    [Plugin] Zorro2 (beta)
    314 Posts 154 Posters 446.8k Views 154 Watching
    • L
      lo.ozn
      Do you know where I can find and download this plugin????
      thanks
      • massimoM
        massimo Moderator
        Just at the bottom of the first post.
        • L
          lo.ozn
          Does anyone know why when trying to slice an entire model at a section plane or trying to do cuts it comes out bug splat error?? Is it maybe for the complexity of the model?
          any solution will be very appreciated
          thanks
          • C
            ciudadanochano
            Sorry I don´t find the way to make it works. Every time I try it, pops ups a blug splat error..Could anybody help me?
            thank you all
            • W
              Whaat
              I notice you both are showing older versions of SketchUp (6 and 7). In SU8, some bugs were fixed that result in less crashes for plugins like zorro2. Try upgrading to the free version of SU8 and see if you can get it to work without bugsplats.
                aferlo
                sorry to bother but I can't find the download link???
                thank you for your help
                • GaieusG
                  It's at the bottom of the first post in this topic (a red ruby icon)
                  • C
                    corderjos
                    hi I've tried everything, I have a relatively large model which I need to slice, but sketchup crashes after a few minutes of the slicing process. I've tried exploting it to almost having no groups or components (rather complicated task I must say) and it still crashes! Help, anyone?
                    • K
                      KU ARCH STUDENT
                      This thread seems quite old but I'll add what I have found to work in regards to sketchup crashing when attempting to slice a model.
                      I tried to use the zorro tool on sketchup 8 pro with little luck, but then again I only tried a few times so it could very well be working now. I couldn't figure out what the problem was, and really didn't put too much thought or effort into it. That being said, I have cut some very complex models in Sketchup 7 pro using the zorro slice tool without problems, but when I would try to slice the very same model in SU8 it just would crash as some people have said on here. Anyway, If it crashes in SU8, try SU7 and if that doesn't work chances are it is your model and maybe the way it is organized/layered. Hope that helps a little, SU7 always works for me without fail, larger models can take up to 5 or 10 minutes sometimes, but in the end it always works for me. Awesome tool by the way....
                      • W
                        Whaat
                        Thanks for posting this tip!
                        • F
                          function
                          indeed, I'll keep that in mind, zorro has recently been slicing my SU 8 in half - I'll drop it down to 7 when I need to now!
                          • brodieB
                            brodie
                            This is one of those scripts I only use once in a great while but when you need it, it's a huge time saver. Just used it on SU 8 and it worked great. Thanks,
                            -Brodie
                              joi89
                              Just get to know about this plug-in.. will try to use.. thanks a lot..
                              • L
                                lw252kent
                                Hello.
                                Trying to download the Zorro 2.0 plug in from the initial link listed, but having difficulty. It says have the option to open or save. Tried both yet laptop says that doesnt recognise the format in which to open the programme?! Does anyone know how to download it?
                                Regards,
                                Lauren
                                • GaieusG
                                  Hi Lauren,
                                  The format is *.rb ("ruby") and you actually do not need to open it with anything but simply save the file in this folder:
                                  C:\Program Files\Google\Google SketchUp 8\Plugins\
                                  If you want to open it, it is actually a "simple" text file with this *.rb extension so use Notepad (coming with Windows by default). Do NOT use a Word processor like MS World as it adds some special characters to line ends and such.
                                  • N
                                    nickdk
                                    Is it likely that the "bug splat" error will be corrected in the Zorry plugin? I absolutely love the plugin but it's always a challenge to make it work without too many "splats" :S ? 😄
                                    • C
                                      ckho1985
                                      blug splat!!!! arrrrgh (banging my head...)
                                      would be a most-wanted tool if bug is fixed on slicing a section plane.
                                      • N
                                        natmonday
                                        This plug-in is just what I need. However I am getting a "bug splat" everytime i try to use it... any suggestions??
                                        @whaat said:
                                        Time for an update of Zorro. I think this release is much more polished than the first one. Plus, you now finally have the ability to render section cut views.
                                        New Features:
                                        -made cuts work with parallel projection views
                                        -added slice model at section plane (right click on a section plane for context menu)
                                        -added nested cuts using CTRL modifier
                                        -improved precision of cuts
                                        Somes notes on this release:
                                        • It is recommended to use 'Slice model at Section' on a backup of your SKP file. It is a destructive process.
                                        • Cutting through nested components results in creation of many unique components
                                        • Some code was used with permission from TIG's SectionCutFace script to create a cutting plane from a section plane. Thanks!
                                        • Script should work for older versions of SU and also on Mac systems
                                        I am calling this a beta version so please post any bugs or requests in this thread. Enjoy!
                                        EDIT: Updated version now attached which should fix the problems that have been reported. Also added tutorial.
                                        Whaat
                                        • E
                                          erentumer
                                          when I try to slice from section plane sketchup turns off does anyone know why it closes itself?
                                          • C
                                            chango70
                                            I think it crash with nested components and groups. I use it only when I've exploded everything.
                                            • 11
                                            • 15
                                            • 16
                                            • 9 / 16
