    [Plugin] Pipe Tool (UPDATE 3/19/2011)
    46 Posts 22 Posters 54.9k Views 22 Watching
      OK, thanks. I have not tried it yet but then I will! I hope you do not mind my question!
      (And thanks for the plugin, too - maybe Pilou is right and you should give some other title/subject...)
        By the way, in order to get your plugin to the Index, simply add [Plugin] to the subject line. That page is automatically generated (somehow - that's too crazy to think about)
          I would suggest to title this [Plugin]Pipe Tool as it's possibly infringing on it's bigger brother's territory.
          But its a great gesture to share this here 👍
          • tridemT Offline
            tridem
            👍 Nice work Builder Boy, very useful ... I just cannot figured out what's the meaning of the pipe room 😳 is it a grid that helps to positioning the components...or what?
              Ditto.
              A couple of notes about the distribution:
              Could you make sure that the icons are in a sub-folder - so you only have the .rb file in the root. That way it's easier to manage the plugins folder.
              (It's the common practice of distrobuting plugins: one .rb file in the plugins folder, and the remaining files in a sub-folder.
              Is the "previous versions" folder needed?
              I looked at your code - saw you added a method under class Geom::PolygonMesh
              <span class="syntaxdefault">def&nbsp;add_lathe</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">pts</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">center</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">dir</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">angle</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">numsegments</span><span class="syntaxkeyword">)&nbsp;</span><span class="syntaxcomment">#&nbsp;Copyright&nbsp;2004-2005,&nbsp;@Last&nbsp;Software,&nbsp;Inc.&nbsp;(I&nbsp;changed&nbsp;it&nbsp;a&nbsp;little)&nbsp;</span><span class="syntaxdefault"></span>
              This might cause problems since you changed the code. If some other plugin relies on the original Geom::PolygonMesh.add_lathe then your plugin will overwrite this.
              Avoid such conflicts by not using the same method name as the one you modify. Personally I prefer to never extend the base classes just in case someone else should be thinking of adding a method of the same name. We've already had and still have issues where plugins conflict over methods extended in the base classes.
              This add_lathe would be very easy to port into a method under the PipeTool class you use in the rest of the plugin.
              • EdsonE Offline
                Edson
                it would help if you could make a short video demonstrating what the plugin does.
                http://www.mahfuz.arq.br
                  Builder Boy
                  How? I don't have any software. I don't even have a microphone.
                  No
                  All my plugins
                    Builder Boy
                    Look at this.
                    All my plugins
                      Ben Ritter
                      Thank you for sharing.
                        d12dozr
                        Cam Studio is one free screen capture program...maybe you can just make a video of you making that futuristic motorcycle and other examples, and upload it to YouTube. Voiceover isn't even necessary, but then you could make some explaining text to supplement the video.
                        Thanks for your efforts!
                        http://goo.gl/f7ooYh
                          Builder Boy
                          What has this got to do with your 'plugin'?
                          I built it out of the pipes I made with my plugin. The wheel is 4 curved pipes that I combined. The handle is made out of a few pipes. The only things I didn't use my plugin for is the headlight and the red light on the back and the room I rendered it in and, a little hand modeling. (erasing unnecessary geometry, adding color Etc...)
                          Motorcycle.skp
                          All my plugins
                          • U Offline
                            unclex
                            Anybody can use this plugins?
                            Upzip it to the Plugins Cata
                            But Nothing Happening........
                              Builder Boy
                              I don't understand what you're problem is. Can you explain it better?
                              All my plugins
                                perryman
                                You need to put the file "Pipe Tool v4.0.rb" along with the .png files in the ..\plugins folder. You cannot put the folder in the ..\plugins directory.
                                I also want to thank you, Builder Boy, for a very nice plugin, great work!!
                                A few pointers that may be possible to implement:
                                • T-junction button?
                                • Flange button?
                                • is it possible to have metric, milimeter units, as standard?
                                • is it possible to make the pipe and parts hollow, with a thickness parameter?
                                Overall a very nice plugin. I would like to contribute but I'm sorry to say I don't have the knowledge to write or program a plugin, hmm...
                                • tridemT Offline
                                  tridem
                                  • Flange button?
                                  👍 +1
                                  except the pipe room, I see that overriding the values without " it uses metric units
                                  • U Offline
                                    unclex
                                    if i don't change anything, it works
                                    but i want change the PNG catalog,or change the PNG name(ofcouse i changed the file‘s name,too), change ‘ " to mm,it cannot work……
                                    For example
                                    @srad = '6"' change → @srad = '300.mm'
                                    piperoom.small_icon="Pipe Room.png" → piperoom.small_icon="PipeRoom.png"
                                      I haven't even looked at the code... but if @srad is being set as a string '1"' and then .to_l is used on it to return a 'length' then you can change it to another default unit e.g. '25mm' [no '.']. If it's a length already @srad = 1.0 [in inches if NO units] or =1.inch then you do use a '.' as in @srad = 25.mm to make it in 'mm'...
                                      The problem in using a string is you are forced to use a units suffix.
                                      If it were a length to start with then it's always a length and in 'current' units, so if you have 'mm' set in Model Info even it it were set to be 1 ["] it'd show as 25.4 [mm]...
                                      • N Offline
                                        Nick2010
                                        Thank you Builder Boy! 👍
                                          powersketch
                                          Thanks for making the plugin! Where can I find the png button icons? From reading the thread it sound like a previous version was distributed as a zip file with the .rb and some .png files.
                                            Builder Boy
                                            @gaieus said:
                                            Michael,
                                            Don't get me wrong here for this question; you "made a free version of it"? (Meaning you used that code and such)
                                            OR you made a tool yourself that has similar features as 3SKENG?
                                            Maybe it's just your wording. But you know, we take piracy and such very seriously here.
                                            I made a tool myself that has similar features as 3SKENG.
                                            All my plugins
                                            • 1 / 3
