    [Plugin] MaterialConsolidator
    59 Posts 32 Posters 45.7k Views 32 Watching
    • soloS Offline
      Another awesome and needed tool, any possibility to have it available in the 'tools' drop down menu? as typing into ruby consol everytime will require me to remember the command and I have already forgotten it.
        rv1974
        Awesome! It's time to clean those Augean stables.
          d12dozr
          Sweet! Thanks, TIG!
          +1
          http://goo.gl/f7ooYh
            Here's v1.1 http://forums.sketchucation.com/viewtopic.php?p=295290#p295290
            It now has 'Material Consolidator' under the 'Tools' menu...
            • Bob JamesB Offline
              Bob James
              Oh, YES!!
              Thank you, TIG
                rv1974
                Hi TIG!
                I have some important suggestion. The majority of people working in the 3D field use some prefixes in the mats\layers\camera names. It's extremely helpful to differ my stuff from the others.I for example name all my assets in this way: zzz_blahblah. And everything is inserted in the initial template file.
                So what I'm asking for is ability to set the default nameprioty directly in the ruby file
                itself (just to set up it once and forget). In my case zzz_* formula would be dominant.
                What do you think?
                  rv1974
                  At the moment the first material in the database is used in preference to any other matches [the names are not considered just the position in the list], so if you have 'zzz_Material', 'zzz_Material1' and 'xxx_Material99' that are all exact matching 'clones' and 'zzz_Material' is the first one then everything becomes 'zzz_Material' and the others are purged...
                  I can't see how we would use 'prefixes' to sort materials [at the moment, as I said, the name is ignored and its 'order of being created' is used] 😕
                    Here's v1.2 http://forums.sketchucation.com/viewtopic.php?p=295290#p295290
                    The listing and sorting algorithms have been optimized for speed and command-line/console progress messages added...
                      rv1974
                      @tig said:
                      rv1974
                      order of being created is already a nice thing. The workaround is to embed a simple planes matrix with user common used materials applied into initial template.
                      Thank you.
                        rocorona
                        @tig said:
                        @gaieus said:
                        @tig said:
                        These are:-
                        materialType
                        color RGB
                        transparency [alpha]
                        What is a material "type"?
                        I feel I'm missing something basilar, but I can't find this in the "modify material" window.
                          @rocorona said:
                          @tig said:
                          @gaieus said:
                          @tig said:
                          These are:-
                          materialType
                          color RGB
                          The materialType is accessible via the API - it returns values [0/1/2] depending on if the material is simply a 'plain-color', has a 'texture' or it has a texture and it has been 'colorized'... that's all... http://code.google.com/apis/sketchup/docs/ourdoc/material.html#materialType
                            rocorona
                            TIG, "thanks" for your reply, and "thanks" for your great and valuable work!
                            • E Offline
                              Ecuadorian
                              I was thinking about this yesterday, as using FormFonts objects bloats my files with duplicate materials.
                              Thanks, TIG! 👍
                              -Miguel Lescano
                                Here's v1.3 http://forums.sketchucation.com/viewtopic.php?p=295290#p295290
                                It is now wrapped into its own class 'MaterialConsolidator'.
                                • H Offline
                                  headshot
                                  GR8 !!!
                                  TY.
                                    Staatsfeind
                                    thank you for this useful tool !
                                    but one question:
                                    how do i delete unused materials that result from objects imported by
                                    the warehouse and which i dont use anymore?
                                    to be more exactly, i tried out several warehouse objects to fit my needs
                                    and mixed some of them. at the end i got 50+ textures loaded but maybe only
                                    15 are in use. deleting all by hand would take some time.
                                    did i get something wrong ?
                                    cheers
                                    http://www.frenchtouchstudio.com
                                    manager/modeler
                                      but one question:
                                      cheers
                                      'Used' Materials are not 'purged'...
                                      Erase all unwanted Component Instances OR go to the Component Browser and find the unwanted component, right-click its icon and pick 'Delete' - this removes it from the model/browser/data-base.
                                      OR if there are no Instances left use Component Browser > Purge... pop-out to remove any unused Components
                                      It's recommended that you also use Layer Browser > Purge... pop-out to remove any unused Layers [that might have been associated with Components that you have just purged]
                                      NOW use Material Browser > Purge... pop-out to remove any unused Materials [that might have been associated with Components that you have just purged]
                                      OR simply use Model Info > Statistics > Purge Unused... to purge them all in one go - this also includes a purge of unused Styles.
                                      OR try my 'Purge' script which is similar but it lets you choose which kinds of thing to purge, and makes a 'report' of what's gone too...
                                        Staatsfeind
                                        hell you react fast ! ;D
                                        thx for your answer, will give it a try.
                                        manager/modeler
                                        • brodieB Offline
                                          brodie
                                          Great plugin, thanks TIG. Not one I'll likely use very often but I just had need of it and it worked perfectly.
                                          -Brodie
                                            DavidXJ98
                                            Thank you for this plugin... it's quite useful.
                                            • 1 / 3
