    [Plugin] UV Toolkit
    377 Posts 86 Posters 298.7k Views 86 Watching
      @gaieus said:
      Richard,
      Indeed UV Toolkit 2 only works properly if the number/shape of the initial faces is the same as those of the end result.
      If during a distortion operation faces get subdivided further, it fails. You can pre-triangulate your faces first if needed however.
      I found that after I manipulated my mesh, it rendered properly in Twilight and Thea (neither of which "likes" distorted textures AFAIK) so I thought the plugin fixes texture distortion.
      You mean when using UV Memory?
      That doesn't fix anything - in fact, it doesn't reapply distorted textures to triangles, they end up as skewed textures. Though, if you have a dense triangulated mesh you probably don't see the artefacts.
        Well, I used triangulated faces here and it re-applied the texture perfectly:
        http://forums.sketchucation.com/viewtopic.php?p=300361#p300361
        (skp also added in that post)
          And it also renders the twisted/bent "column" correctly (all faces are triangulated)
          • I Offline
            irvinekagiwa
            can't use your plug in this error appears Error Loading File tt_uv_toolkit_2.rb
            no such file to load -- TT_Lib2/core.rb
              Triangulation is probably a good solution to deal with render engines. Maybe I should add an option to triangulate (soft/smooth the new faces) to the UV memory tool...
                Irvine,
                Please, go back to the first post (where you downloaded the plugin) and follow the link to the TT_Lib library. You will need to install that, too.
                Not a bad idea (although there are triangulating plugins available). However I had no issues with it without the triangulation (where it was not needed) otherwise (testing in Twilight and Thea only)
                I would be more interested in that sneak preview of UV Toolkit 3 (with the copy > paste function from other geometry). I have now a project where there are vaults and domes of the same kind but completely different sizes/distortions...
                  v2.2 - I'm wrapping it up. πŸ˜„
                    Well, I answered your PM (that it is not that bloody urgent yet) but if it is not that much of a work...
                    πŸ˜‰
                      Ah - you need to transfer UVs between whole surfaces, not use individual faces... ?
                        Yes. I guess(ed) the plugin would work that way, too.
                        Currently I (sort of) "copy" (or "memorize") the UV's on a mesh and then restore them. In my thoughts, it would work the same way with the improved UV Tools just it could (also) transfer these co-ordinates from one mesh to the other.
                        Sometimes you can quite easily apply a material to a certain shape but if you modify it further, it is not easy. Then here is a quick (and rather dirty) example. I will have all different shapes (tapered and distorted) vaults that are derived from the same, quite regular shape. If I texture each separately, it will take forever.
                        But even a better example: this way you could easily apply a texture to a flat (yet subdivided) (sur-)face then copy the UV's and apply it to a completely modified mesh.
                          Copy from one mesh to another is more challenging.
                          UV copy/paste only works on per quad-face.
                          If you have a mapped mesh, then use the UV Memory function to store the UVs - then you can make a copy of that mesh - modify it (as long as you don't erase/recreate the faces and finally use the UV Restore function.
                          Copy from a mesh to another would require the mesh to have the same structure, same number of faces etc. The challenge is trying to match it all up.
                          hmmm...
                            Well yes, as the plugin currently works (also), it is obvious. But as I explained, I'll have to finish the untextured model first and then texture it.
                            This method would require to re-model each vault. In my above example, the two vaults are identical in face count and all. So with "my version" I could (re-)texture the whole thing any time by texturing the "regular" one and then transfer the co-ordinates to the other one.
                            But of course, if it is a no-go, I won't insist (somehow I thoughtyour unpublished beta worked that way)
                              It's not a complete go. But it may not be part of the next release. ...will see... Would be a very useful tool.
                                Definitely. And thanks for listening!
                                πŸ˜„
                                (We could add a topic next to "Google is listening" like "ThomThom is listening")
                                πŸ˜„
                                • Rich O BrienR Online
                                  Or even "Gaieus is pestering" maybe?
                                    I am only doing it for the sake of the community (i.e. squeezing everything out of Thom in order that we have the greatest UV plugin ever!)
                                    πŸ˜„
                                      I'll agree on the UV toolkit being excellent but don't forget he needs to concentrate on Bezier Patch for me.
                                      Now i need to return to baking the world biggest cookie.....for Thom.....my pal...... πŸ‘
                                        Ro33y
                                        thanks a lot thom!! πŸ‘
                                        very usefull... β˜€
                                          robert111
                                          why uv toolkit , no work with me, i have make uv toolkit (2.1.0) and TT_Lib2 (v2.4.0) in sketchup / plugin but i dont find uv toolkit in my plugin
                                          is the same problem with sketchup 7 and 8
                                          plz i need solution for this problem
                                          thanks
                                            Windows or OSX? Can you post a screenshot of where you placed the files?
                                            Any error messages?
                                            • 11
                                            • 18
                                            • 19
                                            • 9 / 19
