    [Plugin] UV Toolkit
    377 Posts 86 Posters 311.4k Views 86 Watching
    • I Offline
      irvinekagiwa
      can't use your plug in this error appears Error Loading File tt_uv_toolkit_2.rb
      no such file to load -- TT_Lib2/core.rb
        Triangulation is probably a good solution to deal with render engines. Maybe I should add an option to triangulate (soft/smooth the new faces) to the UV memory tool...
          Irvine,
          Please, go back to the first post (where you downloaded the plugin) and follow the link to the TT_Lib library. You will need to install that, too.
          Not a bad idea (although there are triangulating plugins available). However I had no issues with it without the triangulation (where it was not needed) otherwise (testing in Twilight and Thea only)
          I would be more interested in that sneak preview of UV Toolkit 3 (with the copy > paste function from other geometry). I have now a project where there are vaults and domes of the same kind but completely different sizes/distortions...
            v2.2 - I'm wrapping it up. πŸ˜„
              Well, I answered your PM (that it is not that bloody urgent yet) but if it is not that much of a work...
              πŸ˜‰
                Ah - you need to transfer UVs between whole surfaces, not use individual faces... ?
                  Yes. I guess(ed) the plugin would work that way, too.
                  Currently I (sort of) "copy" (or "memorize") the UV's on a mesh and then restore them. In my thoughts, it would work the same way with the improved UV Tools just it could (also) transfer these co-ordinates from one mesh to the other.
                  Sometimes you can quite easily apply a material to a certain shape but if you modify it further, it is not easy. Then here is a quick (and rather dirty) example. I will have all different shapes (tapered and distorted) vaults that are derived from the same, quite regular shape. If I texture each separately, it will take forever.
                  But even a better example: this way you could easily apply a texture to a flat (yet subdivided) (sur-)face then copy the UV's and apply it to a completely modified mesh.
                    Copy from one mesh to another is more challenging.
                    UV copy/paste only works on per quad-face.
                    If you have a mapped mesh, then use the UV Memory function to store the UVs - then you can make a copy of that mesh - modify it (as long as you don't erase/recreate the faces and finally use the UV Restore function.
                    Copy from a mesh to another would require the mesh to have the same structure, same number of faces etc. The challenge is trying to match it all up.
                    hmmm...
                      Well yes, as the plugin currently works (also), it is obvious. But as I explained, I'll have to finish the untextured model first and then texture it.
                      This method would require to re-model each vault. In my above example, the two vaults are identical in face count and all. So with "my version" I could (re-)texture the whole thing any time by texturing the "regular" one and then transfer the co-ordinates to the other one.
                      But of course, if it is a no-go, I won't insist (somehow I thoughtyour unpublished beta worked that way)
                        It's not a complete go. But it may not be part of the next release. ...will see... Would be a very useful tool.
                          Definitely. And thanks for listening!
                          πŸ˜„
                          (We could add a topic next to "Google is listening" like "ThomThom is listening")
                          πŸ˜„
                            Or even "Gaieus is pestering" maybe?
                              I am only doing it for the sake of the community (i.e. squeezing everything out of Thom in order that we have the greatest UV plugin ever!)
                              πŸ˜„
                                I'll agree on the UV toolkit being excellent but don't forget he needs to concentrate on Bezier Patch for me.
                                Now i need to return to baking the world biggest cookie.....for Thom.....my pal...... πŸ‘
                                  Ro33y
                                  thanks a lot thom!! πŸ‘
                                  very usefull... β˜€
                                    robert111
                                    why uv toolkit , no work with me, i have make uv toolkit (2.1.0) and TT_Lib2 (v2.4.0) in sketchup / plugin but i dont find uv toolkit in my plugin
                                    is the same problem with sketchup 7 and 8
                                    plz i need solution for this problem
                                    thanks
                                      Windows or OSX? Can you post a screenshot of where you placed the files?
                                      Any error messages?
                                        robert111
                                        thanks thomthom
                                        i have uv toolkit and not toolkit2
                                          robert111
                                          i have windows xp pack 3
                                            I'm guessing you put all the content of the TT_Lib2 folder directly into the plugins folder?
                                            Have a look at the footprint description of TT_Lib2 - towards the bottom of the first post.
                                            • 18
                                            • 19
                                            • 5 / 19
