    [Plugin] Shape Bender Beta
    1.3k Posts 331 Posters 2.0m Views 329 Watching
      There's an updated version of the HolePunch tool available that avoids this clash...
      see here for details http://forums.sketchucation.com/viewtopic.php?p=302853#p302853
      and the zip's download is here http://forums.sketchucation.com/viewtopic.php?p=271170#p271170
      πŸ€“
      • fuzzionF Offline
        fuzzion
        @ben ritter said:
        Chris, I can hardly keep up with your wonderful scripts. Most importantly though, you are very much appreciated for your kindness to the SU community.
        Very well said. πŸ‘
        Excellent plugin.
        "Only the dead have seen the end of war" - Plato
          jrtaylor6
          After I download how to I make it work on sketchup?
            Hi Jonathan (and welcome),
            Did you watch the video in the first post, It pretty much explains everything.
              jrtaylor6
              Yeah i watch them. I dont have the tab that has plugins on it.
                You mustn't have installed the files properly... πŸ˜•
                It's a zip file... you must extract the files/folders from it into your ../Plugins/ folder... Please reread the instructions for the script installation and report back...
                PS: I see you are a MAC user...
                Type this into Window > Ruby Console
                Sketchup.find_support_file('Plugins')
                it shows where you should install your Plugins...
                it IS easier on a PC as there is only one option...
                πŸ˜’
                  jrtaylor6
                  Yes it was easier on PC so i switch to that.. I extracted all the files to the plugin file, and I got an error. This is what it said Error Loading File clf_shape_bender_loader.rb
                  no such file to load -- progressbar.rb
                    So install progressbar.rb as indicated in the 6th line of the original post.
                    And, for future reference, it is worthwhile reading all of the original post in an thread before downloading plugins. They usually full of useful information. πŸ˜‰
                      IF you report the original error message in the first place we could help you more promptly πŸ˜’
                      Please read the tool's instructions, follow them and then report errors after that [if any] 😞
                        jrtaylor6
                        Im sorry man Im just new to sketchup and Im trying to figure everything out..
                          So did installing progressbar.rb fix your problem?
                            Please report if the suggested fix resolves your issue...
                            Without feedback we are unsure if what we suggest works......... πŸ˜•
                            • E Offline
                              ellen_leung
                              thanks so much! i tried, very easy and very useful!
                                clovis
                                HI everyone
                                I really appreciate all the work done for those amazing plugins , but i have some problems using Shape bender :
                                installation went fine but when it comes to ebnding and object it doesn t work , explanation :
                                I select a group (ok ) BUT THEN when it comes to select a line i have drawn on the side of that object , a window appears telling me [please select a straight line ] or [ select a line on the red axis ] .... and my line is straight And on the red axis !
                                could anyone help me out?
                                  John,
                                  Is the line you are selecting part of the group? If so, that would explain the message. The line must be outside the group for it to work.
                                  http://farm5.static.flickr.com/4067/5126930295_1fe489e2ba.jpg
                                  In this image the line is being selected. The component to be bent is above it.
                                    clovis
                                    the line is outside the group .
                                    Mostly sketchup tells me [ please select a line that is on the red axis ]
                                    what may i do ??
                                      clovis
                                      and it does not work even if my line is on the red axis ...
                                        You need three things to use the tool
                                        A Group or Component-instance.
                                        A Line drawn along the red-axis to determine the extent of the actions.
                                        A Curve [e.g. an Arc] - this is often drawn to have similar extents as the Line [but not necessarily].
                                        Preselect the Group/Component.
                                        Run the tool and follow the prompts.
                                        Pick the Line.
                                        Pick the Curve.
                                          TIG beat me to it. Can you post a screen shot of what you're trying to do?
                                            clovis
                                            Pick the Line.
                                            Pick the Curve.
                                            Toggle the 'Ends' using the Arrow-Keys etc as prompted etc...[attachment=0:rnii52fu]<!-- ia0 -->Capture.PNG<!-- ia0 -->[/attachment:rnii52fu]
                                            I EXACTLY DO AS YOU SHOW ... but Can t select the "lone line on the red axis" , as sketchup does not notice it .. always the same error message
                                            I might try to re instal the plug in ...
                                            • 32
                                            • 33
                                            • 34
                                            • 35
                                            • 36
                                            • 63
                                            • 64
                                            • 34 / 64
