    [Plugin] Zorro2 (beta)
    314 Posts 154 Posters 446.8k Views 154 Watching
      @kwalkerman said:
      Awesome plugin. Works great with the section plane and with the straight zorro tool.
      I was getting bugsplats when I used the section plane (on very simple models). De-activated another plugin (openstudio), and now it works fine.
      Karen
      Also when using any tool that changes the models entities with instances you need the Outliner to be closed or at least rolled-up - otherwise a known bug in SUp can cause it to crash...
      • DavidBoulderD
        DavidBoulder
        TIG, is this working on SU 8? I'm getting crashes on XP without any other plugins installed.
        David Goldwasser
        OpenStudio Developer
        National Renewable Energy Laboratory
          Works OK for me with the Outliner closed ?
          • DavidBoulderD
            DavidBoulder
            No dialogs open (including Outliner). I even tried disabling Dynamic Components, Sandbox Tools, Solar North, and Photo Textures.
            I'll try again tomorrow after a fresh restart. By the way, same results on SU7.
            Split at section cut seems to work. Just cut tool that crashes.
            David Goldwasser
              Ruby Console Messages ???
              • DavidBoulderD
                DavidBoulder
                No ruby console messages before the crash, but I realized that I wasn't using it correctly. When I used the cut tool I was picking points at the edge of a cube, and I thought I had to pick 3 to define a plane, vs. just two. So here is how I made it crash.
                • draw a rectangle and extrude to a box
                • select the Zorro tool
                • click on one of the top edges of the box
                • next click on the opposing side
                • now click on the same point as above
                • and last, click on the bottom edge on the same side of the box
                screen shot just before crash (when I click at the cursor)
                This crashes it for me. I have a screen shot of what it looks like before the click that causes the crash. There doesn't seem to be anything special about where on the edge of the box I draw my cut lines for the crash to occur. When I use to tool as intended, single cut line beyond the geometry, then everything works fine.
                By the way, what would be really cool new feature for Zorro for me is to have the "slide model at section" create separate groups out of the trimmed parts vs. throwing them away. Could have the new groups named something like "mygroupname_cut". An extra cool feature would be to create the plane at the cutting edge so the new groups are still solid. This would kind of be the anti-outer shell, allowing you to split a volume into two. Even with SketchUp Pro this would still be a useful tool. Right now I can't draw a section plane and split into two groups. I have to create a big box to use as a cutting volume, vs. a more simple cutting plane.
                David Goldwasser
                  sir.sanio
                  @maritozo said:
                  I'm doing it just as the tutorial says
                  first "add section cut face"
                  and the "slice model at section"
                  but even though my model doesn't have any groups, when it is cutting "group #n (29 or 31 most of the times)" the sketch up crashes 😞
                  i've got a deadline in college, really need this to work out!
                  anyone can help?
                  thanks!
                  Same problem here! Can anyone help?
                  Best regards,
                  Sanio
                    sir.sanio
                    @chimbalo said:
                    After a few hours I figure it out how to fix the bug splat, I have a heavy model, every time that I started using the slice tool my model crashed up, I tryed exploding the model, chainging to newer sketch up, etc etc etc. At the end I took all the model and grouped up whith out the cuting plane, after I slice it, and was the solution for the problem, now it doesn't matter how heavy is the file, the plug in ,work fine. sorry for my bad english, I hope is useful for you.
                    Thank You, Sir!
                    That worked for me!!
                    Best regards,
                    Sanio
                      JHearne
                      Hi there!
                      I just downloaded your Zorro2 plugin, I don't have a clue how to install it on my computer! Any advice? πŸ˜„
                        @jhearne said:
                        Hi there!
                        Like most scripts the .rb file is put into the Sketchup Plugins folder.
                        When you restart Sketchup you get a new menu item 'Zorro' - for details of where this is and how to use the tool please see the useful .pdf guide, that you can download from the same page that you got the .rb file - i.e. the first post in this thread... πŸ€“
                        • C
                          caarloos82
                          THANK YOU FOR YOUR SOFTWARE!!!
                          cheers
                          carlos
                          • W
                            Whaat
                            cheers
                            carlos
                            You're very welcome!
                              shoeb_cars
                              a really needed plugin.......i use it a lot for 3d sections...thanks a ton
                              P.S : is it possible to but a component into two diff components without opening it i.e., cutting any component into diff parts, so that to delete the other side of the cut line i dont have to open the component and delete that part.
                              that would be an added advantage πŸ‘
                              • K
                                kwaviehoo
                                is it unuseful in su8?
                                • GaieusG
                                  You men if it is usable?
                                  If so, yes it is.
                                  • W
                                    Whaat
                                    Not possible at the moment. Maybe someday.
                                    • L
                                      lo.ozn
                                      Do you know where I can find and download this plugin????
                                      thanks
                                      • massimoM
                                        massimo Moderator
                                        Just at the bottom of the first post.
                                        • L
                                          lo.ozn
                                          Does anyone know why when trying to slice an entire model at a section plane or trying to do cuts it comes out bug splat error?? Is it maybe for the complexity of the model?
                                          any solution will be very appreciated
                                          thanks
                                          • C
                                            ciudadanochano
                                            Sorry I donΒ΄t find the way to make it works. Every time I try it, pops ups a blug splat error..Could anybody help me?
                                            thank you all
