    [Plugin] MaterialConsolidator
    59 Posts 32 Posters 48.0k Views 32 Watching
      Thanks TIG for the explanation, it makes sense now. β˜€
      Ah, and before I forget; many thanks for the plugin, too!
        autarchos
        thank you so much TIG! this is a blessing. i can't tell you how many times i've downloaded models from the 3d warehouse which seem to exponentially multiply the list of materials already in my model.
        • Didier BurD Offline
          Didier Bur
          Hi TIG,
          Are the faces that were painted with a "removed" material repainted with the consolidated one ?
          I mean suppose you have 2 faces, one is painted with material m1 and the other with material m2.
          If the materials have matching properties, one of them is purged, say m2.
          Does the face painted with m2 repainted with the remaining m1 material ?
          Thanks for all your work,
          DB
            @didier bur said:
            Hi TIG,
            Yes!
            It ensures that only one material of the exact same 'properties' is used - this means that if m1==m2 then everything*** that used m2 now has m1 and m2 is purged if m1==m2==m3 etc m2 and m3 go and everything is m1...
            ---'everything' means all faces, edges, groups and component-instances etc... in the model and inside definitions too...
              Excellent! πŸ‘ πŸ‘
              • soloS Offline
                Another awesome and needed tool, any possibility to have it available in the 'tools' drop down menu? as typing into ruby consol everytime will require me to remember the command and I have already forgotten it.
                • R Do not disturb
                  rv1974
                  Awesome! It's time to clean those Augean stables.
                    d12dozr
                    Sweet! Thanks, TIG!
                    +1
                    http://goo.gl/f7ooYh
                      Here's v1.1 http://forums.sketchucation.com/viewtopic.php?p=295290#p295290
                      It now has 'Material Consolidator' under the 'Tools' menu...
                      • Bob JamesB Offline
                        Bob James
                        Oh, YES!!
                        Thank you, TIG
                        • R Do not disturb
                          rv1974
                          Hi TIG!
                          I have some important suggestion. The majority of people working in the 3D field use some prefixes in the mats\layers\camera names. It's extremely helpful to differ my stuff from the others.I for example name all my assets in this way: zzz_blahblah. And everything is inserted in the initial template file.
                          So what I'm asking for is ability to set the default nameprioty directly in the ruby file
                          itself (just to set up it once and forget). In my case zzz_* formula would be dominant.
                          What do you think?
                            rv1974
                            At the moment the first material in the database is used in preference to any other matches [the names are not considered just the position in the list], so if you have 'zzz_Material', 'zzz_Material1' and 'xxx_Material99' that are all exact matching 'clones' and 'zzz_Material' is the first one then everything becomes 'zzz_Material' and the others are purged...
                            I can't see how we would use 'prefixes' to sort materials [at the moment, as I said, the name is ignored and its 'order of being created' is used] πŸ˜•
                              Here's v1.2 http://forums.sketchucation.com/viewtopic.php?p=295290#p295290
                              The listing and sorting algorithms have been optimized for speed and command-line/console progress messages added...
                              • R Do not disturb
                                rv1974
                                @tig said:
                                rv1974
                                order of being created is already a nice thing. The workaround is to embed a simple planes matrix with user common used materials applied into initial template.
                                Thank you.
                                  rocorona
                                  @tig said:
                                  @gaieus said:
                                  @tig said:
                                  These are:-
                                  materialType
                                  color RGB
                                  transparency [alpha]
                                  What is a material "type"?
                                  I feel I'm missing something basilar, but I can't find this in the "modify material" window.
                                    @rocorona said:
                                    @tig said:
                                    @gaieus said:
                                    @tig said:
                                    These are:-
                                    materialType
                                    color RGB
                                    The materialType is accessible via the API - it returns values [0/1/2] depending on if the material is simply a 'plain-color', has a 'texture' or it has a texture and it has been 'colorized'... that's all... http://code.google.com/apis/sketchup/docs/ourdoc/material.html#materialType
                                      rocorona
                                      TIG, "thanks" for your reply, and "thanks" for your great and valuable work!
                                      • E Offline
                                        Ecuadorian
                                        I was thinking about this yesterday, as using FormFonts objects bloats my files with duplicate materials.
                                        Thanks, TIG! πŸ‘
                                        -Miguel Lescano
                                          Here's v1.3 http://forums.sketchucation.com/viewtopic.php?p=295290#p295290
                                          It is now wrapped into its own class 'MaterialConsolidator'.
                                          • H Offline
                                            headshot
                                            GR8 !!!
                                            TY.
                                            • 1 / 3
