    [Plugin] UV Toolkit
    377 Posts 86 Posters 415.1k Views 86 Watching
      Windows or OSX? Can you post a screenshot of where you placed the files?
      Any error messages?
        robert111
        thanks thomthom
        i have uv toolkit and not toolkit2
          robert111
          i have windows xp pack 3
            I'm guessing you put all the content of the TT_Lib2 folder directly into the plugins folder?
            Have a look at the footprint description of TT_Lib2 - towards the bottom of the first post.
              robert111
              yes i put all the content of the TT_Lib2 folder directly into the plugins folder
                It should be there.
                It should be ...\Plugins\TT_Lib2\<*.rb> - like the footprint description for TT_Lib illustrates.
                  robert111
                  I did not understand, can you explain more clearly
                    JoZ
                    Ehy ThomThom, great plugin πŸ˜„
                    Any chance you would look into increasing it with numerical input transformations like: translation, rotation, scale as possible in 3dpaintbrush for example (see this part of video: http://www.youtube.com/watch?feature=player_detailpage&v=h_7ZOgjxREM#t=125s) ?
                    That would be very usefull, avoiding me the need to often switch to other 3d app just for this (I often need precise numerical transform) πŸ˜„
                      When I finish the transoformation gizmo you'll be able to use numerical input for some transformations.
                        JoZ
                        Perfect... now I must remind of that... everything I think... You have yet thought about! πŸ˜›
                        • W
                          wannabe
                          hi
                          I'm using sketchup for a while now (i got used to sketchup6 and this plugin works fine with it πŸ˜„ )
                          well I haven't got any request for a plugin before but this one just peaks my curiosity...
                          I thought of "linking" all faces (by id or something) to a brother object which we could deform and even unwrap (^^), texture and use remember uvs so it saves the current material position
                          BUT
                          restore it on the original
                          what do u think ? possible ?
                          deforming the face was nice however without I'd be happy too 😎
                          great work so far works great
                            rv1974
                            @thomthom said:
                            I have lots of ideas myself. I just don't know if I can do them. πŸ˜‰
                            Is 'align texture to the selected edge' among them?
                              That one is doable. πŸ˜„
                                rv1974
                                Good ...I'll listen RΓΆyksop while you doing this doable πŸ™‚
                                • GaieusG
                                  @wannabe said:
                                  hi
                                  BUT
                                  That's one of my major wishes with the tool.
                                  Or put in a different way; not only remember then restore on the same geometry but copy from one geometry and apply on another one.
                                  Of course, the geometry should be the same as far as faces' number and shape is concerned.
                                    Justo
                                    Hey
                                    getting this error below;
                                    Error Loading File tt_uv_toolkit_2.rb
                                    undefined method `add_item' for nil:NilClass
                                    Ive got the latest lib in the plugin folder as well
                                    any help would be appreciated
                                    Cheers
                                    Justin
                                    Cheers
                                    Justin
                                      @justo said:
                                      Hey
                                      Cheers
                                      Justin
                                      I'm guessing you didn't extract it correctly and places all .rb files in the Plugins folder?
                                      If you look at the bottom of the first post you see an example of the footprint for the files.
                                      In the plugins folder you should have tt_uv_toolkit_2.rb and a folder TT_UV_Toolkit which contains other .rb files.
                                        Justo
                                        i believe they're in the right spots?
                                        tt_uv_toolkit_2.rb is in plugin folder
                                        and folder TT_UV_Toolkit contains clipboard, core, memory, and quadface .rb files.
                                        TT_Lib2 is in plugin folder.
                                        if it makes a difference, this is the first time ive tried to use this plugin (no older versions)
                                        Cheers
                                        Justin
                                          hm...
                                          Ok - do this for me:
                                          Open the Ruby Console (Window > Ruby Console)
                                          Type: load 'tt_uv_toolkit_2.rb'
                                          Post back the full message it reports back.
