    SU upgrade to 8.0.4811 (Maintenance 1)
    108 Posts 42 Posters 41.4k Views 42 Watching
    • GaieusG
      Ah, OK, thanks, I understand the difference now. As I said, I am (also) planning to test this on my 32 bit OS (I have some pretty heavy models with over a million polys and such - even without entourage)
      • Bob JamesB
        Bob James
        @spence said:
        So, I just installed DivX and gave it a whirl, awesome, it worked so slick and the export was very fast. It looked super good.
        If anyone would like to try, check out the difference between codecs like the default (I thinks it's Sorenson) and DivX. DivX is so much smoother, no where near as much jitter. http://www.divx.com/DivX
        Which DivX codec: MEV, H264, AAC, AVI ?
        • Al HartA
          Al Hart
          Regarding using LargeAddressAware on 32 bit machines.
          I found out how to do this, See: LargeAddressAware Thread
          Al Hart
          IRender nXt from Render Plus
          • StinkieS
            Stinkie
            Mmm ... LAA + Vray ... Exporting large images fixed ... Looks like a useful update.
            • spenceS
              spence
              Bob,
              Not entirely sure. I just downloaded the free DivX (Not the Pro) and installed the Codec Pack 1.0. I set it to export an .AVI, but I'm not sure which codec it uses. I don't believe I'm able to change what codec because I'm not using the Pro version. I hope that answers your question.
              Spence
              • Bob JamesB
                Bob James
                Thanks, Spence: I'll give it a try
                • honoluludesktopH
                  honoluludesktop
                  Doesn't DivX require a DivX player? Will it work with the WinMedia Player?
                  • PixeroP
                    Pixero
                    List of default codecs in Windows media player: http://support.microsoft.com/kb/899113
                    Everything else will need a special codec download.
                    As of DivX there is also the free Xvid. Still a codec is needed to play.
                    • GaieusG
                      There's absolutely no difference between the free and pro versions in this case (since version 6, they can export animation exactly the same way).
                      If it does not work, there must be something else. To check if it does work, set the codec to something else than Cinepack. Export something (just a couple of frames) and open the export options again. If it did not change back to Cinepack, it works.
                      (I still like to export as image sequence better. I generally export at a double size then I batch resize them with some better antialiasing than what SU has and make the movie of the images - more control, more options, nicer output - but double/triple as much time to accomplish)
                      • PixeroP
                        Pixero
                        Plus, if anything goes wrong, like a crash, with images you can just continue where you left of while for a movie export you'd have to start from the beginning.
                        • GaieusG
                          Yes, exactly. And although not an excellent movie, this technique also allows me to use some special effects between the different parts like below.
                          Phases of an excavation
                          [flash=450,380:4adfvfw1]http://www.youtube.com/v/bKsEpF1Neh0?fs=1&hl=en_US[/flash:4adfvfw1]
                          • K
                            Khai
                            for all your video playback needs - http://www.videolan.org/ small, powerful, free, plays just about anything.
                            • PixeroP
                              Pixero
                              Yes VLC Player is great, but what if you want to send a movie to a client?
                              Then you must use something that can be viewed on any computer.
                              • K
                                Khai
                                then all bets are out the window. you can't even guarentee they have the same codec's you do anyway.
                                at that point, your better off boiling your work down to DVD format. that can be played on more than just a computer then...
                                • Bryan KB
                                  I'm still using 7 (free). Is there any compelling reason to go to 8 (free)?
                                  I'm seem to vaguely recall that someone mentioned some features had been removed from 8?
                                  Can anyone fill me in?
                                  • GaieusG
                                    DWG/DXF import was removed from 7.0 and substituted with a plugin in the free version. AFAIK it does not work in SU 8 (free) but I am not sure.
                                    However you can always keep your old version 7 (I have 6, and 😎 and can even run them together at the same time. If nothing else, the shadow bug fix is worth upgrading to v.8 M1.
                                    • Bryan KB
                                      Thanks Gaieus.
                                      I didn't know about the shadow bug. What is that all about?
                                      • GaieusG
                                        When during an animation where shadows are on, the camera is travelling into/out of the shadow, it used to flicker. Just try it out.
                                        Now it's fixed.
                                          RHPLUS
                                          I checked out V-ray for SU8. There is possibility to use HDRI 360 panoramas as a background and source of natural light in scene, but this is very difficult to positionning this panoramas in accordance to real sun position.My proposition is to enlarge options in styles settings and let set 360 HDRI or raster panorama as a background instead of color sky and ground.
                                          • Al HartA
                                            Al Hart
                                            [This is probably getting off-topic]
                                            When 360 HDRIs were "invented" the idea was to stitch together actual photographs to create Panoramic images. But no provision was made in the HDRi format to specify where the sun happened to be when the image was taken, (and what time, date, and location was used for the image). It it were, then we could attempt to rotate the image (automatically) to have the sun direction match the SketchUp sun direction. But, of course, we could not change the date, time or location of the original HDRi image to match the SketchUp sun time. (Since the HDRi image has already been taken)
                                            These backgrounds provide great illumination and reflections. But I, (after admitting to by prejudice in this matter), think that SketchUp should leave the interface and rendering of HDRi backgrounds to the add-on renderers.
                                            HDRI rendering
                                            http://wiki.renderplus.com/images/thumb/8/83/Final_HDRi_sky.jpg/550px-Final_HDRi_sky.jpg
                                            Original SketchUp Model
                                            http://wiki.renderplus.com/images/thumb/6/61/HDRi_-_Airstream.jpg/450px-HDRi_-_Airstream.jpg
                                            Al Hart
                                            • 5 / 6
