    [Plugin] UV Toolkit
    377 Posts 86 Posters 320.2k Views 86 Watching
      @solo said:
      http://media.bigoo.ws/content/gif/smiles/smiles_349.gif
      Rich? 😲 πŸ˜†
        No, Mike, i'm more....
        http://www.english-blogs.com/wp-content/uploads/2008/10/drunk-man-falls-hurts-head-hoboken.jpg
        • mitcorbM Offline
          mitcorb
          Mike???
            Yeah, Mike
              Well that's a new nick name... πŸ˜’
              • mitcorbM Offline
                mitcorb
                And ThomThom left you like this on your last outing?
                Edit: oops, in case that doesn't translate culturally, no insinuations intended.
                  Unfortunately TT was not there at our last outing - but otherwise it was something like that...
                  πŸ˜’
                  Back to-topic: fantastic tool, Thom, thanks a lot! I will now have to find another (improved) trick to do my arches...
                    I have something up my sleeves for that as well, but it's in it's third re-coding. (...or was that fourth...) to get it working right.
                      Just let me know when you need a beta forum!
                      πŸ˜‰
                      • erikBE Offline
                        erikB
                        TT this ruby is amazing !! πŸ‘
                        Will be very usefull.
                        erikB
                          Ben Ritter
                          Thank you so much Thomas.
                          • N Offline
                            nektares
                            Thanks for this one ThomThom it makes alot easier several uvmapping situations! this is great! Thanks again!
                            uvtest
                            • shuraS Offline
                              shura
                              Yes very useful indeed, thank you Thomas!
                              The Remember/Restore function is very innovative too. I tried to make a pillow but it didn't work (back). Maybe because I also edited by using Move tool on single vertices?
                              However, with only Smoove it works well (front).
                                It didn't restore properly after using Move, but Smoove worked fine?
                                How how odd... I really don't know why that would be. I'll try and see if I can reproduce it.
                                • shuraS Offline
                                  shura
                                  I've reproduced the same process with a less complex geometry and it seems to work well (!).
                                  When it did not work before, I have fiddled a lot with the vertices - or maybe the memory got lost when saving the file?
                                    If you erase/recreate geometry you will loose mapping data.
                                    • shuraS Offline
                                      shura
                                      Ah, that sounds plausible. Not sure what I did wrong, but I guess must have been something like that.
                                      thank you Thomas
                                      • Alan FraserA Offline
                                        Alan Fraser
                                        Looks like a very useful script, Thom...but I'm having problems loading the V2. The ruby is asking for core.rb in TT_Lib2. Is this different from the one in TT_UV_Toolkit; and if so, where is the Lib2 folder hanging out? Did that install as part of an earlier offering?
                                        3D Figures
                                          Requirements
                                          * SketchUp 7 or newer - ( Other versions untested )
                                          * [**TT_Lib2**](http://forums.sketchucation.com/viewtopic.php?f) (v2.4.0)
                                          Yeah, it requires Thomthom's Menu
                                            Alan Fraser
                                            Thanks Rich...thought it would be something like that. Don't know how I missed that line.
                                            3D Figures
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 15 / 19
