    [Plugin] Zorro2 (beta)
    314 Posts 154 Posters 365.1k Views 154 Watching
      JHearne
      Hi there!
      I just downloaded your Zorro2 plugin, I don't have a clue how to install it on my computer! Any advice? πŸ˜„
      • TIGT Online
        @jhearne said:
        Hi there!
        Like most scripts the .rb file is put into the Sketchup Plugins folder.
        When you restart Sketchup you get a new menu item 'Zorro' - for details of where this is and how to use the tool please see the useful .pdf guide, that you can download from the same page that you got the .rb file - i.e. the first post in this thread... πŸ€“
          caarloos82
          THANK YOU FOR YOUR SOFTWARE!!!
          cheers
          carlos
          • W Offline
            Whaat
            cheers
            carlos
            You're very welcome!
              shoeb_cars
              a really needed plugin.......i use it a lot for 3d sections...thanks a ton
              P.S : is it possible to but a component into two diff components without opening it i.e., cutting any component into diff parts, so that to delete the other side of the cut line i dont have to open the component and delete that part.
              that would be an added advantage πŸ‘
                kwaviehoo
                is it unuseful in su8?
                  You men if it is usable?
                  If so, yes it is.
                  • W Offline
                    Whaat
                    Not possible at the moment. Maybe someday.
                      lo.ozn
                      Do you know where I can find and download this plugin????
                      thanks
                      • massimoM Offline
                        massimo Moderator
                        Just at the bottom of the first post.
                          lo.ozn
                          Does anyone know why when trying to slice an entire model at a section plane or trying to do cuts it comes out bug splat error?? Is it maybe for the complexity of the model?
                          any solution will be very appreciated
                          thanks
                            ciudadanochano
                            Sorry I donΒ΄t find the way to make it works. Every time I try it, pops ups a blug splat error..Could anybody help me?
                            thank you all
                            • W Offline
                              Whaat
                              I notice you both are showing older versions of SketchUp (6 and 7). In SU8, some bugs were fixed that result in less crashes for plugins like zorro2. Try upgrading to the free version of SU8 and see if you can get it to work without bugsplats.
                                aferlo
                                sorry to bother but I can't find the download link???
                                thank you for your help
                                  It's at the bottom of the first post in this topic (a red ruby icon)
                                    corderjos
                                    hi I've tried everything, I have a relatively large model which I need to slice, but sketchup crashes after a few minutes of the slicing process. I've tried exploting it to almost having no groups or components (rather complicated task I must say) and it still crashes! Help, anyone?
                                      KU ARCH STUDENT
                                      This thread seems quite old but I'll add what I have found to work in regards to sketchup crashing when attempting to slice a model.
                                      I tried to use the zorro tool on sketchup 8 pro with little luck, but then again I only tried a few times so it could very well be working now. I couldn't figure out what the problem was, and really didn't put too much thought or effort into it. That being said, I have cut some very complex models in Sketchup 7 pro using the zorro slice tool without problems, but when I would try to slice the very same model in SU8 it just would crash as some people have said on here. Anyway, If it crashes in SU8, try SU7 and if that doesn't work chances are it is your model and maybe the way it is organized/layered. Hope that helps a little, SU7 always works for me without fail, larger models can take up to 5 or 10 minutes sometimes, but in the end it always works for me. Awesome tool by the way....
                                      • W Offline
                                        Whaat
                                        Thanks for posting this tip!
                                        • F Offline
                                          function
                                          indeed, I'll keep that in mind, zorro has recently been slicing my SU 8 in half - I'll drop it down to 7 when I need to now!
                                          • brodieB Offline
                                            brodie
                                            This is one of those scripts I only use once in a great while but when you need it, it's a huge time saver. Just used it on SU 8 and it worked great. Thanks,
                                            -Brodie
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 13 / 16
