    [Plugin] UV Toolkit
    377 Posts 86 Posters 398.5k Views 86 Watching
    • N
      notareal
      @thomthom said:
      UV Memory (2.1.0)
      Very Experimental!
      Use only on triangles and quad-faces.
      I am sold already... looking good.
      • soloS
        http://media.bigoo.ws/content/gif/smiles/smiles_349.gif
        You da man, will test this tomorrow.
          Rich? ๐Ÿ˜ฒ ๐Ÿ˜†
            No, Mike, i'm more....
            http://www.english-blogs.com/wp-content/uploads/2008/10/drunk-man-falls-hurts-head-hoboken.jpg
            • mitcorbM
              mitcorb
              Mike???
                Yeah, Mike
                  Well that's a new nick name... ๐Ÿ˜’
                  • mitcorbM
                    mitcorb
                    And ThomThom left you like this on your last outing?
                    Edit: oops, in case that doesn't translate culturally, no insinuations intended.
                    • GaieusG
                      Unfortunately TT was not there at our last outing - but otherwise it was something like that...
                      ๐Ÿ˜’
                      Back to-topic: fantastic tool, Thom, thanks a lot! I will now have to find another (improved) trick to do my arches...
                        I have something up my sleeves for that as well, but it's in it's third re-coding. (...or was that fourth...) to get it working right.
                        • GaieusG
                          Just let me know when you need a beta forum!
                          ๐Ÿ˜‰
                          • erikBE
                            erikB
                            TT this ruby is amazing !! ๐Ÿ‘
                            Will be very usefull.
                            erikB
                            • B
                              Ben Ritter
                              Thank you so much Thomas.
                              • N
                                nektares
                                Thanks for this one ThomThom it makes alot easier several uvmapping situations! this is great! Thanks again!
                                uvtest
                                • shuraS
                                  shura
                                  Yes very useful indeed, thank you Thomas!
                                  The Remember/Restore function is very innovative too. I tried to make a pillow but it didn't work (back). Maybe because I also edited by using Move tool on single vertices?
                                  However, with only Smoove it works well (front).
                                    It didn't restore properly after using Move, but Smoove worked fine?
                                    How how odd... I really don't know why that would be. I'll try and see if I can reproduce it.
                                    • shuraS
                                      shura
                                      I've reproduced the same process with a less complex geometry and it seems to work well (!).
                                      When it did not work before, I have fiddled a lot with the vertices - or maybe the memory got lost when saving the file?
                                        If you erase/recreate geometry you will loose mapping data.
                                        • shuraS
                                          shura
                                          Ah, that sounds plausible. Not sure what I did wrong, but I guess must have been something like that.
                                          thank you Thomas
                                          • Alan FraserA
                                            Alan Fraser
                                            Looks like a very useful script, Thom...but I'm having problems loading the V2. The ruby is asking for core.rb in TT_Lib2. Is this different from the one in TT_UV_Toolkit; and if so, where is the Lib2 folder hanging out? Did that install as part of an earlier offering?
                                            3D Figures
                                            • 18
                                            • 19
                                            • 8 / 19
