    [Plugin] Pipe Tool (UPDATE 3/19/2011)
    46 Posts 22 Posters 56.0k Views 22 Watching
      d12dozr
      @builder boy said:
      How? I don't have any software. I don't even have a microphone.
      Cam Studio is one free screen capture program...maybe you can just make a video of you making that futuristic motorcycle and other examples, and upload it to YouTube. Voiceover isn't even necessary, but then you could make some explaining text to supplement the video.
      Thanks for your efforts!
      http://goo.gl/f7ooYh
        Builder Boy
        What has this got to do with your 'plugin'?
        I built it out of the pipes I made with my plugin. The wheel is 4 curved pipes that I combined. The handle is made out of a few pipes. The only things I didn't use my plugin for is the headlight and the red light on the back and the room I rendered it in and, a little hand modeling. (erasing unnecessary geometry, adding color Etc...)
        Motorcycle.skp
        All my plugins
        • U Offline
          unclex
          Anybody can use this plugins?
          Upzip it to the Plugins Cata
          But Nothing Happening........
            Builder Boy
            I don't understand what you're problem is. Can you explain it better?
            All my plugins
              perryman
              You need to put the file "Pipe Tool v4.0.rb" along with the .png files in the ..\plugins folder. You cannot put the folder in the ..\plugins directory.
              I also want to thank you, Builder Boy, for a very nice plugin, great work!!
              A few pointers that may be possible to implement:
              • T-junction button?
              • Flange button?
              • is it possible to have metric, milimeter units, as standard?
              • is it possible to make the pipe and parts hollow, with a thickness parameter?
              Overall a very nice plugin. I would like to contribute but I'm sorry to say I don't have the knowledge to write or program a plugin, hmm...
              • tridemT Offline
                tridem
                • Flange button?
                👍 +1
                except the pipe room, I see that overriding the values without " it uses metric units
                • U Offline
                  unclex
                  if i don't change anything, it works
                  but i want change the PNG catalog,or change the PNG name(ofcouse i changed the file‘s name,too), change ‘ " to mm,it cannot work……
                  For example
                  @srad = '6"' change → @srad = '300.mm'
                  piperoom.small_icon="Pipe Room.png" → piperoom.small_icon="PipeRoom.png"
                    I haven't even looked at the code... but if @srad is being set as a string '1"' and then .to_l is used on it to return a 'length' then you can change it to another default unit e.g. '25mm' [no '.']. If it's a length already @srad = 1.0 [in inches if NO units] or =1.inch then you do use a '.' as in @srad = 25.mm to make it in 'mm'...
                    The problem in using a string is you are forced to use a units suffix.
                    If it were a length to start with then it's always a length and in 'current' units, so if you have 'mm' set in Model Info even it it were set to be 1 ["] it'd show as 25.4 [mm]...
                    • N Offline
                      Nick2010
                      Thank you Builder Boy! 👍
                        powersketch
                        Thanks for making the plugin! Where can I find the png button icons? From reading the thread it sound like a previous version was distributed as a zip file with the .rb and some .png files.
                          Builder Boy
                          @gaieus said:
                          Michael,
                          Don't get me wrong here for this question; you "made a free version of it"? (Meaning you used that code and such)
                          OR you made a tool yourself that has similar features as 3SKENG?
                          Maybe it's just your wording. But you know, we take piracy and such very seriously here.
                          I made a tool myself that has similar features as 3SKENG.
                          All my plugins
                            raineysky
                            Thank You Builder Boy. Great plugin!!!
                              betod
                              it looks grate but where do i dropp al the files in my sketchup file??? thanks
                                Have a look at this tutorial: http://sketchucation.com/resources/tutorials/37-beginner/108-installing-sketchup-plugins
                                  Markis100
                                  Does this plugin work on mac oS? I dropped the files into plugin directory. Nothing is working. Am I doing something wrong?
                                    Can you describe what "isn't working"? Error messages? Unexpected behaviour? No new menus or toolbars?
                                    Difficult to help without any specific information.
                                      Markis100
                                      Nothing happens, no new menus, or pull downs. I copied all of the files from the folder into the plugin directory. Are there instructions somewhere?
                                        http://www.thomthom.net/thoughts/2012/01/installing-plugins-for-google-sketchup/
                                          This toolset has something of a 'rogue' setup, as it comes with all of its files [a .rb and 5 pngs] inside a zip archive and they ALL go 'loose' into the Plugins folder.
                                          I suspect you have done this, but are perplexed about how to 'activate' it...
                                          [Usually a toolset have a loader .rb and a tool-specific subfolder of several helper files, sometimes a tool is an Extension that needs activating [once] before any menus etc are available, but this tool is not like that 😕 ]
                                          The author has not been at all helpful about how you use his tools... 😒
                                          But reading through the code near the end of the script I see that it makes NO menus or context-menus !
                                          After Sketchup is restarted and the toolset has successfully auto-loaded, it only runs from a Toolbar that is named 'Pipes' - you will need to activate it [once] from your View > Toolbars list...
                                            Markis100
                                            Good call, that was the problem. Had to load the tool palette. Couple instructions from the author would have saved a lot of time. Sadly after all that the tool is a little disappointing. Has zero piping standards built into it. God I wish somebody would create something for real layouts. Piping is so difficult in sketch up. Wake up Trimble
                                            • 2 / 3
