    [Plugin] Shape Bender Beta
    1.3k Posts 331 Posters 2.0m Views 329 Watching
      Yes, it is the same height as the straight ramp you had drawn in the file.
      It's on my computer at home and I'm not there at the moment. I could send it to you or post it when I get back.
        arjunmax09
        but isn't there an effective way to make the ramp i'm making using shapebender?? πŸ˜’
        when you fail at something....you haven't really failed...you've found one way the thing will not work out
        • X Offline
          xtr3mx7
          Thank you TIG for providing the solution. The plugin now works perfectly πŸ˜„
          This is indeed a very great script. Big cheers to Chris πŸ˜„
          • U Offline
            unclex
            thanx this wonderful Plugin
            but it can not work with TIG's [HolePunchTool] Plugin, if punch was loaded, run Bender, SU would Crashed...
              I am working on it... πŸ˜• πŸ˜’
              • U Offline
                unclex
                ThanX
                  There's an updated version of the HolePunch tool available that avoids this clash...
                  see here for details http://forums.sketchucation.com/viewtopic.php?p=302853#p302853
                  and the zip's download is here http://forums.sketchucation.com/viewtopic.php?p=271170#p271170
                  πŸ€“
                  • fuzzionF Offline
                    fuzzion
                    @ben ritter said:
                    Chris, I can hardly keep up with your wonderful scripts. Most importantly though, you are very much appreciated for your kindness to the SU community.
                    Very well said. πŸ‘
                    Excellent plugin.
                    "Only the dead have seen the end of war" - Plato
                      jrtaylor6
                      After I download how to I make it work on sketchup?
                        Hi Jonathan (and welcome),
                        Did you watch the video in the first post, It pretty much explains everything.
                          jrtaylor6
                          Yeah i watch them. I dont have the tab that has plugins on it.
                            You mustn't have installed the files properly... πŸ˜•
                            It's a zip file... you must extract the files/folders from it into your ../Plugins/ folder... Please reread the instructions for the script installation and report back...
                            PS: I see you are a MAC user...
                            Type this into Window > Ruby Console
                            Sketchup.find_support_file('Plugins')
                            it shows where you should install your Plugins...
                            it IS easier on a PC as there is only one option...
                            πŸ˜’
                              jrtaylor6
                              Yes it was easier on PC so i switch to that.. I extracted all the files to the plugin file, and I got an error. This is what it said Error Loading File clf_shape_bender_loader.rb
                              no such file to load -- progressbar.rb
                                So install progressbar.rb as indicated in the 6th line of the original post.
                                And, for future reference, it is worthwhile reading all of the original post in an thread before downloading plugins. They usually full of useful information. πŸ˜‰
                                  IF you report the original error message in the first place we could help you more promptly πŸ˜’
                                  Please read the tool's instructions, follow them and then report errors after that [if any] 😞
                                    jrtaylor6
                                    Im sorry man Im just new to sketchup and Im trying to figure everything out..
                                      So did installing progressbar.rb fix your problem?
                                        Please report if the suggested fix resolves your issue...
                                        Without feedback we are unsure if what we suggest works......... πŸ˜•
                                        • E Offline
                                          ellen_leung
                                          thanks so much! i tried, very easy and very useful!
                                            clovis
                                            HI everyone
                                            I really appreciate all the work done for those amazing plugins , but i have some problems using Shape bender :
                                            installation went fine but when it comes to ebnding and object it doesn t work , explanation :
                                            I select a group (ok ) BUT THEN when it comes to select a line i have drawn on the side of that object , a window appears telling me [please select a straight line ] or [ select a line on the red axis ] .... and my line is straight And on the red axis !
                                            could anyone help me out?
                                            • 32
                                            • 33
                                            • 34
                                            • 35
                                            • 36
                                            • 63
                                            • 64
                                            • 34 / 64
