    [Plugin] UV Toolkit
    377 Posts 86 Posters 415.1k Views 86 Watching
    • soloS
      http://media.bigoo.ws/content/gif/smiles/smiles_349.gif
      You da man, will test this tomorrow.
        Rich? 😲 πŸ˜†
          No, Mike, i'm more....
          http://www.english-blogs.com/wp-content/uploads/2008/10/drunk-man-falls-hurts-head-hoboken.jpg
          • mitcorbM
            mitcorb
            Mike???
              Yeah, Mike
                Well that's a new nick name... πŸ˜’
                • mitcorbM
                  mitcorb
                  And ThomThom left you like this on your last outing?
                  Edit: oops, in case that doesn't translate culturally, no insinuations intended.
                  • GaieusG
                    Unfortunately TT was not there at our last outing - but otherwise it was something like that...
                    πŸ˜’
                    Back to-topic: fantastic tool, Thom, thanks a lot! I will now have to find another (improved) trick to do my arches...
                      I have something up my sleeves for that as well, but it's in it's third re-coding. (...or was that fourth...) to get it working right.
                      • GaieusG
                        Just let me know when you need a beta forum!
                        πŸ˜‰
                        • erikBE
                          erikB
                          TT this ruby is amazing !! πŸ‘
                          Will be very usefull.
                          erikB
                          • B
                            Ben Ritter
                            Thank you so much Thomas.
                            • N
                              nektares
                              Thanks for this one ThomThom it makes alot easier several uvmapping situations! this is great! Thanks again!
                              uvtest
                              • shuraS
                                shura
                                Yes very useful indeed, thank you Thomas!
                                The Remember/Restore function is very innovative too. I tried to make a pillow but it didn't work (back). Maybe because I also edited by using Move tool on single vertices?
                                However, with only Smoove it works well (front).
                                  It didn't restore properly after using Move, but Smoove worked fine?
                                  How how odd... I really don't know why that would be. I'll try and see if I can reproduce it.
                                  • shuraS
                                    shura
                                    I've reproduced the same process with a less complex geometry and it seems to work well (!).
                                    When it did not work before, I have fiddled a lot with the vertices - or maybe the memory got lost when saving the file?
                                      If you erase/recreate geometry you will loose mapping data.
                                      • shuraS
                                        shura
                                        Ah, that sounds plausible. Not sure what I did wrong, but I guess must have been something like that.
                                        thank you Thomas
                                        • Alan FraserA
                                          Alan Fraser
                                          Looks like a very useful script, Thom...but I'm having problems loading the V2. The ruby is asking for core.rb in TT_Lib2. Is this different from the one in TT_UV_Toolkit; and if so, where is the Lib2 folder hanging out? Did that install as part of an earlier offering?
                                          3D Figures
                                            Requirements
                                            * SketchUp 7 or newer - ( Other versions untested )
                                            * [**TT_Lib2**](http://forums.sketchucation.com/viewtopic.php?f) (v2.4.0)
                                            Yeah, it requires Thomthom's Menu
                                            • 18
                                            • 19
                                            • 8 / 19
