    [Plugin] Shape Bender Beta
    1.3k Posts 331 Posters 2.2m Views 329 Watching
      arjunmax09
      @dave r said:
      Is this what you want as a result?
      yes i want a ramp like this only..is the edge on the end coming out to be 3.4 metres in height??
      when you fail at something....you haven't really failed...you've found one way the thing will not work out
        Yes, it is the same height as the straight ramp you had drawn in the file.
        It's on my computer at home and I'm not there at the moment. I could send it to you or post it when I get back.
          arjunmax09
          but isn't there an effective way to make the ramp i'm making using shapebender?? πŸ˜’
          • X Offline
            xtr3mx7
            Thank you TIG for providing the solution. The plugin now works perfectly πŸ˜„
            This is indeed a very great script. Big cheers to Chris πŸ˜„
            • U Offline
              unclex
              thanx this wonderful Plugin
              but it can not work with TIG's [HolePunchTool] Plugin, if punch was loaded, run Bender, SU would Crashed...
                I am working on it... πŸ˜• πŸ˜’
                • U Offline
                  unclex
                  ThanX
                    There's an updated version of the HolePunch tool available that avoids this clash...
                    see here for details http://forums.sketchucation.com/viewtopic.php?p=302853#p302853
                    and the zip's download is here http://forums.sketchucation.com/viewtopic.php?p=271170#p271170
                    πŸ€“
                    • fuzzionF Offline
                      fuzzion
                      @ben ritter said:
                      Chris, I can hardly keep up with your wonderful scripts. Most importantly though, you are very much appreciated for your kindness to the SU community.
                      Very well said. πŸ‘
                      Excellent plugin.
                      "Only the dead have seen the end of war" - Plato
                        jrtaylor6
                        After I download how to I make it work on sketchup?
                          Hi Jonathan (and welcome),
                          Did you watch the video in the first post, It pretty much explains everything.
                            jrtaylor6
                            Yeah i watch them. I dont have the tab that has plugins on it.
                              You mustn't have installed the files properly... πŸ˜•
                              It's a zip file... you must extract the files/folders from it into your ../Plugins/ folder... Please reread the instructions for the script installation and report back...
                              PS: I see you are a MAC user...
                              Type this into Window > Ruby Console
                              Sketchup.find_support_file('Plugins')
                              it shows where you should install your Plugins...
                              it IS easier on a PC as there is only one option...
                              πŸ˜’
                                jrtaylor6
                                Yes it was easier on PC so i switch to that.. I extracted all the files to the plugin file, and I got an error. This is what it said Error Loading File clf_shape_bender_loader.rb
                                no such file to load -- progressbar.rb
                                  So install progressbar.rb as indicated in the 6th line of the original post.
                                  And, for future reference, it is worthwhile reading all of the original post in an thread before downloading plugins. They usually full of useful information. πŸ˜‰
                                    IF you report the original error message in the first place we could help you more promptly πŸ˜’
                                    Please read the tool's instructions, follow them and then report errors after that [if any] 😞
                                      jrtaylor6
                                      Im sorry man Im just new to sketchup and Im trying to figure everything out..
                                        So did installing progressbar.rb fix your problem?
                                          Please report if the suggested fix resolves your issue...
                                          Without feedback we are unsure if what we suggest works......... πŸ˜•
                                          • E Offline
                                            ellen_leung
                                            thanks so much! i tried, very easy and very useful!
                                            • 32
                                            • 33
                                            • 34
                                            • 35
                                            • 36
                                            • 63
                                            • 64
                                            • 34 / 64
