    [Plugin] Shape Bender Beta
    1.3k Posts 331 Posters 2.2m Views 329 Watching
      arjunmax09
      Hello everyone..
      I'm using Google SketchUp Pro 8 . I am unable to make a ramp using shape bender that is 34 metres long and has 1:10 slope. The Shape Bender doesn't bend the ramp as expected. I've attached a video and a model of the ramp.
      Ramp problem.rar
      when you fail at something....you haven't really failed...you've found one way the thing will not work out
      • numbthumbN Offline
        numbthumb
        How about this?
        Comfortably numb...
          Arjun,
          I think the problem comes in that there needs to be some distortion in the top surface which shape Bender doesn't do. I think NumbThumb's suggestion is a good one. I did it manually because I wanted to see how the shape develops but I think the plugin would be much faster.
          http://farm6.static.flickr.com/5045/5290313722_16e1a20be2.jpg
          http://farm6.static.flickr.com/5130/5290313788_1952597cc1.jpg
          Is this what you want as a result?
            arjunmax09
            yes i want a ramp like this only..is the edge on the end coming out to be 3.4 metres in height??
              Yes, it is the same height as the straight ramp you had drawn in the file.
              It's on my computer at home and I'm not there at the moment. I could send it to you or post it when I get back.
                arjunmax09
                but isn't there an effective way to make the ramp i'm making using shapebender?? πŸ˜’
                • X Offline
                  xtr3mx7
                  Thank you TIG for providing the solution. The plugin now works perfectly πŸ˜„
                  This is indeed a very great script. Big cheers to Chris πŸ˜„
                  • U Offline
                    unclex
                    thanx this wonderful Plugin
                    but it can not work with TIG's [HolePunchTool] Plugin, if punch was loaded, run Bender, SU would Crashed...
                      I am working on it... πŸ˜• πŸ˜’
                      • U Offline
                        unclex
                        ThanX
                          There's an updated version of the HolePunch tool available that avoids this clash...
                          see here for details http://forums.sketchucation.com/viewtopic.php?p=302853#p302853
                          and the zip's download is here http://forums.sketchucation.com/viewtopic.php?p=271170#p271170
                          πŸ€“
                          • fuzzionF Offline
                            fuzzion
                            @ben ritter said:
                            Chris, I can hardly keep up with your wonderful scripts. Most importantly though, you are very much appreciated for your kindness to the SU community.
                            Very well said. πŸ‘
                            Excellent plugin.
                            "Only the dead have seen the end of war" - Plato
                              jrtaylor6
                              After I download how to I make it work on sketchup?
                                Hi Jonathan (and welcome),
                                Did you watch the video in the first post, It pretty much explains everything.
                                  jrtaylor6
                                  Yeah i watch them. I dont have the tab that has plugins on it.
                                    You mustn't have installed the files properly... πŸ˜•
                                    It's a zip file... you must extract the files/folders from it into your ../Plugins/ folder... Please reread the instructions for the script installation and report back...
                                    PS: I see you are a MAC user...
                                    Type this into Window > Ruby Console
                                    Sketchup.find_support_file('Plugins')
                                    it shows where you should install your Plugins...
                                    it IS easier on a PC as there is only one option...
                                    πŸ˜’
                                      jrtaylor6
                                      Yes it was easier on PC so i switch to that.. I extracted all the files to the plugin file, and I got an error. This is what it said Error Loading File clf_shape_bender_loader.rb
                                      no such file to load -- progressbar.rb
                                        So install progressbar.rb as indicated in the 6th line of the original post.
                                        And, for future reference, it is worthwhile reading all of the original post in an thread before downloading plugins. They usually full of useful information. πŸ˜‰
                                          IF you report the original error message in the first place we could help you more promptly πŸ˜’
                                          Please read the tool's instructions, follow them and then report errors after that [if any] 😞
                                            jrtaylor6
                                            Im sorry man Im just new to sketchup and Im trying to figure everything out..
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 35
                                            • 63
                                            • 64
                                            • 33 / 64
