    [Plugin] UV Toolkit
    377 Posts 86 Posters 391.2k Views 86 Watching
      Yeah, Mike
        Well that's a new nick name... πŸ˜’
        • mitcorbM Offline
          mitcorb
          And ThomThom left you like this on your last outing?
          Edit: oops, in case that doesn't translate culturally, no insinuations intended.
            Unfortunately TT was not there at our last outing - but otherwise it was something like that...
            πŸ˜’
            Back to-topic: fantastic tool, Thom, thanks a lot! I will now have to find another (improved) trick to do my arches...
              I have something up my sleeves for that as well, but it's in it's third re-coding. (...or was that fourth...) to get it working right.
                Just let me know when you need a beta forum!
                πŸ˜‰
                • erikBE Offline
                  erikB
                  TT this ruby is amazing !! πŸ‘
                  Will be very usefull.
                  erikB
                    Ben Ritter
                    Thank you so much Thomas.
                    • N Offline
                      nektares
                      Thanks for this one ThomThom it makes alot easier several uvmapping situations! this is great! Thanks again!
                      uvtest
                      • shuraS Offline
                        shura
                        Yes very useful indeed, thank you Thomas!
                        The Remember/Restore function is very innovative too. I tried to make a pillow but it didn't work (back). Maybe because I also edited by using Move tool on single vertices?
                        However, with only Smoove it works well (front).
                          It didn't restore properly after using Move, but Smoove worked fine?
                          How how odd... I really don't know why that would be. I'll try and see if I can reproduce it.
                          • shuraS Offline
                            shura
                            I've reproduced the same process with a less complex geometry and it seems to work well (!).
                            When it did not work before, I have fiddled a lot with the vertices - or maybe the memory got lost when saving the file?
                              If you erase/recreate geometry you will loose mapping data.
                              • shuraS Offline
                                shura
                                Ah, that sounds plausible. Not sure what I did wrong, but I guess must have been something like that.
                                thank you Thomas
                                • Alan FraserA Offline
                                  Alan Fraser
                                  Looks like a very useful script, Thom...but I'm having problems loading the V2. The ruby is asking for core.rb in TT_Lib2. Is this different from the one in TT_UV_Toolkit; and if so, where is the Lib2 folder hanging out? Did that install as part of an earlier offering?
                                  3D Figures
                                    Requirements
                                    * SketchUp 7 or newer - ( Other versions untested )
                                    * [**TT_Lib2**](http://forums.sketchucation.com/viewtopic.php?f) (v2.4.0)
                                    Yeah, it requires Thomthom's Menu
                                      Alan Fraser
                                      Thanks Rich...thought it would be something like that. Don't know how I missed that line.
                                      3D Figures
                                        Requirements
                                        No - ThomThom's menu is not required. TT_Lib2 is. Two separate things. ThomThom's menu is just an optional plugin you install if you want to group all my plugins' menus under one main menu.
                                          Sorry typo I meant to say Thomthom's Library.
                                          Oh the shame!
                                            That'll be ten Hail Marys.
                                            • 18
                                            • 19
                                            • 8 / 19