                                            Justo
                                            D:/Applications/Google/Google Sketchup 8/Plugins/TT_Lib2/core.rb:59: warning: already initialized constant BB_LEFT_FRONT_BOTTOM
                                            D:/Applications/Google/Google Sketchup 8/Plugins/TT_Lib2/core.rb:60: warning: already initialized constant BB_RIGHT_FRONT_BOTTOM
                                            D:/Applications/Google/Google Sketchup 8/Plugins/TT_Lib2/core.rb:61: warning: already initialized constant BB_LEFT_BACK_BOTTOM
                                            D:/Applications/Google/Google Sketchup 8/Plugins/TT_Lib2/core.rb:62: warning: already initialized constant BB_RIGHT_BACK_BOTTOM
                                            D:/Applications/Google/Google Sketchup 8/Plugins/TT_Lib2/core.rb:63: warning: already initialized constant BB_LEFT_FRONT_TOP
                                            D:/Applications/Google/Google Sketchup 8/Plugins/TT_Lib2/core.rb:64: warning: already initialized constant BB_RIGHT_FRONT_TOP
                                            D:/Applications/Google/Google Sketchup 8/Plugins/TT_Lib2/core.rb:65: warning: already initialized constant BB_LEFT_BACK_TOP
                                            D:/Applications/Google/Google Sketchup 8/Plugins/TT_Lib2/core.rb:66: warning: already initialized constant BB_RIGHT_BACK_TOP
                                            D:/Applications/Google/Google Sketchup 8/Plugins/TT_Lib2/core.rb:68: warning: already initialized constant BB_CENTER_FRONT_BOTTOM
                                            D:/Applications/Google/Google Sketchup 8/Plugins/TT_Lib2/core.rb:69: warning: already initialized constant BB_CENTER_BACK_BOTTOM
                                            D:/Applications/Google/Google Sketchup 8/Plugins/TT_Lib2/core.rb:70: warning: already initialized constant BB_CENTER_FRONT_TOP
                                            D:/Applications/Google/Google Sketchup 8/Plugins/TT_Lib2/core.rb:71: warning: already initialized constant BB_CENTER_BACK_TOP
                                            D:/Applications/Google/Google Sketchup 8/Plugins/TT_Lib2/core.rb:73: warning: already initialized constant BB_LEFT_CENTER_BOTTOM
                                            D:/Applications/Google/Google Sketchup 8/Plugins/TT_Lib2/core.rb:74: warning: already initialized constant BB_LEFT_CENTER_TOP
                                            D:/Applications/Google/Google Sketchup 8/Plugins/TT_Lib2/core.rb:75: warning: already initialized constant BB_RIGHT_CENTER_BOTTOM
                                            D:/Applications/Google/Google Sketchup 8/Plugins/TT_Lib2/core.rb:76: warning: already initialized constant BB_RIGHT_CENTER_TOP
                                            D:/Applications/Google/Google Sketchup 8/Plugins/TT_Lib2/core.rb:78: warning: already initialized constant BB_LEFT_FRONT_CENTER
                                            D:/Applications/Google/Google Sketchup 8/Plugins/TT_Lib2/core.rb:79: warning: already initialized constant BB_RIGHT_FRONT_CENTER
                                            D:/Applications/Google/Google Sketchup 8/Plugins/TT_Lib2/core.rb:80: warning: already initialized constant BB_LEFT_BACK_CENTER
                                            D:/Applications/Google/Google Sketchup 8/Plugins/TT_Lib2/core.rb:81: warning: already initialized constant BB_RIGHT_BACK_CENTER
                                            D:/Applications/Google/Google Sketchup 8/Plugins/TT_Lib2/core.rb:83: warning: already initialized constant BB_LEFT_CENTER_CENTER
                                            D:/Applications/Google/Google Sketchup 8/Plugins/TT_Lib2/core.rb:84: warning: already initialized constant BB_RIGHT_CENTER_CENTER
                                            D:/Applications/Google/Google Sketchup 8/Plugins/TT_Lib2/core.rb:85: warning: already initialized constant BB_CENTER_FRONT_CENTER
                                            D:/Applications/Google/Google Sketchup 8/Plugins/TT_Lib2/core.rb:86: warning: already initialized constant BB_CENTER_BACK_CENTER
                                            D:/Applications/Google/Google Sketchup 8/Plugins/TT_Lib2/core.rb:87: warning: already initialized constant BB_CENTER_CENTER_TOP
