toolkit
    377 Posts 86 Posters 398.5k Views 86 Watching
    • GaieusG
      I am only doing it for the sake of the community (i.e. squeezing everything out of Thom in order that we have the greatest UV plugin ever!)
      πŸ˜„
        I'll agree on the UV toolkit being excellent but don't forget he needs to concentrate on Bezier Patch for me.
        Now i need to return to baking the world biggest cookie.....for Thom.....my pal...... πŸ‘
          Ro33y
          thanks a lot thom!! πŸ‘
          very usefull... β˜€
            robert111
            why uv toolkit , no work with me, i have make uv toolkit (2.1.0) and TT_Lib2 (v2.4.0) in sketchup / plugin but i dont find uv toolkit in my plugin
            is the same problem with sketchup 7 and 8
            plz i need solution for this problem
            thanks
              Windows or OSX? Can you post a screenshot of where you placed the files?
              Any error messages?
                robert111
                thanks thomthom
                i have uv toolkit and not toolkit2
                  robert111
                  i have windows xp pack 3
                    I'm guessing you put all the content of the TT_Lib2 folder directly into the plugins folder?
                    Have a look at the footprint description of TT_Lib2 - towards the bottom of the first post.
                      robert111
                      yes i put all the content of the TT_Lib2 folder directly into the plugins folder
                        It should be there.
                        It should be ...\Plugins\TT_Lib2\<*.rb> - like the footprint description for TT_Lib illustrates.
                          robert111
                          I did not understand, can you explain more clearly
                            JoZ
                            Ehy ThomThom, great plugin πŸ˜„
                            Any chance you would look into increasing it with numerical input transformations like: translation, rotation, scale as possible in 3dpaintbrush for example (see this part of video: http://www.youtube.com/watch?feature=player_detailpage&v=h_7ZOgjxREM#t=125s) ?
                            That would be very usefull, avoiding me the need to often switch to other 3d app just for this (I often need precise numerical transform) πŸ˜„
                              When I finish the transoformation gizmo you'll be able to use numerical input for some transformations.
                                JoZ
                                Perfect... now I must remind of that... everything I think... You have yet thought about! πŸ˜›
                                • W
                                  wannabe
                                  hi
                                  I'm using sketchup for a while now (i got used to sketchup6 and this plugin works fine with it πŸ˜„ )
                                  well I haven't got any request for a plugin before but this one just peaks my curiosity...
                                  I thought of "linking" all faces (by id or something) to a brother object which we could deform and even unwrap (^^), texture and use remember uvs so it saves the current material position
                                  BUT
                                  restore it on the original
                                  what do u think ? possible ?
                                  deforming the face was nice however without I'd be happy too 😎
                                  great work so far works great
                                    rv1974
                                    @thomthom said:
                                    I have lots of ideas myself. I just don't know if I can do them. πŸ˜‰
                                    Is 'align texture to the selected edge' among them?
                                      That one is doable. πŸ˜„
                                        rv1974
                                        Good ...I'll listen RΓΆyksop while you doing this doable πŸ™‚
                                        • GaieusG
                                          @wannabe said:
                                          hi
                                          BUT
                                          That's one of my major wishes with the tool.
                                          Or put in a different way; not only remember then restore on the same geometry but copy from one geometry and apply on another one.
                                          Of course, the geometry should be the same as far as faces' number and shape is concerned.
                                            Justo
                                            Hey
                                            getting this error below;
                                            Error Loading File tt_uv_toolkit_2.rb
                                            undefined method `add_item' for nil:NilClass
                                            Ive got the latest lib in the plugin folder as well
                                            any help would be appreciated
                                            Cheers
                                            Justin
                                            Cheers
                                            Justin
                                            • 11
                                            • 12
                                            • 18
                                            • 19
                                            • 10 / 19
