    [Plugin] BezierSpline - v2.2a - 22 Apr 21
    460 Posts 183 Posters 2.1m Views 183 Watching
    • GaieusG
      Hi aswas,
      The link does work for me. What do you see in place of the download link to the zip archive under that big, yellow, download label?
        Hi Fredo
        I have 1.4e - 10 Nov 2010 installed, but I still experience the context handler to lag on larger models.
        Example: ~92.000 entities:
        ### Context Handler ### bezierspline_main.rb:2465:inload_all_menus' bezierspline.rb:50
        3.013 seconds`
        • fredo6F
          @thomthom said:
          Hi Fredo
          3.013 seconds`
          I guess these are 92000 entities at first level, which is normally seldom, since most co,plex model tend to be structured with components.
          Then, yes, BezierSpline cycles through it to find a curve which is of type BezierSpline.
          I'll see what I can do
            It was on a selection inside a component or group.
            • F
              fellanamedlime
              Hi Fredo,
              I love your Bezier plugin - it's a really great help. There's one thing though: is there any way to constrain the direction by which you can move the control points of the curve?
              For example, if I want to move a point vertically, it's really tricky: I have to draw a vertical line, then try and move the control point to the top of that line, although even then it doesn't work properly because it doesn't snap.
              If there was a way to constrain it (like you do normally, by pressing shift to constrain it to the blue axis), that would be a major, major help. Is there any way to incoroporate this into the plugin?
              Thanks once again for all you hard work.
              • mitcorbM
                mitcorb
                What you are asking may not be available, since these are supposed to be 2d functions. I could be wrong, and it won't be the first time- believe me.
                I believe Bezierspline has some documentation which you can find within your Sketchup Plugins Folder, since it is supplied with the script. Should be pdf. I am saying this without checking my folder for sure.
                • jeff hammondJ
                  i'm leaning toward the ICBW side 😉
                  • mitcorbM
                    mitcorb
                    Yeah, me too.
                    I just checked the documentation and then did an experiment. Yes, I was able to intentionally click a point above the horizontal plane, although I did not click on a particular line.
                    Tralfamadorians have the ability to see things much more clearly than us earthlings 💚
                    My apologies, fellanamedlime
                    • jeff hammondJ
                      what's fellanamedlime?
                      fella named lime?
                      the only thing google is telling me at the moment is that it's a fairly popular forum user name (even one here at scf).
                      i'm thinking this one has flown over my head 😆
                      • C
                        chrisjk
                        You can constrain the movement in editing mode. On the Mac, click Alt (I think it's probably Ctrl in Windows) then the black box turns into an outline, hit the up arrow as you would with the Move tool and Hey Presto you are locked in the Z direction. Fredo links to a tutorial here http://www.aecbytes.com/tipsandtricks/2009/issue42-sketchup.html that explains that plus other stuff.
                        • fredo6F
                          @fellanamedlime said:
                          Hi Fredo,
                          When you edit a control point, you can press Arrows to impose a direction of axes. You'll see a small triangle (you may have to press and release CTRL if you are in plane constraint mode).
                          But I agree, this should be better done. Indeed, I will take care of it when I build a new version.
                          • mitcorbM
                            mitcorb
                            Thank you, Fredo
                            Would there be any difficulty using this SU7.1 in anticipation of upgrading to SU8?
                            • L
                              Larsen
                              Total respect, chapeau Monsieur.
                              [Every form of thinking perish by excess of its basic principles.
                              • fredo6F
                                NEW RELEASE 1.4f - 23 Jan 2011
                                This release just fixes a potential performance in the contextual menu when there is a big number of elements in the selection. This was signaled by ThomThom and Jim.
                                Download new release at main post on BezierSpline
                                  Jim
                                  Thanks Fredo.
                                  • F
                                    fellanamedlime
                                    Aha! This is exactly what I was after... Pressing the arrow keys to constrain direction plane (i.e. up key=blue etc.) is actually a pretty easy way of doing it, I just wasn't aware of this function. This makes it a lot easier to use. Thanks for the tip!
                                    • W
                                      watkins
                                      Dear Fredo,
                                      Just a brief note to say thank you for all your hard work. As always, your generosity is greatly appreciated.
                                      Kind regards,
                                      Bob
                                        junoswayam
                                        Thanks a lot man..... This is amazing!!
                                          spruzza
                                          Great!!! Really usefull!!
                                          • U
                                            unclex
                                            IF remove cadfather's icon catalog
                                            the BS icon @ SU vanished...
                                            when cadfather's and default catalog together,
                                            the icon @ SU can work
                                            • 11
                                            • 22
                                            • 23
                                            • 9 / 23