                                            D:/Applications/Google/Google Sketchup 8/Plugins/TT_Lib2/core.rb:88: warning: already initialized constant BB_CENTER_CENTER_BOTTOM
                                            D:/Applications/Google/Google Sketchup 8/Plugins/TT_Lib2/core.rb:90: warning: already initialized constant BB_CENTER_CENTER_CENTER
                                            D:/Applications/Google/Google Sketchup 8/Plugins/TT_Lib2/core.rb:91: warning: already initialized constant BB_CENTER
                                            D:/Applications/Google/Google Sketchup 8/Plugins/TT_Lib2/core.rb:96: warning: already initialized constant MB_ICONHAND
                                            D:/Applications/Google/Google Sketchup 8/Plugins/TT_Lib2/core.rb:97: warning: already initialized constant MB_ICONSTOP
                                            D:/Applications/Google/Google Sketchup 8/Plugins/TT_Lib2/core.rb:98: warning: already initialized constant MB_ICONERROR
                                            D:/Applications/Google/Google Sketchup 8/Plugins/TT_Lib2/core.rb:99: warning: already initialized constant MB_ICONQUESTION
                                            D:/Applications/Google/Google Sketchup 8/Plugins/TT_Lib2/core.rbπŸ’― warning: already initialized constant MB_ICONEXCLAMATION
                                            D:/Applications/Google/Google Sketchup 8/Plugins/TT_Lib2/core.rb:101: warning: already initialized constant MB_ICONWARNING
                                            D:/Applications/Google/Google Sketchup 8/Plugins/TT_Lib2/core.rb:102: warning: already initialized constant MB_ICONASTERISK
                                            D:/Applications/Google/Google Sketchup 8/Plugins/TT_Lib2/core.rb:103: warning: already initialized constant MB_ICONINFORMATION
                                            D:/Applications/Google/Google Sketchup 8/Plugins/TT_Lib2/core.rb:104: warning: already initialized constant MB_ICON_NONE
                                            D:/Applications/Google/Google Sketchup 8/Plugins/TT_Lib2/core.rb:106: warning: already initialized constant MB_DEFBUTTON1
                                            D:/Applications/Google/Google Sketchup 8/Plugins/TT_Lib2/core.rb:107: warning: already initialized constant MB_DEFBUTTON2
                                            D:/Applications/Google/Google Sketchup 8/Plugins/TT_Lib2/core.rb:108: warning: already initialized constant MB_DEFBUTTON3
                                            D:/Applications/Google/Google Sketchup 8/Plugins/TT_Lib2/core.rb:109: warning: already initialized constant MB_DEFBUTTON4
                                            D:/Applications/Google/Google Sketchup 8/Plugins/TT_Lib2/core.rb:120: warning: already initialized constant VERSION
                                            D:/Applications/Google/Google Sketchup 8/Plugins/TT_Lib2/core.rb:124: warning: already initialized constant V_MAJOR
                                            D:/Applications/Google/Google Sketchup 8/Plugins/TT_Lib2/core.rb:128: warning: already initialized constant V_MINOR
                                            D:/Applications/Google/Google Sketchup 8/Plugins/TT_Lib2/core.rb:132: warning: already initialized constant V_REV
                                            Error: #<NoMethodError: undefined method add_item' for nil:NilClass> D:/Applications/Google/Google Sketchup 8/Plugins/tt_uv_toolkit_2.rb:27 D:/Applications/Google/Google Sketchup 8/Plugins/TT_Lib2/core.rb:213:in require'
                                            D:/Applications/Google/Google Sketchup 8/Plugins/TT_Lib2/core.rb:212:in each' D:/Applications/Google/Google Sketchup 8/Plugins/TT_Lib2/core.rb:212 D:/Applications/Google/Google Sketchup 8/Plugins/tt_uv_toolkit_2.rb:27:in require'
                                            (eval):58:in `load'
                                            (eval):58
                                            Cheers
                                            Justin
                                            • 11
                                            • 12
                                            • 13
                                            • 18
                                            • 19
                                            • 11 / 19
