    [Plugin] BezierSpline - v2.2a - 22 Apr 21
    460 Posts 183 Posters 2.1m Views 183 Watching
    • jeff hammondJ Offline
      @mitcorb said:
      What you are asking may not be available, since these are supposed to be 2d functions. I could be wrong, and it won't be the first time- believe me.
      i'm leaning toward the ICBW side 😉
      • mitcorbM Offline
        mitcorb
        Yeah, me too.
        I just checked the documentation and then did an experiment. Yes, I was able to intentionally click a point above the horizontal plane, although I did not click on a particular line.
        Tralfamadorians have the ability to see things much more clearly than us earthlings 💚
        My apologies, fellanamedlime
          what's fellanamedlime?
          fella named lime?
          the only thing google is telling me at the moment is that it's a fairly popular forum user name (even one here at scf).
          i'm thinking this one has flown over my head 😆
            chrisjk
            You can constrain the movement in editing mode. On the Mac, click Alt (I think it's probably Ctrl in Windows) then the black box turns into an outline, hit the up arrow as you would with the Move tool and Hey Presto you are locked in the Z direction. Fredo links to a tutorial here http://www.aecbytes.com/tipsandtricks/2009/issue42-sketchup.html that explains that plus other stuff.
            • fredo6F Offline
              @fellanamedlime said:
              Hi Fredo,
              I love your Bezier plugin - it's a really great help. There's one thing though: is there any way to constrain the direction by which you can move the control points of the curve?
              For example, if I want to move a point vertically, it's really tricky: I have to draw a vertical line, then try and move the control point to the top of that line, although even then it doesn't work properly because it doesn't snap.
              If there was a way to constrain it (like you do normally, by pressing shift to constrain it to the blue axis), that would be a major, major help. Is there any way to incoroporate this into the plugin?
              Thanks once again for all you hard work.
              When you edit a control point, you can press Arrows to impose a direction of axes. You'll see a small triangle (you may have to press and release CTRL if you are in plane constraint mode).
              But I agree, this should be better done. Indeed, I will take care of it when I build a new version.
              • mitcorbM Offline
                mitcorb
                Thank you, Fredo
                Would there be any difficulty using this SU7.1 in anticipation of upgrading to SU8?
                  Larsen
                  Total respect, chapeau Monsieur.
                  [Every form of thinking perish by excess of its basic principles.
                  • fredo6F Offline
                    NEW RELEASE 1.4f - 23 Jan 2011
                    This release just fixes a potential performance in the contextual menu when there is a big number of elements in the selection. This was signaled by ThomThom and Jim.
                    Download new release at main post on BezierSpline
                      Jim
                      Thanks Fredo.
                      • F Offline
                        fellanamedlime
                        Aha! This is exactly what I was after... Pressing the arrow keys to constrain direction plane (i.e. up key=blue etc.) is actually a pretty easy way of doing it, I just wasn't aware of this function. This makes it a lot easier to use. Thanks for the tip!
                        • W Offline
                          watkins
                          Dear Fredo,
                          Just a brief note to say thank you for all your hard work. As always, your generosity is greatly appreciated.
                          Kind regards,
                          Bob
                            junoswayam
                            Thanks a lot man..... This is amazing!!
                              spruzza
                              Great!!! Really usefull!!
                              • U Offline
                                unclex
                                IF remove cadfather's icon catalog
                                the BS icon @ SU vanished...
                                when cadfather's and default catalog together,
                                the icon @ SU can work
                                  bentleykfrog
                                  cool tool, just one suggestion. It would be helpful to reverse the direction of the polyline divide function so you can choose which end the dividing starts at. Currently, for curves that have an incorrect start and end, I have to explode my curve, then recreate the curve using the classic bezier curve tool, then use polyline divide.
                                  Sorry for my ignorance if this feature already exists.
                                    bentleykfrog
                                    Ohh, I forgot to post an example of how I've used the tool. I used Polyline divide in the image below on the lines that set out the rows of vines, then I used Chris Fullmer's Component Stringer to set out the vine components along these paths. Very happy with the result ☀
                                    Polyline Divide usage example
                                    • fredo6F Offline
                                      The feature does not exist in BezierSpline, but you can use the plugin RevertCurve to inverse the direction of the curve.
                                        bentleykfrog
                                        Ahh! awesome, thanks again Fredo6
                                          mimarhamza
                                          Hi Fredo This toolbar is great.My question is that I couldnt find out how to snap x y z axes like hold the shift key down draw line and also hard to snap endpoint when creating or editing curves?
                                          • F Offline
                                            function
                                            hi - I had a feature request for the Courbette tool.: can we have an option to specify a uniform division of vertexes over the whole curve while retaining the same control points? or possibly even better, to modify the S value between control points. As far as I have been able to understand, the S value affects the whole curve which causes facets with shallow slopes and over-division with high slopes (see image). Trying to up the S value to compensate for the faceting then simultaneously overpopulates higher slopes with far too many vertexes. This tool is very intuitive and great to work with, however I find myself attempting workarounds to create a more uniform distribution.
                                            • 11
                                            • 22
                                            • 23
                                            • 9 / 23
