    [Plugin] UV Toolkit
    377 Posts 86 Posters 391.2k Views 86 Watching
    • jason_marantoJ Offline
      jason_maranto
      You are officially my hero!
      Best,
      Jason.
      • N Offline
        notareal
        @thomthom said:
        UV Memory (2.1.0)
        Very Experimental!
        Use only on triangles and quad-faces.
        I am sold already... looking good.
        • soloS Offline
          http://media.bigoo.ws/content/gif/smiles/smiles_349.gif
          You da man, will test this tomorrow.
            Rich? ๐Ÿ˜ฒ ๐Ÿ˜†
              No, Mike, i'm more....
              http://www.english-blogs.com/wp-content/uploads/2008/10/drunk-man-falls-hurts-head-hoboken.jpg
              • mitcorbM Offline
                mitcorb
                Mike???
                  Yeah, Mike
                    Well that's a new nick name... ๐Ÿ˜’
                    • mitcorbM Offline
                      mitcorb
                      And ThomThom left you like this on your last outing?
                      Edit: oops, in case that doesn't translate culturally, no insinuations intended.
                        Unfortunately TT was not there at our last outing - but otherwise it was something like that...
                        ๐Ÿ˜’
                        Back to-topic: fantastic tool, Thom, thanks a lot! I will now have to find another (improved) trick to do my arches...
                          I have something up my sleeves for that as well, but it's in it's third re-coding. (...or was that fourth...) to get it working right.
                            Just let me know when you need a beta forum!
                            ๐Ÿ˜‰
                            • erikBE Offline
                              erikB
                              TT this ruby is amazing !! ๐Ÿ‘
                              Will be very usefull.
                              erikB
                                Ben Ritter
                                Thank you so much Thomas.
                                • N Offline
                                  nektares
                                  Thanks for this one ThomThom it makes alot easier several uvmapping situations! this is great! Thanks again!
                                  uvtest
                                  • shuraS Offline
                                    shura
                                    Yes very useful indeed, thank you Thomas!
                                    The Remember/Restore function is very innovative too. I tried to make a pillow but it didn't work (back). Maybe because I also edited by using Move tool on single vertices?
                                    However, with only Smoove it works well (front).
                                      It didn't restore properly after using Move, but Smoove worked fine?
                                      How how odd... I really don't know why that would be. I'll try and see if I can reproduce it.
                                      • shuraS Offline
                                        shura
                                        I've reproduced the same process with a less complex geometry and it seems to work well (!).
                                        When it did not work before, I have fiddled a lot with the vertices - or maybe the memory got lost when saving the file?
                                          If you erase/recreate geometry you will loose mapping data.
                                          • shuraS Offline
                                            shura
                                            Ah, that sounds plausible. Not sure what I did wrong, but I guess must have been something like that.
                                            thank you Thomas
                                            • 18
                                            • 19
                                            • 7 / 19
